    [Plugin Library] LibFredo6
    2.2k Posts 583 Posters 7.7m Views 585 Watching
    • U Offline
      unit611 @TIG
      @TIG
      I tried uninstalling and reinstalling sketchup, but it seems like I should try again with deleting every sketchup-related files I can get my hands on. Maybe then I should try as you suggested.
      On the other hand, is a pop-up window saying "B03" also an error?
      Rich O BrienR TIGT 2 Replies Last reply Reply Quote 0
        Rich O Brien Moderator @unit611
        @unit611 said in [Plugin Library] LibFredo6 - v14.6a - 18 Sep 24:
        @TIG
        Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
          TIG Moderator @unit611
          @unit611
          I did not tell you to uninstall SketchUp - a simple 'Repair' will suffice.
          Do not delete files randomly - it'll break something somewhere.
          When you install SketchUp are you using 'Run as administrator' ?
          The B03 pop up window probably relates to SketchUcation licensing errors.
          After a proper installation AND a validation of the various licenses, there should be no more errors.
          Do as Rich says about outputting your SCF settings - doing it before AND after the fixes would help...
          • U Offline
            unit611 @TIG
            @TIG
            I did what Rich-O-Brien said, running th repair as administrator, with the sketchup closed. But nothing's changed. It keeps showing B03 when I first click on "activate license", and A04 when I apply my license file, which is in my "C:-users-profile name-desktop" route.
            Has it got to do with me recently changing the PC's name? I've been using the rubies for a while before I changed my desktop's name in the windows system setting.
            TIGT 1 Reply Last reply Reply Quote 0
              @unit611
              Giving us all of the info is helpful - not in dribs-and-drabs...
              The A04 error tells us that the license signature file is somehow incorrect - i.e. not [necessarily] the license file itself
              If you have changed your PC name you do need to delete your signature file and redo things, so that the validations then point to the correct signature file.
              Changing your PC's name [or Windows user-name] can also cause weird issues, if you have not followed the naming conventions - e.g. use only ASCII letters and numbers, with a limited number of other punctuation characters... there are already threads about this...
              W 2 Replies Last reply Reply Quote 0
              • W Offline
                wskim Newcomers @TIG
                @TIG
                Sorry about that I'll try as you say
                • W Offline
                  @TIG
                  I changed my PC name back to english only and it worked. I guess it was because I used non-conventional letters, as you said.
                  thanks for all the help
                  • E Offline
                    erikcoleman1992
                    Hello,
                    I am currently trying to install Round corner and it says I need to update to fred06 v14.6. do I have to uninstall the old version to update to the new one or is there an easier way?? or am I missing something completely!?
                    any information would be appreciated trying to do a school project rn and i need that bevel tool!
                      Rich O Brien Moderator @erikcoleman1992
                      @erikcoleman1992 Install Sketchucation Tools 4.4.1
                      Sketchucation Tools | SketchUcation
                      (sketchucation.com)
                      Then use that to install/update extensions.
                      Restart SketchUp to complete installations fully.
                      Fredo's extension require Libfredo to fully function
                      • I Offline
                        IsaiARQJ
                        Hola, quiero pagar la licencia ara uso del Lib Fredo6 perpetuo pero no encuentro la forma ni está claro como hacer el pago de la licencia. Me pueden resolver el problema ?
                          TIG Moderator @IsaiARQJ
                          @IsaiARQJ
                          LibFredo6 is a free library used by many of his extensions - some of those are paid.
                          So you do need alicense for that library.
                          LibFredo6 es una colección gratuita que utilizan muchas de sus extensiones; algunas de ellas son de pago.
                          Por lo tanto, necesitas una licencia para esa biblioteca.
                          • N Offline
                            natas_ha
                            I bought the licence and installed the rbz file but nothing is happening. When I open Sketchup it constantly telling me that I need to install the LibFredo plug in but I already did it. How to continue with this?
                              Rich O Brien Moderator @natas_ha
                              @natas_ha
                              Libfredo is a helper library for many of Fredo's other extensions. On its own it serves no real purpose
                                TIG Moderator @natas_ha
                                @natas_ha
                                Which of Fredo's extensions did you license ?
                                Do you have the latest version of his helper extension LibFredo6 installed ?
                                Did you restart to sync everything ?
                                Also do you also have the latest version of the SketchUcation tools installed - for the licensing...
                                If none of this helps repost and someone will ask you for more details...
                                N 1 Reply Last reply Reply Quote 0
                                • N Offline
                                  natas_ha @TIG
                                  @TIG FredoCorner_v2.7a this extension and I bought the Perpetual licence. I installed the rbz file and nothing is happening. It gives me constantly this:Screenshot 2024-11-08 150415.jpg
                                    Dave R @natas_ha
                                    @natas_ha are you sure you bought the license for FredoCorner and not RoundCorner? Many people have gotten confused and tried to use the license for one on the other. They are different extensions and require different licenses.
                                    Did you install LibFredo6 using the Sketchucation ExtensionStore and then restart SketchUp?
                                    • fredo6F Offline
                                      fredo6
                                      NEW RELEASE: LibFredo6 v14.7a - 09 Nov 24
                                      LibFredo6 14.7a is a major release. It includes changes related to:
                                      • ThruPaint v2.8a
                                      • New plugins
                                      • Future compatibility
                                      • Bug Fixing
                                      Requirements: SU2017 and above
                                      See plugin home page of LibFredo6 for Download of LibFredo6.
                                      Main Post of the LibFredo6 thread
                                      F 1 Reply Last reply Reply Quote 0
                                      • F Offline
                                        FlorinAp @fredo6
                                        @fredo6 This one has at least one bug - doesn't allow Lord of the Toolbars to add/remove icons, neither in the toolbars and neither in palettes.!
                                        Edit: For SU 2023.!
                                        fredo6F 1 Reply Last reply Reply Quote 0
                                        • fredo6F Offline
                                          fredo6 @FlorinAp
                                          @FlorinAp
                                          You are correct. I simply forgot to publish LOTT to adjust with necessary changes in LibFredo6.
                                          LOTT is now published as v2.8a.
                                            a4jp.com
                                            Can you make it so we can add time to the clock? I opened the clock on old projects but I want to add the time I have worked on those files before.
                                            • 102
                                            • 103
                                            • 104
                                            • 105
                                            • 106
                                            • 112
                                            • 113
                                            • 104 / 113
