    New API doc - typos and questions
    370 Posts 35 Posters 291.3k Views 35 Watching
      Hi Scott, I have sent you a PM, too, about it. The mods have also be informed to welcome you in the team.
      πŸ˜†
        @thomthom said:
        ToolObservers? How are they related to onClose and onOpen?
        I meant to say, InstanceObservers. πŸ˜›
        In any case, they fire fine for me.
        Hmm... When I tried to implement it in my plugin the onClose never fired. I also tried Jim's observer test script: http://sketchuptips.blogspot.com/2008/03/plugin-oberver-tests.html - and that never fired either. Could you post a working sample where onClose fires? (The onOpen always works though.)
        • scottliningerS Offline
          scottlininger
          Give this a go... Could be that we're seeing a sneaky bug...
          class MyInstanceObserver < Sketchup;;InstanceObserver
             def onOpen(instance)
               UI.messagebox("onOpen; " + instance.to_s)
             def onClose(instance)
               UI.messagebox("onClose; " + instance.to_s)
          model = Sketchup.active_model
          model.definitions[0].instances[0].add_observer(MyInstanceObserver.new)
          • Scott Lininger
            SketchUp Software Engineer
            Have you visited the Ruby API Docs?
            Nopes. Doesn't work.
              Jim
              Works for me...
                Scott just found out that it works if the script loads when SU loads. But if you put it a subfolder for instance, and then manually load it, it won't work.
                Jim's Observer tests never fire the event in SU7. However, in SU6 it works fine.
                  Jim
                  Just wondering if you have Dynamic Components on, and what happens if you turn them off?
                    Well I'll be! After disabling DCs the onClose even works!
                    btw, the DefinitionObserver works in SU6. But not SU7. Noticed that when I tested this observer in SU6.
                      scottlininger
                      Self note: need to add an explanation of how add_face works in relation to which "side" of the face is inside vs. outside, and document the exception where faces drawn at z=0 are always drawn with inside facing upward.
                      πŸ˜„
                      -Scott Lininger
                      • Scott Lininger
                        scottlininger
                        From Didier's post:
                        301 Moved Permanently
                        (www.sketchucation.com)
                        Need to add an FAQ for getting to installation directory of SU, for folks trying to build installers (and find out a mac equivalent.)
                        • Scott Lininger
                          avariant
                          BoundingBox.valid?
                          text says
                          status
                              true if the bounding box is valid (not empty), false if it is not valid (empty)
                          but the code example has it exactly the opposite:
                           bbox = Sketchup.active_model.bounds
                           status = bbox.valid?
                           if (status)
                             # If true, bounding box is empty.
                           else
                             # If false, bounding box contains entities.
                          • Chris FullmerC Offline
                            The introduction to RenderingOptions class states:
                            The majority of the rendering information returned exists in the Model Info > Display section of SketchUp.
                            There is no longer a Model Info > Distplay section of SketchUp. I suppose it should say its in the styles inspector or something like that.
                            http://code.google.com/apis/sketchup/docs/ourdoc/renderingoptions.html#introduction
                            Also, the API doesn't list these:
                            DisplayQueWidth
                            DisplayDims
                            DisplaySketchAxes
                            DisplayText
                            DisplayWatermarks
                            DrawDepthQue
                            DrawLineEnds
                            DrawProfilesOnly
                            DrawUnderground
                            EdgeType
                            FogEndDist*- listed as FogEnd in the API*
                            FogStartDist - listed as FogStart in the API
                            HideConstructionGeometry
                            LineEndWidth
                            LockedColor
                            SectionTransparencyMode
                            ShowViewName
                            And the API lists these which don't appear to be valid:
                            DisplayFogEdges
                            FogDensity
                            FogEnd - appears to actually be FogEndDist
                            FogStart*- appears to actually be FogStartDist*
                            FogType
                            I tried to be thorough, but perhaps I missed something. It might not be bad to double check my work πŸ˜„
                              http://code.google.com/apis/sketchup/docs/ourdoc/tool.html#onReturn
                              the onReturn method is showing an example for onMouseLeave
                                http://code.google.com/apis/sketchup/docs/ourdoc/view.html#zoom_extents
                                Does not give an example of view.zoom_extents. It gives an example of view.zoom
                                  ModelObserver.onExplode
                                  http://code.google.com/apis/sketchup/docs/ourdoc/modelobserver.html#onExplode
                                  The onExplode method is invoked whenever a component anywhere in this model is exploded. This is an easier way to watch explode events vs. attaching an InstanceObserver to every instance in the model.
                                  The docs in InstanceObserver http://code.google.com/apis/sketchup/docs/ourdoc/instanceobserver.html doesn't mention any explode event. All though, I imagine there used to be. ModelObserver.onExplode is new to SU7, and I'm sure there was an explode related event in SU6. But it's MIA atm.
                                    Face.position_material
                                    http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/face.html#position_material
                                    Doesn't explain the difference between using 2,4,6 or 8 points.
                                      Vector3d.samedirection?
                                      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/vector3d.html#samedirection?
                                      vector = Geom::Vector3d.new 0,0,1
                                      vector2 = Geom::Vector3d.new 0,1,0
                                      status = vector.sime_direction? vector2
                                        Face.mesh
                                        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/face.html#mesh
                                        The mesh method creates a polygon mesh that represents the face. See the PolygonMesh class for more information.
                                        Valid flags are:
                                        * 0: Include PolygonMeshPoints,
                                        * 1: Include PolygonMeshUVQFront,
                                        * 2: Include PolygonMeshUVQBack,
                                        * 4: Include PolygonMeshNormals.
                                        Add these numbers together to combine flags. A value of 5 will include all flags, for example.
                                        No example given.
                                          UVHelper.get_front_UVQ UVHelper.get_back_UVQ
                                          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/uvhelper.html
                                          a Point3d containing the UV coordinates where the X value is the U value, the Y value is the V value and the Z value is a Q value (which is not used).
                                          I does appear that the Q value is used. At least when you have a warped texture. (Texture mapped not as a rectangle or parallelogram.) See this thread for further details and sample data: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=19041
                                            And I'd also wish there was info about projected textures.
                                            • 18
                                            • 19
                                            • 5 / 19
