[Plugin Library] LibFredo6 - v16.4b - 21 Nov 26
@fredo6 ??
@epetit91 it might be that since you are still using SketchUp 2017 you'll need to stop updating.
Again, please report the output of the command menu: Window > LibFredo6 Settings > Fredo6 Plugin Information for Sketchucation Support. Otherwise, there is no way to make any diagnostics.
It also does not work with 16.1. version. Here is my report:
Fredo6 Plugins Information on 2026-10-01 14:52:46 +0200
- Platform: x64-mingw32 - Ruby: 2.2.4
- Sketchup: 17.2.2555
- LibFredo6: v16.1g
- LibFredo6 G6 Binary loaded
- LibFredo6 E6 Binary NOT loaded
- Sketchucation Tools: 5.0.8
- SCFLicense: v7.5a - 80
- Fredo6 Plugins
Curviloft v2.0a - licensed FULL: 262837 - HE1772082497.0K
FredoScale v3.7c
JointPushPull v4.9a - licensed FULL: 263124 - HE1772082497.0K
RoundCorner v3.3a - licensed FULL: 263401 - HE1772082497.0K - SCFLicense directory present
Signature File: 2026-02-26 06:08:17 +0100
Curviloft: 2026-02-26 06:08:26 +0100
JointPushPull: 2026-02-26 10:15:01 +0100
RoundCorner: 2026-03-02 12:08:45 +0100
With version 16.1g, SketchUp crashes whenever I launch any Fredo command.
With version 16.2a/b, nothing happens, regardless of which Fredo command I run.The latest version of LibFredo6 that works without issues :
Fredo6 Plugins Information on 2026-10-01 18:34:24 +0200
- Platform: x86_64-darwin14 - Ruby: 2.2.4
- Sketchup: 17.3.116
- LibFredo6: v16.1a
- LibFredo6 Binary loaded
- SCFLicense: v7.5a - 72
- Fredo6 Plugins
Curviloft v2.0a - licensed FULL: 96723 - DX1670440412.0J
FredoTools v4.5c
JointPushPull v4.9a - licensed FULL: 187883 - DX1670440412.0J
RoundCorner v3.4a - licensed FULL: 106080 - DX1670440412.0J - SCFLicense directory present
Signature File: 2022-12-07 20:13:32 +0100
Curviloft: 2026-09-30 07:52:46 +0200
JointPushPull: 2026-09-30 07:53:08 +0200
RoundCorner: 2026-09-30 07:53:25 +0200
How do you install LibFredo6 (Sketcucation Tools, Extension Manager, manual unzip)?
It seems that the main ruby file (Fredo6_!LibFredo6.rb) is not updated.
Could go to the Plugins directory, erase Fredo6_!LibFredo6.rb and the folder Fredo6_!LibFredo6, and then reinstall LibFredo6 v16.2b to have a clean installation.
@fredo6
I installed it via Extension manager. I try to erase it from Plugins, download it again, install via Extension Manager, but nothing changed. -
Why are you not using the Sketchucation Tool to install it?
@Dave-R
it is the same. When I open Sketchucation Tool, there is just link to Extension Manager. -
The SketchUcation Toolbar == ExtensionStore
If you use the Extensions > SketchUcation submenu it also lists the ExtensionStore, PluginManager and a link to o[en the native Extension Manager.
Are you installing it from an RBZ downloaded from our PluginStore, or from our ExtensionStore dialog that opens from within SketchUp itself ?
That's not been made clear... -
There must be something wrong with your installation or you're looking in the wrong place.
Click on the red button in the Sketchucation Tools toolbar.
What does your post actually mean ?
There is a newer version... -
I am facing issues using Fredo scale plugin and thru paint issues just like before version 16.a but then it resolved and I install new versions of all Fredo plugins avilable on skechucation and Fredo library as well now problem is Fredo plugins are not working properly at all especially Fredo scale and thru paint I have paid licences of both and it is not recognizes the licence on every turning on of my PC as well I tried installing new version of extension store tool as well
Can u please help me or give me RBZ file of libfredo 16.a so that I can use smoothly
I have 4 version installed in my PC 21 24 25 and 26 skechup's -
@Dave-R unfortunately, it does not work for me. I have installed Extensionstore v5.0.8., but I see only button continue, but it not work. I think, there is problem may be with firewall, or something like that, because my PC is in domain, which is not directly on internet. But all other updates are function normally.
NEW RELEASE: LibFredo6 v16.3a - 20 Oct 26
LibFredo6 16.3a is a maintenance release. It includes changes related to:
- Compatibility SU2027
- Bug Fixing
If you use LordOfTheToolbars, please upgrade it to LordOfTheToolbars v4.1a. Otherwise, LOTT will not be activated
Requirements: SU2017 and above
See plugin home page of LibFredo6 for Download of LibFredo6.
NEW RELEASE: LibFredo6 v16.3b - 21 Oct 26
- Fix for FredoTools which may not work with v16.3a
- Bug Fixing
If you use LordOfTheToolbars, please upgrade it to LordOfTheToolbars v4.2a. Otherwise, LOTT will not be activated
@fredo6 Dear fredo6, the new release 16.3b absolutely doesn not work for me. I am so sad.
That's rather vague. Please provide more concise information.
Register LoginAdvertisement
