    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.3m Views 345 Watching
      Et Γ§Γ  marche? πŸ’š
      PS : If the Stretch makes 3 cushions that will be a "Dynamic Component" πŸ˜‰
      • StinkieS
        Stinkie
        Thank you. This is most impressive.
        • B
          BUDLA
          Et Γ§Γ  marche? πŸ’š
          Very ccool scripts! πŸ‘
          Little trick and "Dynamic component"-Ready!
          Thanks Fredo
          Little trick.zip
          Budla
            Yes, but Dynamic components "multiply" here you have always 4 boxes πŸ˜‰
              mehdiettouile
              C'est du travail de grand maitre, j'ai presque honte de ne pouvoir dire que merci.
              • B
                BUDLA
                Yep! Anyway its good for me!
                Budla
                  Just in case nobody else has noticed, there's an html file (freescale.donation.html) in the freescale_dir_20 folder.. you can make a donation via that link.
                  This he truly deserves!
                    sepo
                    clean selection?
                      sepo
                      aha πŸ˜„ I see what you mean.
                      Awesome plugin Fredo. Thank you very much. πŸ‘ πŸ‘
                      • pep75P
                        pep75
                        πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„
                        GOOGLE SHOULD THANK PEOPLE LIKE YOU! This plugin is exactly what SU needed in the 7th version but they didn't see it. You're brilliant. THNX!!!
                        • CadFatherC
                          CadFather
                          Master SuperFredo has done it again! 😲 β˜€
                          ..it's a pleasure just to admire the genius!
                          (hope google is listening)
                          Thank You Fredo.
                          • I
                            ilay7k
                            Thank you! 😍
                            • MarianM
                              Marian
                              THANK YOU VERY VERY MUCH, thess tools were diarely needed in SU.
                              Cheers.
                              • GaieusG
                                This is again one of the greatest plugins, Fredo! There are so many of "one of the greates plugins" by you now that the expression is getting inflated however. πŸ˜‰
                                Thanks a bunch!
                                • G
                                  Gjenio
                                  Your scripts are just incredible!
                                  Thank you Fredo
                                  You are great
                                  • T
                                    torben.wadlinger
                                    I say "Wooooooaaaaaaaahhh!"
                                    Google, be ashamed!
                                    Great job, man. Great job!
                                    Torben
                                    • K
                                      kwistenbiebel
                                      A one man development team. Wonderful!
                                      Google, shame on you +1
                                      • boofredlayB
                                        boofredlay
                                        You can change the key assignments and show more (or less) toolbar icons by modifying the settings in the FreeScale Default Parameters dialog box (the menu entry is under FreeScale, not under LibFredo6).
                                        To activate the slicer and divider, you also have the contextual menus.
                                        Got it, thank you very much for the response, and the plugin.
                                        • W
                                          wrecknball
                                          Wow! Just had my first cup of coffee and thought I would check to see about the "Bend" plugin. It's like christmas morning. Thanks sooooo much Fredo!
                                          I will give it a try and post some results. Thanks again.
                                          • N
                                            notareal
                                            Thank you. This is like Christmas!
                                            • 58
                                            • 59
                                            • 2 / 59
