    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 586 Posters 10.8m Views 588 Watching
    • fredo6F
      NEW RELEASE: LibFredo6 v15.6a - 26 Nov 25
      LibFredo6 15.6a is a major release. It includes changes related to:
      • Full and future compatibility with SU2026
      • Other bug Fixing and technical adjustments
      • fredo6F
        NEW RELEASE: LibFredo6 v15.6b - 02 Dec 25
        LibFredo6 15.6b is a minor release. It includes changes related to:
        • Preparation for future plugin
        • fredo6F
          NEW RELEASE: LibFredo6 v15.6c - 10 Dec 25
          LibFredo6 15.6c is a minor release. It includes changes related to:
          • Full compatibility with SU2026.1
          1 Reply Last reply πŸ‘
          • fredo6F
            NEW RELEASE: LibFredo6 v15.7a - 26 Dec 25
            LibFredo6 15.7a is a major release. It includes changes related to:
            • New plugin: FredoSection v1.3a
            • fredo6F
              NEW RELEASE: LibFredo6 v15.7b - 02 Jan 26
              LibFredo6 15.7b is a major release. It includes changes related to:
              • Bug Fixing and technical adjustments
              • fredo6F
                NEW RELEASE: LibFredo6 v15.8a - 09 Jan 26
                LibFredo6 15.8a is a major release. It includes changes related to:
                • Bug Fixing for Animator
                • Evolutions for FredoSection v1.4a
                • panixiaP
                  panixia
                  Hi Fredo, today I updated libfredo to the last version and I just discovered that it broke LOTT on Sketchup 2021.
                  The plugin is still working, but is not possible to edit and create custom toolbars and palettes anymore.
                  I can just use the already existing ones.
                  • fredo6F
                    Do you get errors in the Ruby console ?
                    • panixiaP
                      panixia
                      No, I don't.
                      All I can say is that if I try to drag a new icon into an existing toolbar, it doesn't add to it.
                      I can create a new toolbar, but again, I can't populate it, if I drag icons on the new toolbar nothing happens.
                      I'm pretty sure that the problem is related to libfredo6, because if I remove it and load an older version, everything works as intended.
                      • fredo6F
                        @panixia
                        which version of LOTT do you run?
                        panixiaP 1 Reply Last reply
                        • fredo6F
                          NEW RELEASE: LibFredo6 v15.8b - 12 Jan 26
                          LibFredo6 15.8b is a maintenance release. It includes changes related to:
                          • Bug Fixing for picking tools
                          • Evolutions for Axyz
                          • panixiaP
                            panixia @fredo6
                            @fredo6 LOTT v2.6a - 31 Oct 23
                            I never updated it, because I understood that you had to remove features in latest versions, so I followed the general rule "If ain't broke don't fix it".. should I update?
                            • fredo6F
                              NEW RELEASE: LibFredo6 v15.8c - 28 Jan 26
                              LibFredo6 15.8c is a maintenance release. It includes changes related to:
                              • Bug Fixing for ColorScale (favorites)
                              • fredo6F
                                NEW RELEASE: LibFredo6 v15.8d - 01 Feb 26
                                LibFredo6 15.8d is a maintenance release. It includes changes related to:
                                • Bug Fixing for Animator and other plugins
                                  SunnyGee2017
                                  Sketchup 2024 (24.0.553 64-Bit) crashes constantly when I use Rounded Corner or Joint Push/Pull. I have already installed the latest lib (15.8d) and updated all drivers (Radeon RX550).
                                  TIGT fredo6F 2 Replies Last reply
                                    TIG Moderator @SunnyGee2017
                                    @SunnyGee2017
                                    I think @fredo6 will need more details before he can fully look into the cause...
                                    e.g.
                                    Are there any error messages in the Ruby Console or message-boxes ?
                                    What kind of 'crash' is it ?
                                    If it's a BugSplat then what are its details, and have you send these reports into SketchUp ?
                                    S 1 Reply Last reply
                                      SunnyGee2017 @TIG
                                      @TIG It just freezes. I can still move the mouse, but nothing else works. I have to kill the app with the task manager and restart it. It only happens with Fredo plugins. All others work well.
                                      TIGT 1 Reply Last reply
                                        @SunnyGee2017
                                        Thanks, that might be helpful...
                                        Now up to @fredo6
                                        • fredo6F
                                          fredo6 @SunnyGee2017
                                          @SunnyGee2017
                                          Can also invoke menu Window > LibFredo6 Settings.... > Fredo6 Plugin Information... and copy/paste here the content of the Ruby Console.
                                          This will tell me which version of plugins you have.
                                            SunnyGee2017
                                            Fredo6 Plugins Information on 2026-02-08 18:19:24 +0800
                                            • Sketchup: 24.0.553
                                            • LibFredo6: v15.8d
                                            • LibFredo6 Binary loaded
                                            • Sketchucation ExtensionStore: NOT installed
                                            • SCFLicense: NOT installed
                                            • Fredo6 Plugins
                                              Curviloft v2.0a
                                              FredoTools v4.5c
                                              JointPushPull v4.9a
                                              RoundCorner v3.4a
                                            • 107
                                            • 108
                                            • 109
                                            • 110
                                            • 111
                                            • 112
                                            • 113
                                            • 114
                                            • 109 / 114
