    Displacement Shapes
    renderpluginsextensions
    29 Posts 12 Posters 6.2k Views 12 Watching
      I'm thinking a larger scene with different displacements will be interesting. Alien-ish.
      • soloS Offline
        Slow day in the office? πŸ˜†
        Lookibg cool by the way.
          I wrote the UV tool during slow day at the office. πŸ˜‰
          This is me going through The Complete V-Ray Guide. Some of the examples had some extreme displacement, which gave me an idea I wanted to try out.
            Click Draw
            Looks like something Madonna might wear in concert 🀣
            Have I mentioned how much of a laugh I get out of some of the Signatures on here!
              The big boobie you mean?
              πŸ˜„
                The Fallen Madonna with the big boobies?
                • EarthMoverE Offline
                  EarthMover
                  Looks cool Thomas. I started going through the Complete guide myself. What a book! Sometime in 2011 I'll let you know how it is when I finish it.
                  Content Creator at Skapeup
                    I hadn't expected it to be that big. Somehow, the word "Guide" gave me a metnal image of a pocket-sized book. This thing is a behemoth! Hopefully this'll teach me a thing or two about V-Ray. ...but where to begin?
                    • soloS Offline
                      I seem to have a little glitch with my vray, I have recently installed vray on my new machine and everything works great but it does not render displacement, it shows it in material preview window but not in render.
                      I checked the same model on an older machine and it renders the displacement fine, is there someplace I need to check to enable displacement?
                      [edit] Figured it out, I'm having a blonde moment.
                        Care to share what you'd done in your blonde moment?
                        • soloS Offline
                          The model size on the new machine was too big so the dispacement value over the texture was reduced to a point that it was not noticable.
                          • FrederikF Offline
                            Frederik
                            Ouch... Have to admit that it also have happened for me... 😳
                            Recently it happened when I tried using your Vray Grass displace model... πŸ‘Ώ πŸ˜†
                            Didn't realize it was like 30cm grass... πŸ˜†
                            Aaahhh well... Good to know that I'm not the only occasional "blonde" around... πŸ˜†
                            Cheers
                            Kim Frederik
                            • soloS Offline
                              LOL, I have many blonde moments these days, must be age.
                              Thomthom, I used your displacement map from your first post and tried it with Vue:
                              http://img12.imageshack.us/img12/9549/ttdisplacement.jpg
                              I then exported the displaced mesh and opened it in SU.
                              http://img12.imageshack.us/img12/1562/displacementmesh.jpg
                                The one I used isn't the one I posted here. I used an 32bit image, as 8bit images will have a non-linear gamma correction applied it.
                                How did you create the mesh? Terrain generated from bitmap?
                                • soloS Offline
                                  Yes.
                                    BTM
                                    I bet it would be possible to make a whole mountain scene with a displacement map πŸ’š
                                    • soloS Offline
                                      Another quick test.
                                      Image made in paintshop:
                                      http://img7.imageshack.us/img7/7862/testdisp.jpg
                                      Then the displacement/terrain from image:
                                      http://img7.imageshack.us/img7/5422/testdisplacement.jpg
                                      And lastly the mesh from terraim/displacement opened in SU.
                                      http://img7.imageshack.us/img7/3478/testdisplacementmesh.jpg
                                        More 'boobies'. Tried out Two-Sided material. Though, I had expected it to be more translucent. Need to revisit this one. Other tests on plain geometry gave the results I expected, this one didn't. Wonder if it's due to the displacement.
                                        • soloS Offline
                                          I used your map again this time with Vray, and an American flag as a diffuse map.
                                          It UV mapped it perfectly....hmmm.
                                          http://img20.imageshack.us/img20/9247/usflagdisp.png
                                          • N Offline
                                            nomeradona
                                            excellent thread.
