    New API doc - typos and questions
    370 Posts 35 Posters 371.9k Views 35 Watching
      @jim said:
      Just wondering if you have Dynamic Components on, and what happens if you turn them off?
      Well I'll be! After disabling DCs the onClose even works!
      btw, the DefinitionObserver works in SU6. But not SU7. Noticed that when I tested this observer in SU6.
      • scottliningerS
        scottlininger
        Self note: need to add an explanation of how add_face works in relation to which "side" of the face is inside vs. outside, and document the exception where faces drawn at z=0 are always drawn with inside facing upward.
        πŸ˜„
        -Scott Lininger
        • Scott Lininger
          SketchUp Software Engineer
          Have you visited the Ruby API Docs?
        • scottliningerS
          scottlininger
          From Didier's post:
          404 Not Found
          (www.sketchucation.com)
          Need to add an FAQ for getting to installation directory of SU, for folks trying to build installers (and find out a mac equivalent.)
          • Scott Lininger
            avariant
            BoundingBox.valid?
            text says
            status
                true if the bounding box is valid (not empty), false if it is not valid (empty)
            but the code example has it exactly the opposite:
             bbox = Sketchup.active_model.bounds
             status = bbox.valid?
             if (status)
               # If true, bounding box is empty.
             else
               # If false, bounding box contains entities.
            • Chris FullmerC
              The introduction to RenderingOptions class states:
              The majority of the rendering information returned exists in the Model Info > Display section of SketchUp.
              There is no longer a Model Info > Distplay section of SketchUp. I suppose it should say its in the styles inspector or something like that.
              Error 404 (Not Found)!!1
              (code.google.com)
              Also, the API doesn't list these:
              DisplayQueWidth
              DisplayDims
              DisplaySketchAxes
              DisplayText
              DisplayWatermarks
              DrawDepthQue
              DrawLineEnds
              DrawProfilesOnly
              DrawUnderground
              EdgeType
              FogEndDist*- listed as FogEnd in the API*
              FogStartDist - listed as FogStart in the API
              HideConstructionGeometry
              LineEndWidth
              LockedColor
              SectionTransparencyMode
              ShowViewName
              And the API lists these which don't appear to be valid:
              DisplayFogEdges
              FogDensity
              FogEnd - appears to actually be FogEndDist
              FogStart*- appears to actually be FogStartDist*
              FogType
              I tried to be thorough, but perhaps I missed something. It might not be bad to double check my work πŸ˜„
              • Chris FullmerC
                (code.google.com)
                the onReturn method is showing an example for onMouseLeave
                • Chris FullmerC
                  (code.google.com)
                  Does not give an example of view.zoom_extents. It gives an example of view.zoom
                    ModelObserver.onExplode
                    http://code.google.com/apis/sketchup/docs/ourdoc/modelobserver.html#onExplode
                    The onExplode method is invoked whenever a component anywhere in this model is exploded. This is an easier way to watch explode events vs. attaching an InstanceObserver to every instance in the model.
                    The docs in InstanceObserver http://code.google.com/apis/sketchup/docs/ourdoc/instanceobserver.html doesn't mention any explode event. All though, I imagine there used to be. ModelObserver.onExplode is new to SU7, and I'm sure there was an explode related event in SU6. But it's MIA atm.
                      Face.position_material
                      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/face.html#position_material
                      Doesn't explain the difference between using 2,4,6 or 8 points.
                        Vector3d.samedirection?
                        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/vector3d.html#samedirection?
                        vector = Geom::Vector3d.new 0,0,1
                        vector2 = Geom::Vector3d.new 0,1,0
                        status = vector.sime_direction? vector2
                          Face.mesh
                          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/face.html#mesh
                          The mesh method creates a polygon mesh that represents the face. See the PolygonMesh class for more information.
                          Valid flags are:
                          * 0: Include PolygonMeshPoints,
                          * 1: Include PolygonMeshUVQFront,
                          * 2: Include PolygonMeshUVQBack,
                          * 4: Include PolygonMeshNormals.
                          Add these numbers together to combine flags. A value of 5 will include all flags, for example.
                          No example given.
                            UVHelper.get_front_UVQ UVHelper.get_back_UVQ
                            http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/uvhelper.html
                            a Point3d containing the UV coordinates where the X value is the U value, the Y value is the V value and the Z value is a Q value (which is not used).
                            I does appear that the Q value is used. At least when you have a warped texture. (Texture mapped not as a rectangle or parallelogram.) See this thread for further details and sample data: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=19041
                              And I'd also wish there was info about projected textures.
                              • Chris FullmerC
                                (code.google.com)
                                the .add_curve method says it returns a Curve object. It does not. It returns an array of edges.
                                I would prefer that it returned the curve object. But that might break the backward compatibility if other scripts have had to work around this?
                                • Chris FullmerC
                                  (code.google.com)
                                  The Webdialog intro suggests using UI.getURL for opening a basic webpage instead of webdialogs. But there is no getURL method. It should be UI.openURL.
                                    Jim
                                    UI.inspector_names and UI.show_inspector missing "EntityInfo" Dialog.
                                    UI.inspector_names
                                    ["Materials", "Components", "Styles", "Scenes", "Shadows", "Layers", "SoftenEdges", "Outliner", "Instructor", "Fog", "MatchPhoto"]
                                      Vector3d.*
                                      http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#*
                                      The example never displays the * method.
                                      Also, for all the manual examples, such as the Vector methods: Vector3d.*, Vector3d.+, Vector3d.-, Vector3d.< It would be nice if they also said the result of the method.
                                      Such as the .* method would then be:
                                      vector = Geom;;Vector3d.new 1,0,0
                                      vector2 = Geom;;Vector3d.new 0,1,0
                                      vector3 = vector * vector2 # Returns [0,0,1]
                                      Seeing the resulting value helps in understanding what it does.
                                        Face.plane
                                        http://code.google.com/apis/sketchup/docs/ourdoc/face.html#plane
                                        The plane method is used to retrieve the plane of the face. See the Array class for information on how planes are stored.
                                        It's unclear where this information is. I don't see it.
                                        • daikuD
                                          daiku
                                          @thomthom said:
                                          Face.plane
                                          From the Geom module:
                                          The plane is returned as an Array of 4 numbers which are the coefficients of the plane equation Ax + By + Cz + D = 0.
                                          Along with this helpful tidbit:
                                          NOTE: Lines and Planes are infinite. There are several good books on 3D math if you are new to the concepts of a line, plane, and vector.
                                          But if you go back to your high-school geometry text book (or google "plane equation") you'll find something like this:
                                          [a,b,c] will give a normal vector to the plane, and the normal distance from the origin is given by d / sqrt( a^2 + b^2 +c^2)
                                          Clark Bremer
                                          http://www.northernlightstimberframing.com
                                            Ah, it referred to the wrong module.
                                            • 18
                                            • 19
                                            • 5 / 19
