    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 593 Posters 13.7m Views 595 Watching
    • alexpacio2013A
      alexpacio2013 @fredo6
      @fredo6 windows 11
      • alexpacio2013A
        alexpacio2013
        I tried deleting all the Fredo plugins and SketchUp starts up normally. If I install only LibFredo, I've tried both the latest version LibFredo6_v15.5a and the previous version LibFredo6_v15.4c and SketchUp crashes on startup.
        Until a few days ago everything was working perfectly without problems, I only installed the new Sketchucation and apart from SketchUp 2026 which shouldn't affect my already installed SketchUp 2025 unless it installs something in common with SketchUp 2025 as well
        • fredo6F
          Do you start Sketchup with the default template or a custom template ?
          What happens if you deinstall Sketchucation and just install LibFredo6 ?
          alexpacio2013A 1 Reply Last reply
          • alexpacio2013A
            alexpacio2013
            Dopo tre giorni passati a Cercare il colpevole l'ho trovato. In pratica sono i plugin di S4U che mandano in crash sketchup in quanto vanno in conflitto con Fredolib.
            • alexpacio2013A
              @fredo6 After three days of work to figure out what was causing SketchUp to crash, I discovered that there's an incompatibility between the S4U plugins and the new Fredo libraries. Now I have the 2026 version working perfectly.
              • F
                fizaharon
                it was said that the license expired huhu
                TIGT 1 Reply Last reply
                  TIG Moderator @fizaharon
                  @fizaharon
                  LibFredo6 doesn't need a license.
                  What's the message about ?
                  Are you using an extensions that needs a license and it's reporting the trial period has expired ?
                  If so license it, or continue this report in that extension's forum-thread, not here.
                  • fredo6F
                    NEW RELEASE: LibFredo6 v15.6a - 26 Nov 25
                    LibFredo6 15.6a is a major release. It includes changes related to:
                    • Full and future compatibility with SU2026
                    • Other bug Fixing and technical adjustments
                    • fredo6F
                      NEW RELEASE: LibFredo6 v15.6b - 02 Dec 25
                      LibFredo6 15.6b is a minor release. It includes changes related to:
                      • Preparation for future plugin
                      • fredo6F
                        NEW RELEASE: LibFredo6 v15.6c - 10 Dec 25
                        LibFredo6 15.6c is a minor release. It includes changes related to:
                        • Full compatibility with SU2026.1
                        1 Reply Last reply πŸ‘
                        • fredo6F
                          NEW RELEASE: LibFredo6 v15.7a - 26 Dec 25
                          LibFredo6 15.7a is a major release. It includes changes related to:
                          • New plugin: FredoSection v1.3a
                          • fredo6F
                            NEW RELEASE: LibFredo6 v15.7b - 02 Jan 26
                            LibFredo6 15.7b is a major release. It includes changes related to:
                            • Bug Fixing and technical adjustments
                            • fredo6F
                              NEW RELEASE: LibFredo6 v15.8a - 09 Jan 26
                              LibFredo6 15.8a is a major release. It includes changes related to:
                              • Bug Fixing for Animator
                              • Evolutions for FredoSection v1.4a
                              • panixiaP
                                panixia
                                Hi Fredo, today I updated libfredo to the last version and I just discovered that it broke LOTT on Sketchup 2021.
                                The plugin is still working, but is not possible to edit and create custom toolbars and palettes anymore.
                                I can just use the already existing ones.
                                • fredo6F
                                  Do you get errors in the Ruby console ?
                                  • panixiaP
                                    panixia
                                    No, I don't.
                                    All I can say is that if I try to drag a new icon into an existing toolbar, it doesn't add to it.
                                    I can create a new toolbar, but again, I can't populate it, if I drag icons on the new toolbar nothing happens.
                                    I'm pretty sure that the problem is related to libfredo6, because if I remove it and load an older version, everything works as intended.
                                    • fredo6F
                                      @panixia
                                      which version of LOTT do you run?
                                      panixiaP 1 Reply Last reply
                                      • fredo6F
                                        NEW RELEASE: LibFredo6 v15.8b - 12 Jan 26
                                        LibFredo6 15.8b is a maintenance release. It includes changes related to:
                                        • Bug Fixing for picking tools
                                        • Evolutions for Axyz
                                        • panixiaP
                                          panixia @fredo6
                                          @fredo6 LOTT v2.6a - 31 Oct 23
                                          I never updated it, because I understood that you had to remove features in latest versions, so I followed the general rule "If ain't broke don't fix it".. should I update?
                                          • fredo6F
                                            NEW RELEASE: LibFredo6 v15.8c - 28 Jan 26
                                            LibFredo6 15.8c is a maintenance release. It includes changes related to:
                                            • Bug Fixing for ColorScale (favorites)
                                            • 107
                                            • 108
                                            • 109
                                            • 110
                                            • 111
                                            • 115
                                            • 116
                                            • 109 / 116
