    SketchUp Blogs
    15 Posts 7 Posters 2.4k Views 7 Watching
    • Al HartA
      Al Hart
      I found most of these blogs on Jim Foltz's Blog.
      I added a couple more this morning:
      (here is the complete list so far)
      * Official SketchUp Blog
      * 3D Construction Modeling
      * Bonnie's Blog
      * Google SketchUp 3D Challenge
      * My sketchup blog
      * [Plugin] SketchUp Blog
      * Provelo - SketchUp Blog
      * Remus’ Rendering
      * Render Plus Blog
      * SketchStuff
      * SketchUp by Dawn
      * SketchUp Graphics Blog
      * SketchUp Ireland Blog
      * SketchupLinks
      * Tony's Sketchup Modeling
      * Whaat's Up SketchUp Plugins Blog
      If you want to add one of your own, there is a place to submit a link at the bottom of the page:
      Add a Blog
      Al Hart
      IRender nXt from Render Plus
        August
        Hi Al,
        @al hart said:
        I have created a new Web Page which will let you read all the SketchUp Blogs on a single page.
        Take a look: SketchUp Blogs
        I have been trying to access that page all day and and have had no luck.
        Have you changed the location, had a server problem, or is just my flaky computer and/or flaky Comcast connection that's again causing me headaches?
        Thanks,
        August
        “An idea, like a ghost, must be spoken to a little before it will explain itself.”
        [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
        • B
          BTM
          There seems to be a little issue with the page. While loading, twice I get a 'Slow Script' message, in which I have to stop running the script in question, as it makes my browser unresponsive.
          … This appears twice.
          • K
            kwistenbiebel
            The same here (Firefox on vista x64).
            Totally crashed my browser.
            • Chris FullmerC
              I just tried it and it loaded right up.
              • K
                kwistenbiebel
                It might be my script blocker that makes it act funny.
                That same script blocker keeps my PC healthy though, so I rather not switch it off.
                • K
                  Khai
                  ok it does look like Noscript's to blame... but when the site is allowed through. then firefox locks up trying to load something on the page.
                  tried this on 2 machines, same result so far..
                  • Al HartA
                    Al Hart
                    Its not working for me either.
                    I'll try separating each of the blog feeds and see if I can figure out which one is messing it up.
                    In the meantime, you can see a summary of all the blogs in a different format here: RPS BLOG
                    Al Hart
                    • Al HartA
                      Al Hart
                      I think I have this working again:
                      All SktechUp Blogs
                      Al Hart
                      • B
                        BTM
                        Unfortunately, I still get the loading issues.
                        • Al HartA
                          Al Hart
                          It may be a cache issue. Since the original link locks the browser, it may be difficult to clear it.
                          I copied the page to a new URL. Try this:
                          http://www.renderplus.com/htm/SketchUpBlogs2.htm
                          (If it works let me know and will change my other links to link to the new page)
                          If the new page works, try the same one at the old address again:
                          http://www.renderplus.com/htm/SketchUpBlogs.htm
                          Al Hart
                          • B
                            BTM
                            The new URL works fine 😉
                            …Also, after emptying the cache, the old URL works fine too 😄
                              August
                              Thanks Al,
                              Ditto for me. Both URLs working fine at this point.
                              August
