    New API doc - typos and questions
    370 Posts 35 Posters 371.9k Views 35 Watching
      @thomthom said:
      ToolObservers? How are they related to onClose and onOpen?
      I meant to say, InstanceObservers. πŸ˜›
      In any case, they fire fine for me.
      Hmm... When I tried to implement it in my plugin the onClose never fired. I also tried Jim's observer test script: http://sketchuptips.blogspot.com/2008/03/plugin-oberver-tests.html - and that never fired either. Could you post a working sample where onClose fires? (The onOpen always works though.)
      • scottliningerS
        scottlininger
        Give this a go... Could be that we're seeing a sneaky bug...
        class MyInstanceObserver < Sketchup;;InstanceObserver
           def onOpen(instance)
             UI.messagebox("onOpen; " + instance.to_s)
           def onClose(instance)
             UI.messagebox("onClose; " + instance.to_s)
        model = Sketchup.active_model
        model.definitions[0].instances[0].add_observer(MyInstanceObserver.new)
        • Scott Lininger
          SketchUp Software Engineer
          Have you visited the Ruby API Docs?
          Nopes. Doesn't work.
            Jim
            Works for me...
              Scott just found out that it works if the script loads when SU loads. But if you put it a subfolder for instance, and then manually load it, it won't work.
              Jim's Observer tests never fire the event in SU7. However, in SU6 it works fine.
                Jim
                Just wondering if you have Dynamic Components on, and what happens if you turn them off?
                  Well I'll be! After disabling DCs the onClose even works!
                  btw, the DefinitionObserver works in SU6. But not SU7. Noticed that when I tested this observer in SU6.
                  • scottliningerS
                    scottlininger
                    Self note: need to add an explanation of how add_face works in relation to which "side" of the face is inside vs. outside, and document the exception where faces drawn at z=0 are always drawn with inside facing upward.
                    πŸ˜„
                    -Scott Lininger
                    • Scott Lininger
                    • scottliningerS
                      scottlininger
                      From Didier's post:
                      404 Not Found
                      (www.sketchucation.com)
                      Need to add an FAQ for getting to installation directory of SU, for folks trying to build installers (and find out a mac equivalent.)
                      • Scott Lininger
                        avariant
                        BoundingBox.valid?
                        text says
                        status
                            true if the bounding box is valid (not empty), false if it is not valid (empty)
                        but the code example has it exactly the opposite:
                         bbox = Sketchup.active_model.bounds
                         status = bbox.valid?
                         if (status)
                           # If true, bounding box is empty.
                         else
                           # If false, bounding box contains entities.
                        • Chris FullmerC
                          The introduction to RenderingOptions class states:
                          The majority of the rendering information returned exists in the Model Info > Display section of SketchUp.
                          There is no longer a Model Info > Distplay section of SketchUp. I suppose it should say its in the styles inspector or something like that.
                          Error 404 (Not Found)!!1
                          (code.google.com)
                          Also, the API doesn't list these:
                          DisplayQueWidth
                          DisplayDims
                          DisplaySketchAxes
                          DisplayText
                          DisplayWatermarks
                          DrawDepthQue
                          DrawLineEnds
                          DrawProfilesOnly
                          DrawUnderground
                          EdgeType
                          FogEndDist*- listed as FogEnd in the API*
                          FogStartDist - listed as FogStart in the API
                          HideConstructionGeometry
                          LineEndWidth
                          LockedColor
                          SectionTransparencyMode
                          ShowViewName
                          And the API lists these which don't appear to be valid:
                          DisplayFogEdges
                          FogDensity
                          FogEnd - appears to actually be FogEndDist
                          FogStart*- appears to actually be FogStartDist*
                          FogType
                          I tried to be thorough, but perhaps I missed something. It might not be bad to double check my work πŸ˜„
                          • Chris FullmerC
                            (code.google.com)
                            the onReturn method is showing an example for onMouseLeave
                            • Chris FullmerC
                              (code.google.com)
                              Does not give an example of view.zoom_extents. It gives an example of view.zoom
                                ModelObserver.onExplode
                                http://code.google.com/apis/sketchup/docs/ourdoc/modelobserver.html#onExplode
                                The onExplode method is invoked whenever a component anywhere in this model is exploded. This is an easier way to watch explode events vs. attaching an InstanceObserver to every instance in the model.
                                The docs in InstanceObserver http://code.google.com/apis/sketchup/docs/ourdoc/instanceobserver.html doesn't mention any explode event. All though, I imagine there used to be. ModelObserver.onExplode is new to SU7, and I'm sure there was an explode related event in SU6. But it's MIA atm.
                                  Face.position_material
                                  http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/face.html#position_material
                                  Doesn't explain the difference between using 2,4,6 or 8 points.
                                    Vector3d.samedirection?
                                    http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/vector3d.html#samedirection?
                                    vector = Geom::Vector3d.new 0,0,1
                                    vector2 = Geom::Vector3d.new 0,1,0
                                    status = vector.sime_direction? vector2
                                      Face.mesh
                                      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/face.html#mesh
                                      The mesh method creates a polygon mesh that represents the face. See the PolygonMesh class for more information.
                                      Valid flags are:
                                      * 0: Include PolygonMeshPoints,
                                      * 1: Include PolygonMeshUVQFront,
                                      * 2: Include PolygonMeshUVQBack,
                                      * 4: Include PolygonMeshNormals.
                                      Add these numbers together to combine flags. A value of 5 will include all flags, for example.
                                      No example given.
                                        UVHelper.get_front_UVQ UVHelper.get_back_UVQ
                                        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/uvhelper.html
                                        a Point3d containing the UV coordinates where the X value is the U value, the Y value is the V value and the Z value is a Q value (which is not used).
                                        I does appear that the Q value is used. At least when you have a warped texture. (Texture mapped not as a rectangle or parallelogram.) See this thread for further details and sample data: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=19041
                                          And I'd also wish there was info about projected textures.
                                          • Chris FullmerC
                                            (code.google.com)
                                            the .add_curve method says it returns a Curve object. It does not. It returns an array of edges.
                                            I would prefer that it returned the curve object. But that might break the backward compatibility if other scripts have had to work around this?
                                            • 18
                                            • 19
                                            • 5 / 19
