    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.0m Views 345 Watching
      BUDLA
      Et Γ§Γ  marche? πŸ’š
      PS : If the Stretch makes 3 cushions that will be a "Dynamic Component" πŸ˜‰
      Very ccool scripts! πŸ‘
      Little trick and "Dynamic component"-Ready!
      Thanks Fredo
      Little trick.zip
      Budla
        Yes, but Dynamic components "multiply" here you have always 4 boxes πŸ˜‰
          mehdiettouile
          C'est du travail de grand maitre, j'ai presque honte de ne pouvoir dire que merci.
            BUDLA
            Yep! Anyway its good for me!
            Budla
              Just in case nobody else has noticed, there's an html file (freescale.donation.html) in the freescale_dir_20 folder.. you can make a donation via that link.
              This he truly deserves!
                sepo
                clean selection?
                  sepo
                  aha πŸ˜„ I see what you mean.
                  Awesome plugin Fredo. Thank you very much. πŸ‘ πŸ‘
                  • pep75P Offline
                    pep75
                    πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„
                    GOOGLE SHOULD THANK PEOPLE LIKE YOU! This plugin is exactly what SU needed in the 7th version but they didn't see it. You're brilliant. THNX!!!
                    • CadFatherC Offline
                      CadFather
                      Master SuperFredo has done it again! 😲 β˜€
                      ..it's a pleasure just to admire the genius!
                      (hope google is listening)
                      Thank You Fredo.
                      • I Offline
                        ilay7k
                        Thank you! 😍
                        • MarianM Offline
                          Marian
                          THANK YOU VERY VERY MUCH, thess tools were diarely needed in SU.
                          Cheers.
                            This is again one of the greatest plugins, Fredo! There are so many of "one of the greates plugins" by you now that the expression is getting inflated however. πŸ˜‰
                            Thanks a bunch!
                              Gjenio
                              Your scripts are just incredible!
                              Thank you Fredo
                              You are great
                                torben.wadlinger
                                I say "Wooooooaaaaaaaahhh!"
                                Google, be ashamed!
                                Great job, man. Great job!
                                Torben
                                  kwistenbiebel
                                  A one man development team. Wonderful!
                                  Google, shame on you +1
                                  • boofredlayB Offline
                                    boofredlay
                                    You can change the key assignments and show more (or less) toolbar icons by modifying the settings in the FreeScale Default Parameters dialog box (the menu entry is under FreeScale, not under LibFredo6).
                                    To activate the slicer and divider, you also have the contextual menus.
                                    Got it, thank you very much for the response, and the plugin.
                                    • W Offline
                                      wrecknball
                                      Wow! Just had my first cup of coffee and thought I would check to see about the "Bend" plugin. It's like christmas morning. Thanks sooooo much Fredo!
                                      I will give it a try and post some results. Thanks again.
                                      • N Offline
                                        notareal
                                        Thank you. This is like Christmas!
                                        • broomstickB Offline
                                          broomstick
                                          this
                                          is
                                          utterly
                                          AWESOME!
                                          You are doing an incredible job. Thank you so much!
                                          • soloS Offline
                                            Scripters like you are what gives the 'UP' in Sketchup. Thanks a ton for all you hard work and thoughtful rubies.
                                            • 58
                                            • 59
                                            • 2 / 59
