    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 585 Posters 9.8m Views 587 Watching
    • fredo6F
      Do you start Sketchup with the default template or a custom template ?
      What happens if you deinstall Sketchucation and just install LibFredo6 ?
      alexpacio2013A 1 Reply Last reply
      • alexpacio2013A
        alexpacio2013
        Dopo tre giorni passati a Cercare il colpevole l'ho trovato. In pratica sono i plugin di S4U che mandano in crash sketchup in quanto vanno in conflitto con Fredolib.
        • alexpacio2013A
          alexpacio2013 @fredo6
          @fredo6 After three days of work to figure out what was causing SketchUp to crash, I discovered that there's an incompatibility between the S4U plugins and the new Fredo libraries. Now I have the 2026 version working perfectly.
          • F
            fizaharon
            it was said that the license expired huhu
            TIGT 1 Reply Last reply
              TIG Moderator @fizaharon
              @fizaharon
              LibFredo6 doesn't need a license.
              What's the message about ?
              Are you using an extensions that needs a license and it's reporting the trial period has expired ?
              If so license it, or continue this report in that extension's forum-thread, not here.
              • fredo6F
                NEW RELEASE: LibFredo6 v15.6a - 26 Nov 25
                LibFredo6 15.6a is a major release. It includes changes related to:
                • Full and future compatibility with SU2026
                • Other bug Fixing and technical adjustments
                • fredo6F
                  NEW RELEASE: LibFredo6 v15.6b - 02 Dec 25
                  LibFredo6 15.6b is a minor release. It includes changes related to:
                  • Preparation for future plugin
                  • fredo6F
                    NEW RELEASE: LibFredo6 v15.6c - 10 Dec 25
                    LibFredo6 15.6c is a minor release. It includes changes related to:
                    • Full compatibility with SU2026.1
                    1 Reply Last reply ๐Ÿ‘
                    • fredo6F
                      NEW RELEASE: LibFredo6 v15.7a - 26 Dec 25
                      LibFredo6 15.7a is a major release. It includes changes related to:
                      • New plugin: FredoSection v1.3a
                      • fredo6F
                        NEW RELEASE: LibFredo6 v15.7b - 02 Jan 26
                        LibFredo6 15.7b is a major release. It includes changes related to:
                        • Bug Fixing and technical adjustments
                        • fredo6F
                          NEW RELEASE: LibFredo6 v15.8a - 09 Jan 26
                          LibFredo6 15.8a is a major release. It includes changes related to:
                          • Bug Fixing for Animator
                          • Evolutions for FredoSection v1.4a
                          • panixiaP
                            panixia
                            Hi Fredo, today I updated libfredo to the last version and I just discovered that it broke LOTT on Sketchup 2021.
                            The plugin is still working, but is not possible to edit and create custom toolbars and palettes anymore.
                            I can just use the already existing ones.
                            • fredo6F
                              Do you get errors in the Ruby console ?
                              • panixiaP
                                panixia
                                No, I don't.
                                All I can say is that if I try to drag a new icon into an existing toolbar, it doesn't add to it.
                                I can create a new toolbar, but again, I can't populate it, if I drag icons on the new toolbar nothing happens.
                                I'm pretty sure that the problem is related to libfredo6, because if I remove it and load an older version, everything works as intended.
                                • fredo6F
                                  @panixia
                                  which version of LOTT do you run?
                                  panixiaP 1 Reply Last reply
                                  • fredo6F
                                    NEW RELEASE: LibFredo6 v15.8b - 12 Jan 26
                                    LibFredo6 15.8b is a maintenance release. It includes changes related to:
                                    • Bug Fixing for picking tools
                                    • Evolutions for Axyz
                                    • panixiaP
                                      panixia @fredo6
                                      @fredo6 LOTT v2.6a - 31 Oct 23
                                      I never updated it, because I understood that you had to remove features in latest versions, so I followed the general rule "If ain't broke don't fix it".. should I update?
                                      • fredo6F
                                        NEW RELEASE: LibFredo6 v15.8c - 28 Jan 26
                                        LibFredo6 15.8c is a maintenance release. It includes changes related to:
                                        • Bug Fixing for ColorScale (favorites)
                                        • fredo6F
                                          NEW RELEASE: LibFredo6 v15.8d - 01 Feb 26
                                          LibFredo6 15.8d is a maintenance release. It includes changes related to:
                                          • Bug Fixing for Animator and other plugins
                                            SunnyGee2017
                                            Sketchup 2024 (24.0.553 64-Bit) crashes constantly when I use Rounded Corner or Joint Push/Pull. I have already installed the latest lib (15.8d) and updated all drivers (Radeon RX550).
                                            TIGT fredo6F 2 Replies Last reply
                                            • 107
                                            • 108
                                            • 109
                                            • 110
                                            • 111
                                            • 112
                                            • 113
                                            • 114
                                            • 109 / 114
