    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 587 Posters 12.0m Views 589 Watching
    • fredo6F
      When you have issues with the installation of LibFredo6, can you report the utput of the command menu: Window > LibFredo6 Settings > Fredo6 Plugin Information for Sketchucation Support
      This just tells what is your configuration in terms of version installed, Sketchup version, platform, etc...
      Otherwise, it is very difficult to help.
      • E
        epetit91 @TIG
        @TIG said:
        /var/folders/wr/cl77xmh96bbdjh00dl5shws00000gn/T/com.sketchup.SketchUp.2017.eric/Fredo6_LibFredo6_TemporaryFiles
        Yes, I am on Mac (MacOS 10.12.6)
        I have been using Fredo plugins since 2022 and have never encountered a single problem. This issue only appeared after the latest update to FredoLib.
        TThe contents of the /var/folders/wr/cl77xmh96bbdjh00dl5shws00000gn/T/com.sketchup.SketchUp.2017.eric/Fredo6_LibFredo6_TemporaryFiles: folder is as follow :
        drwxr-xr-x 6 eric staff 204 30 sep 08:07 .
        drwxr-xr-x 10 eric staff 340 30 sep 09:01 ..
        drwxr-xr-x 2 eric staff 68 29 sep 21:11 Images
        drwxr-xr-x 2 eric staff 68 29 sep 21:11 LibFredo6_Textures
        drwxr-xr-x 27 eric staff 918 30 sep 08:57 Traces
        -rw-r--r-- 1 eric staff 3988 30 sep 08:57 data6.rb
          @fredo ?
          E 2 Replies Last reply
          • E
            epetit91 @TIG
            @TIG If this can help you, here you will find the data6.rb from the /var/folders/wr/cl77xmh96bbdjh00dl5shws00000gn/T/com.sketchup.SketchUp.2017.eric/Fredo6_LibFredo6_TemporaryFiles folder
            data6.rb
            • E
              epetit91 @TIG
              @TIG I restored LibFredo 15.8e, and everything is working perfectly again. The problem definitely stems from the latest version, 16.
              • E
                epetit91 @TIG
                @TIG To summarize: everything works perfectly up to version 16.1a.
                With version 16.1g, SketchUp crashes.
                With version 16.2a/b, no plugins work.
                Dave RD 1 Reply Last reply
                  @fredo6 ??
                    Dave R @epetit91
                    @epetit91 it might be that since you are still using SketchUp 2017 you'll need to stop updating.
                    • fredo6F
                      Again, please report the output of the command menu: Window > LibFredo6 Settings > Fredo6 Plugin Information for Sketchucation Support. Otherwise, there is no way to make any diagnostics.
                      • B
                        Bublifuk21
                        It also does not work with 16.1. version. Here is my report:
                        Fredo6 Plugins Information on 2026-10-01 14:52:46 +0200
                        • Platform: x64-mingw32 - Ruby: 2.2.4
                        • Sketchup: 17.2.2555
                        • LibFredo6: v16.1g
                        • LibFredo6 G6 Binary loaded
                        • LibFredo6 E6 Binary NOT loaded
                        • Sketchucation Tools: 5.0.8
                        • SCFLicense: v7.5a - 80
                        • Fredo6 Plugins
                          Curviloft v2.0a - licensed FULL: 262837 - HE1772082497.0K
                          FredoScale v3.7c
                          JointPushPull v4.9a - licensed FULL: 263124 - HE1772082497.0K
                          RoundCorner v3.3a - licensed FULL: 263401 - HE1772082497.0K
                          Signature File: 2026-02-26 06:08:17 +0100
                          Curviloft: 2026-02-26 06:08:26 +0100
                          JointPushPull: 2026-02-26 10:15:01 +0100
                          RoundCorner: 2026-03-02 12:08:45 +0100
                        fredo6F 1 Reply Last reply
                        • E
                          epetit91
                          With version 16.1g, SketchUp crashes whenever I launch any Fredo command.
                          With version 16.2a/b, nothing happens, regardless of which Fredo command I run.
                          The latest version of LibFredo6 that works without issues :
                          Fredo6 Plugins Information on 2026-10-01 18:34:24 +0200
                          • Platform: x86_64-darwin14 - Ruby: 2.2.4
                          • Sketchup: 17.3.116
                          • LibFredo6: v16.1a
                          • LibFredo6 Binary loaded
                          • SCFLicense: v7.5a - 72
                          • Fredo6 Plugins
                            Curviloft v2.0a - licensed FULL: 96723 - DX1670440412.0J
                            FredoTools v4.5c
                            JointPushPull v4.9a - licensed FULL: 187883 - DX1670440412.0J
                            RoundCorner v3.4a - licensed FULL: 106080 - DX1670440412.0J
                            Signature File: 2022-12-07 20:13:32 +0100
                            Curviloft: 2026-09-30 07:52:46 +0200
                            JointPushPull: 2026-09-30 07:53:08 +0200
                            RoundCorner: 2026-09-30 07:53:25 +0200
                          • fredo6F
                            fredo6 @Bublifuk21
                            @Bublifuk21
                            How do you install LibFredo6 (Sketcucation Tools, Extension Manager, manual unzip)?
                            It seems that the main ruby file (Fredo6_!LibFredo6.rb) is not updated.
                            Could go to the Plugins directory, erase Fredo6_!LibFredo6.rb and the folder Fredo6_!LibFredo6, and then reinstall LibFredo6 v16.2b to have a clean installation.
                            B 1 Reply Last reply
                            • B
                              Bublifuk21 @fredo6
                              @fredo6
                              I installed it via Extension manager. I try to erase it from Plugins, download it again, install via Extension Manager, but nothing changed.
                                Dave R @Bublifuk21
                                Why are you not using the Sketchucation Tool to install it?
                                • B
                                  Bublifuk21 @Dave R
                                  @Dave-R
                                  it is the same. When I open Sketchucation Tool, there is just link to Extension Manager.
                                    The SketchUcation Toolbar == ExtensionStore
                                    If you use the Extensions > SketchUcation submenu it also lists the ExtensionStore, PluginManager and a link to o[en the native Extension Manager.
                                    Are you installing it from an RBZ downloaded from our PluginStore, or from our ExtensionStore dialog that opens from within SketchUp itself ?
                                    That's not been made clear...
                                      Dave R @Bublifuk21
                                      There must be something wrong with your installation or you're looking in the wrong place.
                                      Click on the red button in the Sketchucation Tools toolbar.
                                        DSABRERA Newcomers @fredo6
                                        @fredo6 said:
                                        LibFredo6 v16.1g
                                        TIGT 1 Reply Last reply
                                          TIG Moderator @DSABRERA
                                          @DSABRERA
                                          What does your post actually mean ?
                                          There is a newer version...
                                          • B
                                            Bajwa
                                            I am facing issues using Fredo scale plugin and thru paint issues just like before version 16.a but then it resolved and I install new versions of all Fredo plugins avilable on skechucation and Fredo library as well now problem is Fredo plugins are not working properly at all especially Fredo scale and thru paint I have paid licences of both and it is not recognizes the licence on every turning on of my PC as well I tried installing new version of extension store tool as well
                                            Can u please help me or give me RBZ file of libfredo 16.a so that I can use smoothly
                                            I have 4 version installed in my PC 21 24 25 and 26 skechup's
                                            • 110
                                            • 111
                                            • 112
                                            • 113
                                            • 114
                                            • 114 / 114
