    Displacement Shapes
    renderpluginsextensions
    29 Posts 12 Posters 6.7k Views 12 Watching
    • C
      Click Draw
      Looks like something Madonna might wear in concert 🀣
      Have I mentioned how much of a laugh I get out of some of the Signatures on here!
      • GaieusG
        The big boobie you mean?
        πŸ˜„
          The Fallen Madonna with the big boobies?
          • EarthMoverE
            EarthMover
            @thomthom said:
            I wrote the UV tool during slow day at the office. πŸ˜‰
            This is me going through The Complete V-Ray Guide. Some of the examples had some extreme displacement, which gave me an idea I wanted to try out.
            Looks cool Thomas. I started going through the Complete guide myself. What a book! Sometime in 2011 I'll let you know how it is when I finish it.
            Content Creator at Skapeup
              I hadn't expected it to be that big. Somehow, the word "Guide" gave me a metnal image of a pocket-sized book. This thing is a behemoth! Hopefully this'll teach me a thing or two about V-Ray. ...but where to begin?
              • soloS
                I seem to have a little glitch with my vray, I have recently installed vray on my new machine and everything works great but it does not render displacement, it shows it in material preview window but not in render.
                I checked the same model on an older machine and it renders the displacement fine, is there someplace I need to check to enable displacement?
                [edit] Figured it out, I'm having a blonde moment.
                  Care to share what you'd done in your blonde moment?
                  • soloS
                    The model size on the new machine was too big so the dispacement value over the texture was reduced to a point that it was not noticable.
                    • FrederikF
                      Frederik
                      Ouch... Have to admit that it also have happened for me... 😳
                      Recently it happened when I tried using your Vray Grass displace model... πŸ‘Ώ πŸ˜†
                      Didn't realize it was like 30cm grass... πŸ˜†
                      Aaahhh well... Good to know that I'm not the only occasional "blonde" around... πŸ˜†
                      Cheers
                      Kim Frederik
                      • soloS
                        LOL, I have many blonde moments these days, must be age.
                        Thomthom, I used your displacement map from your first post and tried it with Vue:
                        http://img12.imageshack.us/img12/9549/ttdisplacement.jpg
                        I then exported the displaced mesh and opened it in SU.
                        http://img12.imageshack.us/img12/1562/displacementmesh.jpg
                          The one I used isn't the one I posted here. I used an 32bit image, as 8bit images will have a non-linear gamma correction applied it.
                          How did you create the mesh? Terrain generated from bitmap?
                          • soloS
                            Yes.
                            • B
                              BTM
                              I bet it would be possible to make a whole mountain scene with a displacement map πŸ’š
                              • soloS
                                Another quick test.
                                Image made in paintshop:
                                http://img7.imageshack.us/img7/7862/testdisp.jpg
                                Then the displacement/terrain from image:
                                http://img7.imageshack.us/img7/5422/testdisplacement.jpg
                                And lastly the mesh from terraim/displacement opened in SU.
                                http://img7.imageshack.us/img7/3478/testdisplacementmesh.jpg
                                  More 'boobies'. Tried out Two-Sided material. Though, I had expected it to be more translucent. Need to revisit this one. Other tests on plain geometry gave the results I expected, this one didn't. Wonder if it's due to the displacement.
                                  • soloS
                                    I used your map again this time with Vray, and an American flag as a diffuse map.
                                    It UV mapped it perfectly....hmmm.
                                    http://img20.imageshack.us/img20/9247/usflagdisp.png
                                    • N
                                      nomeradona
                                      excellent thread.
                                        AcesHigh
                                        Your image seens jagged... like if there was a small displacement map applied on top of the original displacement map. Look how much more "smooth" are the "turbine" images from TomTom.
                                        • N
                                          notareal
                                          I believe jaggin is result of ldr displacement map.
                                          • coulteriC
                                            coulteri
                                            Hey! That's great! πŸ˜„ Thom, could you tell me, how do you create displacement maps? Is it kind of software, that converts 3D object into the map?
                                            Thanks.
                                            Coulteri
