    SketchUp Blogs
    15 Posts 7 Posters 2.0k Views 7 Watching
    • Al HartA Offline
      Al Hart
      I have created a new Web Page which will let you read all the SketchUp Blogs on a single page.
      Take a look: SketchUp Blogs
      If you have a SketchUp blog and would like to have it added, let me know.
      Al Hart
      IRender nXt from Render Plus
        • Al HartA Offline
          Al Hart
          I found most of these blogs on Jim Foltz's Blog.
          I added a couple more this morning:
          (here is the complete list so far)
          * Official SketchUp Blog
          * 3D Construction Modeling
          * Bonnie's Blog
          * Google SketchUp 3D Challenge
          * My sketchup blog
          * [Plugin] SketchUp Blog
          * Provelo - SketchUp Blog
          * Remus’ Rendering
          * Render Plus Blog
          * SketchStuff
          * SketchUp by Dawn
          * SketchUp Graphics Blog
          * SketchUp Ireland Blog
          * SketchupLinks
          * Tony's Sketchup Modeling
          * Whaat's Up SketchUp Plugins Blog
          If you want to add one of your own, there is a place to submit a link at the bottom of the page:
          Add a Blog
          Al Hart
            August
            Hi Al,
            I have been trying to access that page all day and and have had no luck.
            Have you changed the location, had a server problem, or is just my flaky computer and/or flaky Comcast connection that's again causing me headaches?
            Thanks,
            August
            “An idea, like a ghost, must be spoken to a little before it will explain itself.”
            [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
              BTM
              There seems to be a little issue with the page. While loading, twice I get a 'Slow Script' message, in which I have to stop running the script in question, as it makes my browser unresponsive.
              … This appears twice.
              • K Offline
                kwistenbiebel
                The same here (Firefox on vista x64).
                Totally crashed my browser.
                • Chris FullmerC Offline
                  I just tried it and it loaded right up.
                  All my Plugins I've written
                  • K Offline
                    kwistenbiebel
                    It might be my script blocker that makes it act funny.
                    That same script blocker keeps my PC healthy though, so I rather not switch it off.
                    • K Offline
                      Khai
                      ok it does look like Noscript's to blame... but when the site is allowed through. then firefox locks up trying to load something on the page.
                      tried this on 2 machines, same result so far..
                      • Al HartA Offline
                        Al Hart
                        Its not working for me either.
                        I'll try separating each of the blog feeds and see if I can figure out which one is messing it up.
                        In the meantime, you can see a summary of all the blogs in a different format here: RPS BLOG
                        Al Hart
                        • Al HartA Offline
                          Al Hart
                          I think I have this working again:
                          All SktechUp Blogs
                          Al Hart
                            BTM
                            Unfortunately, I still get the loading issues.
                            • Al HartA Offline
                              Al Hart
                              It may be a cache issue. Since the original link locks the browser, it may be difficult to clear it.
                              I copied the page to a new URL. Try this:
                              http://www.renderplus.com/htm/SketchUpBlogs2.htm
                              (If it works let me know and will change my other links to link to the new page)
                              If the new page works, try the same one at the old address again:
                              http://www.renderplus.com/htm/SketchUpBlogs.htm
                              Al Hart
                                BTM
                                The new URL works fine 😉
                                …Also, after emptying the cache, the old URL works fine too 😄
                                  August
                                  Thanks Al,
                                  Ditto for me. Both URLs working fine at this point.
                                  August
