    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.3m Views 345 Watching
    • fredo6F
      fredo6
      Very cool, thank you!
      I have a couple of questions.
      1. I use F4 for reverse faces as a keyboard shortcut therefore it is not working with Freescale at the moment. How can I change your script to accept another keystroke, like F12 for example?
        (I did notice on "Bend" however if I press Tab to adjust the parameters then it will activate the slicer).
      2. I notice in the Youtube video you have 13 icons on the toolbar. Mine only shows 10 and one that I have you don't. I also don't see an option to add or delete any in the Default Parameters Dialog.
      Thanks.
      You can change the key assignments and show more (or less) toolbar icons by modifying the settings in the FreeScale Default Parameters dialog box (the menu entry is under FreeScale, not under LibFredo6).
      To activate the slicer and divider, you also have the contextual menus.
      Fredo
      • Jean-FrancoJ
        Jean-Franco
        What a plugin !!!
        Thank you Fredo, your great developments have really a special flavor.
        Again, special thanks to all great Ruby scripters here.
        Jean-Franco
          Et Γ§Γ  marche? πŸ’š
          PS : If the Stretch makes 3 cushions that will be a "Dynamic Component" πŸ˜‰
          • StinkieS
            Stinkie
            Thank you. This is most impressive.
            • B
              BUDLA
              Et Γ§Γ  marche? πŸ’š
              Very ccool scripts! πŸ‘
              Little trick and "Dynamic component"-Ready!
              Thanks Fredo
              Little trick.zip
              Budla
                Yes, but Dynamic components "multiply" here you have always 4 boxes πŸ˜‰
                • M
                  mehdiettouile
                  C'est du travail de grand maitre, j'ai presque honte de ne pouvoir dire que merci.
                  • B
                    BUDLA
                    Yep! Anyway its good for me!
                    Budla
                    • thomthomT
                      Just in case nobody else has noticed, there's an html file (freescale.donation.html) in the freescale_dir_20 folder.. you can make a donation via that link.
                      This he truly deserves!
                      • S
                        sepo
                        clean selection?
                        • S
                          sepo
                          aha πŸ˜„ I see what you mean.
                          Awesome plugin Fredo. Thank you very much. πŸ‘ πŸ‘
                          • pep75P
                            pep75
                            πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„
                            GOOGLE SHOULD THANK PEOPLE LIKE YOU! This plugin is exactly what SU needed in the 7th version but they didn't see it. You're brilliant. THNX!!!
                            • CadFatherC
                              CadFather
                              Master SuperFredo has done it again! 😲 β˜€
                              ..it's a pleasure just to admire the genius!
                              (hope google is listening)
                              Thank You Fredo.
                              • I
                                ilay7k
                                Thank you! 😍
                                • MarianM
                                  Marian
                                  THANK YOU VERY VERY MUCH, thess tools were diarely needed in SU.
                                  Cheers.
                                  • GaieusG
                                    This is again one of the greatest plugins, Fredo! There are so many of "one of the greates plugins" by you now that the expression is getting inflated however. πŸ˜‰
                                    Thanks a bunch!
                                    • G
                                      Gjenio
                                      Your scripts are just incredible!
                                      Thank you Fredo
                                      You are great
                                      • T
                                        torben.wadlinger
                                        I say "Wooooooaaaaaaaahhh!"
                                        Google, be ashamed!
                                        Great job, man. Great job!
                                        Torben
                                        • K
                                          kwistenbiebel
                                          A one man development team. Wonderful!
                                          Google, shame on you +1
                                          • boofredlayB
                                            boofredlay
                                            Fredo
                                            Got it, thank you very much for the response, and the plugin.
                                            • 58
                                            • 59
                                            • 2 / 59
