    New API doc - typos and questions
    370 Posts 35 Posters 355.3k Views 35 Watching
      avariant
      BoundingBox.valid?
      text says
      status
          true if the bounding box is valid (not empty), false if it is not valid (empty)
      but the code example has it exactly the opposite:
       bbox = Sketchup.active_model.bounds
       status = bbox.valid?
       if (status)
         # If true, bounding box is empty.
       else
         # If false, bounding box contains entities.
      • Chris FullmerC
        The introduction to RenderingOptions class states:
        The majority of the rendering information returned exists in the Model Info > Display section of SketchUp.
        There is no longer a Model Info > Distplay section of SketchUp. I suppose it should say its in the styles inspector or something like that.
        Error 404 (Not Found)!!1
        (code.google.com)
        Also, the API doesn't list these:
        DisplayQueWidth
        DisplayDims
        DisplaySketchAxes
        DisplayText
        DisplayWatermarks
        DrawDepthQue
        DrawLineEnds
        DrawProfilesOnly
        DrawUnderground
        EdgeType
        FogEndDist*- listed as FogEnd in the API*
        FogStartDist - listed as FogStart in the API
        HideConstructionGeometry
        LineEndWidth
        LockedColor
        SectionTransparencyMode
        ShowViewName
        And the API lists these which don't appear to be valid:
        DisplayFogEdges
        FogDensity
        FogEnd - appears to actually be FogEndDist
        FogStart*- appears to actually be FogStartDist*
        FogType
        I tried to be thorough, but perhaps I missed something. It might not be bad to double check my work πŸ˜„
        • Chris FullmerC
          (code.google.com)
          the onReturn method is showing an example for onMouseLeave
          • Chris FullmerC
            (code.google.com)
            Does not give an example of view.zoom_extents. It gives an example of view.zoom
              ModelObserver.onExplode
              http://code.google.com/apis/sketchup/docs/ourdoc/modelobserver.html#onExplode
              The onExplode method is invoked whenever a component anywhere in this model is exploded. This is an easier way to watch explode events vs. attaching an InstanceObserver to every instance in the model.
              The docs in InstanceObserver http://code.google.com/apis/sketchup/docs/ourdoc/instanceobserver.html doesn't mention any explode event. All though, I imagine there used to be. ModelObserver.onExplode is new to SU7, and I'm sure there was an explode related event in SU6. But it's MIA atm.
                Face.position_material
                http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/face.html#position_material
                Doesn't explain the difference between using 2,4,6 or 8 points.
                  Vector3d.samedirection?
                  http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/vector3d.html#samedirection?
                  vector = Geom::Vector3d.new 0,0,1
                  vector2 = Geom::Vector3d.new 0,1,0
                  status = vector.sime_direction? vector2
                    Face.mesh
                    http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/face.html#mesh
                    The mesh method creates a polygon mesh that represents the face. See the PolygonMesh class for more information.
                    Valid flags are:
                    * 0: Include PolygonMeshPoints,
                    * 1: Include PolygonMeshUVQFront,
                    * 2: Include PolygonMeshUVQBack,
                    * 4: Include PolygonMeshNormals.
                    Add these numbers together to combine flags. A value of 5 will include all flags, for example.
                    No example given.
                      UVHelper.get_front_UVQ UVHelper.get_back_UVQ
                      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/uvhelper.html
                      a Point3d containing the UV coordinates where the X value is the U value, the Y value is the V value and the Z value is a Q value (which is not used).
                      I does appear that the Q value is used. At least when you have a warped texture. (Texture mapped not as a rectangle or parallelogram.) See this thread for further details and sample data: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=19041
                        And I'd also wish there was info about projected textures.
                        • Chris FullmerC
                          (code.google.com)
                          the .add_curve method says it returns a Curve object. It does not. It returns an array of edges.
                          I would prefer that it returned the curve object. But that might break the backward compatibility if other scripts have had to work around this?
                          • Chris FullmerC
                            (code.google.com)
                            The Webdialog intro suggests using UI.getURL for opening a basic webpage instead of webdialogs. But there is no getURL method. It should be UI.openURL.
                              Jim
                              UI.inspector_names and UI.show_inspector missing "EntityInfo" Dialog.
                              UI.inspector_names
                              ["Materials", "Components", "Styles", "Scenes", "Shadows", "Layers", "SoftenEdges", "Outliner", "Instructor", "Fog", "MatchPhoto"]
                                Vector3d.*
                                http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#*
                                The example never displays the * method.
                                Also, for all the manual examples, such as the Vector methods: Vector3d.*, Vector3d.+, Vector3d.-, Vector3d.< It would be nice if they also said the result of the method.
                                Such as the .* method would then be:
                                vector = Geom;;Vector3d.new 1,0,0
                                vector2 = Geom;;Vector3d.new 0,1,0
                                vector3 = vector * vector2 # Returns [0,0,1]
                                Seeing the resulting value helps in understanding what it does.
                                  Face.plane
                                  http://code.google.com/apis/sketchup/docs/ourdoc/face.html#plane
                                  The plane method is used to retrieve the plane of the face. See the Array class for information on how planes are stored.
                                  It's unclear where this information is. I don't see it.
                                  • daikuD
                                    daiku
                                    @thomthom said:
                                    Face.plane
                                    From the Geom module:
                                    The plane is returned as an Array of 4 numbers which are the coefficients of the plane equation Ax + By + Cz + D = 0.
                                    Along with this helpful tidbit:
                                    NOTE: Lines and Planes are infinite. There are several good books on 3D math if you are new to the concepts of a line, plane, and vector.
                                    But if you go back to your high-school geometry text book (or google "plane equation") you'll find something like this:
                                    [a,b,c] will give a normal vector to the plane, and the normal distance from the origin is given by d / sqrt( a^2 + b^2 +c^2)
                                    Clark Bremer
                                    http://www.northernlightstimberframing.com
                                      Ah, it referred to the wrong module.
                                        Tool.onSetCursor
                                        http://code.google.com/apis/sketchup/docs/ourdoc/tool.html#onSetCursor
                                        It says that it returns the view as an argument. When I do that I get an wrong number of arguments(0 for 1) error. When I leave the argument out everything works.
                                        Another note;
                                        The onSetCursor method is called by SketchUp when the tool wants to set the cursor. If your tool needs to have more than one cursor, then you will need to implement this method, but if it only has one you can set the cursor in the activate method.
                                        It says that UI.set_cursor(id) can be called from the activate method of the tool if you only have one cursor. When I try that the cursor briefly flickers then reverts back to the default arrow.
                                        • daikuD
                                          daiku
                                          I just want to take a second to thank Thomas for his diligence in finding and documenting these inconsistencies. It's really going to make life easier for a lot of folks. CB.
                                          Clark Bremer
                                            Just noticed that 'behavior' has some typos in the examples - '.xxx =' rather than '.xxx=' ...
                                            behavior.always_face_camera = NOT behavior.always_face_camera=
                                            behavior.cuts_opening = NOT behavior.cuts_opening=
                                            behavior.is2d = NOT behavior.is2d=
                                            behavior.no_scale_mask = NOT behavior.no_scale_mask=
                                            behavior.shadows_face_sun = NOT behavior.shadows_face_sun=
                                            behavior.snapto = NOT behavior.snapto=
                                            • 18
                                            • 19
                                            • 5 / 19
