    [Plugin Library] LibFredo6 - v16.4b - 21 Nov 26
    2.3k Posts 597 Posters 16.1m Views 599 Watching
    • TIGT
      @cemileca said:
      Dear Fredo Curviloft not working in 2015 SU. Please help us
      In Fredo's absence... Have you installed the latest version from RBZ from the PluginStore ?
      http://sketchucation.com/pluginstore?pln=Curviloft
      Have you also installed the latest version of the LibFredo ?
      http://sketchucation.com/pluginstore?pln=LibFredo6
      Have you then restarted SketchUp to effect the updates ?
      If so how is it 'not working' ?
      e.g.
      Not loading ?
      Not functioning as expected ?
      Error messages ?
      etc...
      Help us to help you...
      • C
        cemileca
        You are Super,
        Plugin Working...
        Thank you Very Very much for your attention and interest..
        • S
          SRoland
          Hy
          I install LibFredo 6.6b (SU2015) but not show the toolbar. I set the "Prefered language" EN. On SU toolbars panel not appear Fredo6 toolbar, but install other plugin that immediately appear on toolbar.
          Please help.
          • emnE
            emn
            Sketchup crashes when I use Roundcorner. (I just installed roundcorner)
            Using sketch up pro 2015 on Mac OS 10.9.5. Extentions installed: Mirror_v4.2, Libfredo v6.6b, Roundcorner V2.6a and jbb_layers_panel_16.
            Roundcorner IS working. I'm able to round of corners. When the corners are rounded and I pan my view, (using the middel mouse button) Sketchup crashes.
            Anyone?
            • TIGT
              Have you installed the very latest version of SketchUp v2015 ?
              It did previously have some issues with the MAC update to 'Yosemite'...
              Try disabling the jbb_layers_panel plugin.
              After a restart any improvement ?
              It has observers etc and has been linked to some issues with MACs...
              My Mirror plugin is unlikely to cause issues as it's in its own name-space and only kicks in when it's activate.
              • emnE
                emn
                TIG,
                Removing the layers plugin worked like a charm (so far). I'm amazed how people like you know all this stuff...... I would've never thought of that.
                Thank you so much....
                • emnE
                  emn
                  Oops.... A bit premature.... It still crashes.....
                  • emnE
                    emn
                    Installing the newest sketch up version did the trick.... (again: So far...)
                    • tt_suT
                      tt_su
                      Anyone?
                      Did you submit the BugSplats?
                      If you did - did you enter any details in the report? Description, name or email I can use to look up the crash?
                      • fredo6F
                        fredo6
                        NEW RELEASE: LibFredo6 v6.7a - 25 Feb 15
                        LibFredo6 6.7a is a release mainly for FredoTools::AutoReverseFaces and FredoTools::Convexify, both introduced in FredoTools 2.6
                        See main post of this thread for Download of LibFredo6.
                        Fredo
                        • C
                          coby1012
                          • thomthomT
                            Hi Fredo. Is there any chance that you can mute all that text in the console for your release builds? When I develop I often set the console to upon on startup and it all the output by LibFredo cause a lot of noise.
                            Maybe I suggest that you set that up as a Sketchup.read_default preference that is disabled by default - which can then be enabled by you when you need it for your own debugging?
                            • fredo6F
                              fredo6
                              It would be a bug. There is no need for LibFredo to have traces in the Ruby console.
                              Could you tell me what is output in the console so that I remove the traces
                              Thanks very much
                              Fredo
                              • D
                                driven
                                not sure what TT gets, but I see this on every start-up...
                                (eval):1: warning: already initialized constant Traductor::SU_MAJOR_VERSION /Users/johns_iMac/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:40: warning: previous definition of SU_MAJOR_VERSION was here (eval):1: warning: already initialized constant Traductor::RUN_ON_MAC /Users/johns_iMac/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:39: warning: previous definition of RUN_ON_MAC was here
                                • fredo6F
                                  fredo6
                                  OK. Thanks. Will fix and re-release.
                                  These Ruby warnings are always ennoyng, and none has found a way to get rid of them.
                                  I thought it was some puts forgotten in the code.
                                  Fredo
                                  • D
                                    driven
                                    @fredo6 said:
                                    ...none has found a way to get rid of them.
                                    I used to get them from a few different plugins and adding if not defined? e.g. CAS = @cascade if not defined? CAS, but when looking through you dynamic code, I just couldn't work out where that might be added...
                                    the other way is to load a 'Ruby Console' loader as the last ruby file...
                                    john
                                    • thomthomT
                                      Hmm... I just assumed it was LibFredo.. Might have been Bezier Spline as well. I had to temporarily remove them to do some development, but I'll install again and track down the exact messages.
                                      • fredo6F
                                        fredo6
                                        NEW RELEASE: LibFredo6 v6.7b - 22 Mar 15
                                        LibFredo6 6.7b is a minor releaseremoving some noisy traces at Startup of Sketchup
                                        Fredo
                                        • fredo6F
                                          fredo6
                                          You assumed right!
                                          Actually most noisy traces were coming from BezierSpline, but I removed also two traces in LibFredo6.
                                          So you'll have to upgrade both
                                          • BezierSpline 2.7b
                                          • LibFredo6 6.7b
                                          Fredo
                                          • jiminy-billy-bobJ
                                            jiminy-billy-bob
                                            I still get this :
                                            C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:28: warning: already initialized constant Traductor::LBT__DEF
                                            C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb:31: warning: previous definition of LBT__DEF was here
                                            C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:32: warning: already initialized constant Traductor::VALID_ERROR
                                            C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb:35: warning: previous definition of VALID_ERROR was here
                                            C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:34: warning: already initialized constant Traductor::VALID_MIN
                                            C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb:38: warning: previous definition of VALID_MIN was here
                                            C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:35: warning: already initialized constant Traductor::VALID_MAX
                                            C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb:39: warning: previous definition of VALID_MAX was here
                                            C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:36: warning: already initialized constant Traductor::VALID_PATTERN
                                            C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb:40: warning: previous definition of VALID_PATTERN was here
                                            C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:570: warning: redefining constant Struct::DlgItem
                                            C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:570: warning: already initialized constant Traductor::DialogBox::DlgItem
                                            C:/Users/Marjorie/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/LibTraductor.rb:183: warning: previous definition of DlgItem was here
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 50
                                            • 116
                                            • 117
                                            • 48 / 117
