    [Plugin Library] LibFredo6
    2.2k Posts 583 Posters 7.7m Views 585 Watching
    • alexpacio2013A Offline
      alexpacio2013
      Dopo tre giorni passati a Cercare il colpevole l'ho trovato. In pratica sono i plugin di S4U che mandano in crash sketchup in quanto vanno in conflitto con Fredolib.
        alexpacio2013 @fredo6
        @fredo6 After three days of work to figure out what was causing SketchUp to crash, I discovered that there's an incompatibility between the S4U plugins and the new Fredo libraries. Now I have the 2026 version working perfectly.
        • F Offline
          fizaharon
          it was said that the license expired huhu
          TIGT 1 Reply Last reply Reply Quote 0
            TIG Moderator @fizaharon
            @fizaharon
            LibFredo6 doesn't need a license.
            What's the message about ?
            Are you using an extensions that needs a license and it's reporting the trial period has expired ?
            If so license it, or continue this report in that extension's forum-thread, not here.
            • fredo6F Offline
              fredo6
              NEW RELEASE: LibFredo6 v15.6a - 26 Nov 25
              LibFredo6 15.6a is a major release. It includes changes related to:
              • Full and future compatibility with SU2026
              • Other bug Fixing and technical adjustments
              Requirements: SU2017 and above
              See plugin home page of LibFredo6 for Download of LibFredo6.
              Main Post of the LibFredo6 thread
              • fredo6F Offline
                fredo6
                NEW RELEASE: LibFredo6 v15.6b - 02 Dec 25
                LibFredo6 15.6b is a minor release. It includes changes related to:
                • Preparation for future plugin
                • fredo6F Offline
                  fredo6
                  NEW RELEASE: LibFredo6 v15.6c - 10 Dec 25
                  LibFredo6 15.6c is a minor release. It includes changes related to:
                  • Full compatibility with SU2026.1
                  • fredo6F Offline
                    fredo6
                    NEW RELEASE: LibFredo6 v15.7a - 26 Dec 25
                    LibFredo6 15.7a is a major release. It includes changes related to:
                    • New plugin: FredoSection v1.3a
                    • fredo6F Offline
                      fredo6
                      NEW RELEASE: LibFredo6 v15.7b - 02 Jan 26
                      LibFredo6 15.7b is a major release. It includes changes related to:
                      • Bug Fixing and technical adjustments
                      • fredo6F Offline
                        fredo6
                        NEW RELEASE: LibFredo6 v15.8a - 09 Jan 26
                        LibFredo6 15.8a is a major release. It includes changes related to:
                        • Bug Fixing for Animator
                        • Evolutions for FredoSection v1.4a
                        • panixiaP Offline
                          panixia
                          Hi Fredo, today I updated libfredo to the last version and I just discovered that it broke LOTT on Sketchup 2021.
                          The plugin is still working, but is not possible to edit and create custom toolbars and palettes anymore.
                          I can just use the already existing ones.
                          • fredo6F Offline
                            fredo6
                            Do you get errors in the Ruby console ?
                            • panixiaP Offline
                              panixia
                              No, I don't.
                              All I can say is that if I try to drag a new icon into an existing toolbar, it doesn't add to it.
                              I can create a new toolbar, but again, I can't populate it, if I drag icons on the new toolbar nothing happens.
                              I'm pretty sure that the problem is related to libfredo6, because if I remove it and load an older version, everything works as intended.
                              • fredo6F Offline
                                fredo6
                                @panixia
                                which version of LOTT do you run?
                                panixiaP 1 Reply Last reply Reply Quote 0
                                • fredo6F Offline
                                  fredo6
                                  NEW RELEASE: LibFredo6 v15.8b - 12 Jan 26
                                  LibFredo6 15.8b is a maintenance release. It includes changes related to:
                                  • Bug Fixing for picking tools
                                  • Evolutions for Axyz
                                  • panixiaP Offline
                                    panixia @fredo6
                                    @fredo6 LOTT v2.6a - 31 Oct 23
                                    I never updated it, because I understood that you had to remove features in latest versions, so I followed the general rule "If ain't broke don't fix it".. should I update?
                                    • fredo6F Offline
                                      fredo6
                                      NEW RELEASE: LibFredo6 v15.8c - 28 Jan 26
                                      LibFredo6 15.8c is a maintenance release. It includes changes related to:
                                      • Bug Fixing for ColorScale (favorites)
                                      • fredo6F Offline
                                        fredo6
                                        NEW RELEASE: LibFredo6 v15.8d - 01 Feb 26
                                        LibFredo6 15.8d is a maintenance release. It includes changes related to:
                                        • Bug Fixing for Animator and other plugins
                                          SunnyGee2017
                                          Sketchup 2024 (24.0.553 64-Bit) crashes constantly when I use Rounded Corner or Joint Push/Pull. I have already installed the latest lib (15.8d) and updated all drivers (Radeon RX550).
                                          TIGT fredo6F 2 Replies Last reply Reply Quote 0
                                            TIG Moderator @SunnyGee2017
                                            @SunnyGee2017
                                            I think @fredo6 will need more details before he can fully look into the cause...
                                            e.g.
                                            Are there any error messages in the Ruby Console or message-boxes ?
                                            What kind of 'crash' is it ?
                                            If it's a BugSplat then what are its details, and have you send these reports into SketchUp ?
                                            S 1 Reply Last reply Reply Quote 0
                                            • 107
                                            • 108
                                            • 109
                                            • 110
                                            • 111
                                            • 112
                                            • 113
                                            • 109 / 113
