    New API doc - typos and questions
    370 Posts 35 Posters 290.9k Views 35 Watching
    • scottliningerS Offline
      scottlininger
      Self note: need to add an explanation of how add_face works in relation to which "side" of the face is inside vs. outside, and document the exception where faces drawn at z=0 are always drawn with inside facing upward.
      πŸ˜„
      -Scott Lininger
      • Scott Lininger
        SketchUp Software Engineer
        Have you visited the Ruby API Docs?
        scottlininger
        From Didier's post:
        301 Moved Permanently
        (www.sketchucation.com)
        Need to add an FAQ for getting to installation directory of SU, for folks trying to build installers (and find out a mac equivalent.)
        • Scott Lininger
          avariant
          BoundingBox.valid?
          text says
          status
              true if the bounding box is valid (not empty), false if it is not valid (empty)
          but the code example has it exactly the opposite:
           bbox = Sketchup.active_model.bounds
           status = bbox.valid?
           if (status)
             # If true, bounding box is empty.
           else
             # If false, bounding box contains entities.
          • Chris FullmerC Offline
            The introduction to RenderingOptions class states:
            The majority of the rendering information returned exists in the Model Info > Display section of SketchUp.
            There is no longer a Model Info > Distplay section of SketchUp. I suppose it should say its in the styles inspector or something like that.
            http://code.google.com/apis/sketchup/docs/ourdoc/renderingoptions.html#introduction
            Also, the API doesn't list these:
            DisplayQueWidth
            DisplayDims
            DisplaySketchAxes
            DisplayText
            DisplayWatermarks
            DrawDepthQue
            DrawLineEnds
            DrawProfilesOnly
            DrawUnderground
            EdgeType
            FogEndDist*- listed as FogEnd in the API*
            FogStartDist - listed as FogStart in the API
            HideConstructionGeometry
            LineEndWidth
            LockedColor
            SectionTransparencyMode
            ShowViewName
            And the API lists these which don't appear to be valid:
            DisplayFogEdges
            FogDensity
            FogEnd - appears to actually be FogEndDist
            FogStart*- appears to actually be FogStartDist*
            FogType
            I tried to be thorough, but perhaps I missed something. It might not be bad to double check my work πŸ˜„
            Chris
            All my Plugins I've written
              http://code.google.com/apis/sketchup/docs/ourdoc/tool.html#onReturn
              the onReturn method is showing an example for onMouseLeave
                http://code.google.com/apis/sketchup/docs/ourdoc/view.html#zoom_extents
                Does not give an example of view.zoom_extents. It gives an example of view.zoom
                  ModelObserver.onExplode
                  http://code.google.com/apis/sketchup/docs/ourdoc/modelobserver.html#onExplode
                  The onExplode method is invoked whenever a component anywhere in this model is exploded. This is an easier way to watch explode events vs. attaching an InstanceObserver to every instance in the model.
                  The docs in InstanceObserver http://code.google.com/apis/sketchup/docs/ourdoc/instanceobserver.html doesn't mention any explode event. All though, I imagine there used to be. ModelObserver.onExplode is new to SU7, and I'm sure there was an explode related event in SU6. But it's MIA atm.
                    Face.position_material
                    http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/face.html#position_material
                    Doesn't explain the difference between using 2,4,6 or 8 points.
                      Vector3d.samedirection?
                      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/vector3d.html#samedirection?
                      vector = Geom::Vector3d.new 0,0,1
                      vector2 = Geom::Vector3d.new 0,1,0
                      status = vector.sime_direction? vector2
                        Face.mesh
                        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/face.html#mesh
                        The mesh method creates a polygon mesh that represents the face. See the PolygonMesh class for more information.
                        Valid flags are:
                        * 0: Include PolygonMeshPoints,
                        * 1: Include PolygonMeshUVQFront,
                        * 2: Include PolygonMeshUVQBack,
                        * 4: Include PolygonMeshNormals.
                        Add these numbers together to combine flags. A value of 5 will include all flags, for example.
                        No example given.
                          UVHelper.get_front_UVQ UVHelper.get_back_UVQ
                          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/uvhelper.html
                          a Point3d containing the UV coordinates where the X value is the U value, the Y value is the V value and the Z value is a Q value (which is not used).
                          I does appear that the Q value is used. At least when you have a warped texture. (Texture mapped not as a rectangle or parallelogram.) See this thread for further details and sample data: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=19041
                            And I'd also wish there was info about projected textures.
                              http://code.google.com/apis/sketchup/docs/ourdoc/entities.html#add_curve
                              the .add_curve method says it returns a Curve object. It does not. It returns an array of edges.
                              I would prefer that it returned the curve object. But that might break the backward compatibility if other scripts have had to work around this?
                              Chris
                                http://code.google.com/apis/sketchup/docs/ourdoc/webdialog.html#introduction
                                The Webdialog intro suggests using UI.getURL for opening a basic webpage instead of webdialogs. But there is no getURL method. It should be UI.openURL.
                                  Jim
                                  UI.inspector_names and UI.show_inspector missing "EntityInfo" Dialog.
                                  UI.inspector_names
                                  ["Materials", "Components", "Styles", "Scenes", "Shadows", "Layers", "SoftenEdges", "Outliner", "Instructor", "Fog", "MatchPhoto"]
                                    Vector3d.*
                                    http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#*
                                    The example never displays the * method.
                                    Also, for all the manual examples, such as the Vector methods: Vector3d.*, Vector3d.+, Vector3d.-, Vector3d.< It would be nice if they also said the result of the method.
                                    Such as the .* method would then be:
                                    vector = Geom;;Vector3d.new 1,0,0
                                    vector2 = Geom;;Vector3d.new 0,1,0
                                    vector3 = vector * vector2 # Returns [0,0,1]
                                    Seeing the resulting value helps in understanding what it does.
                                      Face.plane
                                      http://code.google.com/apis/sketchup/docs/ourdoc/face.html#plane
                                      The plane method is used to retrieve the plane of the face. See the Array class for information on how planes are stored.
                                      It's unclear where this information is. I don't see it.
                                      • daikuD Offline
                                        daiku
                                        @thomthom said:
                                        Face.plane
                                        From the Geom module:
                                        The plane is returned as an Array of 4 numbers which are the coefficients of the plane equation Ax + By + Cz + D = 0.
                                        Along with this helpful tidbit:
                                        NOTE: Lines and Planes are infinite. There are several good books on 3D math if you are new to the concepts of a line, plane, and vector.
                                        But if you go back to your high-school geometry text book (or google "plane equation") you'll find something like this:
                                        [a,b,c] will give a normal vector to the plane, and the normal distance from the origin is given by d / sqrt( a^2 + b^2 +c^2)
                                        Clark Bremer
                                        http://www.northernlightstimberframing.com
                                          Ah, it referred to the wrong module.
                                            Tool.onSetCursor
                                            http://code.google.com/apis/sketchup/docs/ourdoc/tool.html#onSetCursor
                                            It says that it returns the view as an argument. When I do that I get an wrong number of arguments(0 for 1) error. When I leave the argument out everything works.
                                            Another note;
                                            The onSetCursor method is called by SketchUp when the tool wants to set the cursor. If your tool needs to have more than one cursor, then you will need to implement this method, but if it only has one you can set the cursor in the activate method.
                                            It says that UI.set_cursor(id) can be called from the activate method of the tool if you only have one cursor. When I try that the cursor briefly flickers then reverts back to the default arrow.
                                            • 6
                                            • 7
                                            • 18
                                            • 19
                                            • 5 / 19
