    New API doc - typos and questions
    370 Posts 35 Posters 310.9k Views 35 Watching
      Jim
      @remus said:
      Jim, is there a way that I could be granted edit rights just to this thread? Then I could add a FIXED note inside the reports as I correct them?
      I'll ask gai if he can make you a mod for the ruby forum πŸ‘
      Scott, there's no way to give edit-rights on a single topic. So you get edit rights to the whole Ruby Forum.
      If you have a list of changes, we can take care of marking them fixed. I'd hate to see you spend time doing it if you have more important work to do.
        Hi Scott, I have sent you a PM, too, about it. The mods have also be informed to welcome you in the team.
        πŸ˜†
          @thomthom said:
          ToolObservers? How are they related to onClose and onOpen?
          I meant to say, InstanceObservers. πŸ˜›
          In any case, they fire fine for me.
          Hmm... When I tried to implement it in my plugin the onClose never fired. I also tried Jim's observer test script: http://sketchuptips.blogspot.com/2008/03/plugin-oberver-tests.html - and that never fired either. Could you post a working sample where onClose fires? (The onOpen always works though.)
          • scottliningerS Offline
            scottlininger
            Give this a go... Could be that we're seeing a sneaky bug...
            class MyInstanceObserver < Sketchup;;InstanceObserver
               def onOpen(instance)
                 UI.messagebox("onOpen; " + instance.to_s)
               def onClose(instance)
                 UI.messagebox("onClose; " + instance.to_s)
            model = Sketchup.active_model
            model.definitions[0].instances[0].add_observer(MyInstanceObserver.new)
            • Scott Lininger
              SketchUp Software Engineer
              Have you visited the Ruby API Docs?
              Nopes. Doesn't work.
                Jim
                Works for me...
                  Scott just found out that it works if the script loads when SU loads. But if you put it a subfolder for instance, and then manually load it, it won't work.
                  Jim's Observer tests never fire the event in SU7. However, in SU6 it works fine.
                    Jim
                    Just wondering if you have Dynamic Components on, and what happens if you turn them off?
                      Well I'll be! After disabling DCs the onClose even works!
                      btw, the DefinitionObserver works in SU6. But not SU7. Noticed that when I tested this observer in SU6.
                        scottlininger
                        Self note: need to add an explanation of how add_face works in relation to which "side" of the face is inside vs. outside, and document the exception where faces drawn at z=0 are always drawn with inside facing upward.
                        πŸ˜„
                        -Scott Lininger
                        • Scott Lininger
                          scottlininger
                          From Didier's post:
                          301 Moved Permanently
                          (www.sketchucation.com)
                          Need to add an FAQ for getting to installation directory of SU, for folks trying to build installers (and find out a mac equivalent.)
                          • Scott Lininger
                            avariant
                            BoundingBox.valid?
                            text says
                            status
                                true if the bounding box is valid (not empty), false if it is not valid (empty)
                            but the code example has it exactly the opposite:
                             bbox = Sketchup.active_model.bounds
                             status = bbox.valid?
                             if (status)
                               # If true, bounding box is empty.
                             else
                               # If false, bounding box contains entities.
                            • Chris FullmerC Offline
                              The introduction to RenderingOptions class states:
                              The majority of the rendering information returned exists in the Model Info > Display section of SketchUp.
                              There is no longer a Model Info > Distplay section of SketchUp. I suppose it should say its in the styles inspector or something like that.
                              http://code.google.com/apis/sketchup/docs/ourdoc/renderingoptions.html#introduction
                              Also, the API doesn't list these:
                              DisplayQueWidth
                              DisplayDims
                              DisplaySketchAxes
                              DisplayText
                              DisplayWatermarks
                              DrawDepthQue
                              DrawLineEnds
                              DrawProfilesOnly
                              DrawUnderground
                              EdgeType
                              FogEndDist*- listed as FogEnd in the API*
                              FogStartDist - listed as FogStart in the API
                              HideConstructionGeometry
                              LineEndWidth
                              LockedColor
                              SectionTransparencyMode
                              ShowViewName
                              And the API lists these which don't appear to be valid:
                              DisplayFogEdges
                              FogDensity
                              FogEnd - appears to actually be FogEndDist
                              FogStart*- appears to actually be FogStartDist*
                              FogType
                              I tried to be thorough, but perhaps I missed something. It might not be bad to double check my work πŸ˜„
                                http://code.google.com/apis/sketchup/docs/ourdoc/tool.html#onReturn
                                the onReturn method is showing an example for onMouseLeave
                                  http://code.google.com/apis/sketchup/docs/ourdoc/view.html#zoom_extents
                                  Does not give an example of view.zoom_extents. It gives an example of view.zoom
                                    ModelObserver.onExplode
                                    http://code.google.com/apis/sketchup/docs/ourdoc/modelobserver.html#onExplode
                                    The onExplode method is invoked whenever a component anywhere in this model is exploded. This is an easier way to watch explode events vs. attaching an InstanceObserver to every instance in the model.
                                    The docs in InstanceObserver http://code.google.com/apis/sketchup/docs/ourdoc/instanceobserver.html doesn't mention any explode event. All though, I imagine there used to be. ModelObserver.onExplode is new to SU7, and I'm sure there was an explode related event in SU6. But it's MIA atm.
                                      Face.position_material
                                      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/face.html#position_material
                                      Doesn't explain the difference between using 2,4,6 or 8 points.
                                        Vector3d.samedirection?
                                        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/vector3d.html#samedirection?
                                        vector = Geom::Vector3d.new 0,0,1
                                        vector2 = Geom::Vector3d.new 0,1,0
                                        status = vector.sime_direction? vector2
                                          Face.mesh
                                          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/face.html#mesh
                                          The mesh method creates a polygon mesh that represents the face. See the PolygonMesh class for more information.
                                          Valid flags are:
                                          * 0: Include PolygonMeshPoints,
                                          * 1: Include PolygonMeshUVQFront,
                                          * 2: Include PolygonMeshUVQBack,
                                          * 4: Include PolygonMeshNormals.
                                          Add these numbers together to combine flags. A value of 5 will include all flags, for example.
                                          No example given.
                                            UVHelper.get_front_UVQ UVHelper.get_back_UVQ
                                            http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/uvhelper.html
                                            a Point3d containing the UV coordinates where the X value is the U value, the Y value is the V value and the Z value is a Q value (which is not used).
                                            I does appear that the Q value is used. At least when you have a warped texture. (Texture mapped not as a rectangle or parallelogram.) See this thread for further details and sample data: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=19041
                                            • 18
                                            • 19
                                            • 5 / 19
