[Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
@TIG I restored LibFredo 15.8e, and everything is working perfectly again. The problem definitely stems from the latest version, 16.
@TIG To summarize: everything works perfectly up to version 16.1a.
With version 16.1g, SketchUp crashes.
With version 16.2a/b, no plugins work. -
@fredo6 ??
@epetit91 it might be that since you are still using SketchUp 2017 you'll need to stop updating.
Again, please report the output of the command menu: Window > LibFredo6 Settings > Fredo6 Plugin Information for Sketchucation Support. Otherwise, there is no way to make any diagnostics.
It also does not work with 16.1. version. Here is my report:
Fredo6 Plugins Information on 2026-10-01 14:52:46 +0200
- Platform: x64-mingw32 - Ruby: 2.2.4
- Sketchup: 17.2.2555
- LibFredo6: v16.1g
- LibFredo6 G6 Binary loaded
- LibFredo6 E6 Binary NOT loaded
- Sketchucation Tools: 5.0.8
- SCFLicense: v7.5a - 80
- Fredo6 Plugins
Curviloft v2.0a - licensed FULL: 262837 - HE1772082497.0K
FredoScale v3.7c
JointPushPull v4.9a - licensed FULL: 263124 - HE1772082497.0K
RoundCorner v3.3a - licensed FULL: 263401 - HE1772082497.0K - SCFLicense directory present
Signature File: 2026-02-26 06:08:17 +0100
Curviloft: 2026-02-26 06:08:26 +0100
JointPushPull: 2026-02-26 10:15:01 +0100
RoundCorner: 2026-03-02 12:08:45 +0100
With version 16.1g, SketchUp crashes whenever I launch any Fredo command.
With version 16.2a/b, nothing happens, regardless of which Fredo command I run.The latest version of LibFredo6 that works without issues :
Fredo6 Plugins Information on 2026-10-01 18:34:24 +0200
- Platform: x86_64-darwin14 - Ruby: 2.2.4
- Sketchup: 17.3.116
- LibFredo6: v16.1a
- LibFredo6 Binary loaded
- SCFLicense: v7.5a - 72
- Fredo6 Plugins
Curviloft v2.0a - licensed FULL: 96723 - DX1670440412.0J
FredoTools v4.5c
JointPushPull v4.9a - licensed FULL: 187883 - DX1670440412.0J
RoundCorner v3.4a - licensed FULL: 106080 - DX1670440412.0J - SCFLicense directory present
Signature File: 2022-12-07 20:13:32 +0100
Curviloft: 2026-09-30 07:52:46 +0200
JointPushPull: 2026-09-30 07:53:08 +0200
RoundCorner: 2026-09-30 07:53:25 +0200
How do you install LibFredo6 (Sketcucation Tools, Extension Manager, manual unzip)?
It seems that the main ruby file (Fredo6_!LibFredo6.rb) is not updated.
Could go to the Plugins directory, erase Fredo6_!LibFredo6.rb and the folder Fredo6_!LibFredo6, and then reinstall LibFredo6 v16.2b to have a clean installation.
@fredo6
I installed it via Extension manager. I try to erase it from Plugins, download it again, install via Extension Manager, but nothing changed. -
Why are you not using the Sketchucation Tool to install it?
