    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.0m Views 345 Watching
    • StinkieS Offline
      Stinkie
      Thank you. This is most impressive.
        BUDLA
        Et Γ§Γ  marche? πŸ’š
        PS : If the Stretch makes 3 cushions that will be a "Dynamic Component" πŸ˜‰
        Very ccool scripts! πŸ‘
        Little trick and "Dynamic component"-Ready!
        Thanks Fredo
        Little trick.zip
        Budla
          Yes, but Dynamic components "multiply" here you have always 4 boxes πŸ˜‰
            mehdiettouile
            C'est du travail de grand maitre, j'ai presque honte de ne pouvoir dire que merci.
              BUDLA
              Yep! Anyway its good for me!
              Budla
                Just in case nobody else has noticed, there's an html file (freescale.donation.html) in the freescale_dir_20 folder.. you can make a donation via that link.
                This he truly deserves!
                  sepo
                  clean selection?
                    sepo
                    aha πŸ˜„ I see what you mean.
                    Awesome plugin Fredo. Thank you very much. πŸ‘ πŸ‘
                    • pep75P Offline
                      pep75
                      πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„
                      GOOGLE SHOULD THANK PEOPLE LIKE YOU! This plugin is exactly what SU needed in the 7th version but they didn't see it. You're brilliant. THNX!!!
                      • CadFatherC Offline
                        CadFather
                        Master SuperFredo has done it again! 😲 β˜€
                        ..it's a pleasure just to admire the genius!
                        (hope google is listening)
                        Thank You Fredo.
                        • I Offline
                          ilay7k
                          Thank you! 😍
                          • MarianM Offline
                            Marian
                            THANK YOU VERY VERY MUCH, thess tools were diarely needed in SU.
                            Cheers.
                              This is again one of the greatest plugins, Fredo! There are so many of "one of the greates plugins" by you now that the expression is getting inflated however. πŸ˜‰
                              Thanks a bunch!
                                Gjenio
                                Your scripts are just incredible!
                                Thank you Fredo
                                You are great
                                  torben.wadlinger
                                  I say "Wooooooaaaaaaaahhh!"
                                  Google, be ashamed!
                                  Great job, man. Great job!
                                  Torben
                                    kwistenbiebel
                                    A one man development team. Wonderful!
                                    Google, shame on you +1
                                    • boofredlayB Offline
                                      boofredlay
                                      You can change the key assignments and show more (or less) toolbar icons by modifying the settings in the FreeScale Default Parameters dialog box (the menu entry is under FreeScale, not under LibFredo6).
                                      To activate the slicer and divider, you also have the contextual menus.
                                      Got it, thank you very much for the response, and the plugin.
                                      • W Offline
                                        wrecknball
                                        Wow! Just had my first cup of coffee and thought I would check to see about the "Bend" plugin. It's like christmas morning. Thanks sooooo much Fredo!
                                        I will give it a try and post some results. Thanks again.
                                        • N Offline
                                          notareal
                                          Thank you. This is like Christmas!
                                          • broomstickB Offline
                                            broomstick
                                            this
                                            is
                                            utterly
                                            AWESOME!
                                            You are doing an incredible job. Thank you so much!
                                            • 58
                                            • 59
                                            • 2 / 59
