    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.4m Views 345 Watching
    • chippwaltersC
      chippwalters
      Truly a most remarkable plugin. And so sensible as well. Congratulations on not only brillant scripting, but wonderful imagination as well! 😄
      Currently working with Cross-Reality technologies
      • Chris FullmerC
        Excellent Fredo!, I'm going to rush home and check this one out,
        • G
          gaganraj
          the ruby masters make me realize how amazing a program sketchup can/should be. THis addition is awsome!
          • L
            leixing
            i just say : thank you very very very very very much!
            rise !
            • boofredlayB
              boofredlay
              Very cool, thank you!
              I have a couple of questions.
              1. I use F4 for reverse faces as a keyboard shortcut therefore it is not working with Freescale at the moment. How can I change your script to accept another keystroke, like F12 for example?
                (I did notice on "Bend" however if I press Tab to adjust the parameters then it will activate the slicer).
              2. I notice in the Youtube video you have 13 icons on the toolbar. Mine only shows 10 and one that I have you don't. I also don't see an option to add or delete any in the Default Parameters Dialog.
              Thanks.
              • MALAISEM
                MALAISE
                Fredo,
                (Rien de très nouveau ! encore un plugin inutile qui va encombrer la barre d'outils !)
                ( 👍 )*10^n avec n variant de 1 à k, k : nombre de téléchargements du plugin!
                MALAISE 😄
                • G
                  gamore
                  Thank you Fredo6
                  FreeScale 2.0a is quite great!
                    remus
                    A very slight aside,
                    these are the only toolbars i think necessary to have open:
                    As you notice they are pretty much all yours, i think it says a lot about the quality of your plugins 👍
                    • fredo6F
                      Thanks.
                      You can change the key assignments and show more (or less) toolbar icons by modifying the settings in the FreeScale Default Parameters dialog box (the menu entry is under FreeScale, not under LibFredo6).
                      To activate the slicer and divider, you also have the contextual menus.
                      • Jean-FrancoJ
                        Jean-Franco
                        What a plugin !!!
                        Thank you Fredo, your great developments have really a special flavor.
                        Again, special thanks to all great Ruby scripters here.
                        Jean-Franco
                          Et çà marche? 💚
                          PS : If the Stretch makes 3 cushions that will be a "Dynamic Component" 😉
                          • StinkieS
                            Stinkie
                            Thank you. This is most impressive.
                            • B
                              BUDLA
                              Et çà marche? 💚
                              Very ccool scripts! 👍
                              Little trick and "Dynamic component"-Ready!
                              Thanks Fredo
                              Little trick.zip
                              Budla
                                Yes, but Dynamic components "multiply" here you have always 4 boxes 😉
                                  mehdiettouile
                                  C'est du travail de grand maitre, j'ai presque honte de ne pouvoir dire que merci.
                                  • B
                                    BUDLA
                                    Yep! Anyway its good for me!
                                    Budla
                                      Just in case nobody else has noticed, there's an html file (freescale.donation.html) in the freescale_dir_20 folder.. you can make a donation via that link.
                                      This he truly deserves!
                                        sepo
                                        clean selection?
                                          sepo
                                          aha 😄 I see what you mean.
                                          Awesome plugin Fredo. Thank you very much. 👍 👍
                                          • pep75P
                                            pep75
                                            GOOGLE SHOULD THANK PEOPLE LIKE YOU! This plugin is exactly what SU needed in the 7th version but they didn't see it. You're brilliant. THNX!!!
                                            • 58
                                            • 59
                                            • 2 / 59
