    [Plugin] Recall last tool v1.2
    60 Posts 28 Posters 59.5k Views 28 Watching
    • P Offline
      pecan
      Using the tool name should work:
      def onActiveToolChanged (tools_object, toolname, toolid)
              print tools_object, toolname, toolid
      		@@Matt_Model_Toolid = @@Matt_Model_Toolid2 if @@Matt_Model_Toolid2
      		#@@Matt_Model_Toolid2 = toolid if not([21022,10508].index toolid)
      		@@Matt_Model_Toolid2 = "select#{toolname};";
      		puts "1; #{@@Matt_Model_Toolid} 2; #{@@Matt_Model_Toolid2}"
      • P Offline
        pecan
        > 	end
        Well... almost.
        "selectCameraOrbitTool:" doesnt work.
        It's action name is simply OrbitTool.
        So maybe a hash of returned tool names and the send_action name.
        sendActionToolName = {"CameraOrbitTool", "OrbitTool", } etc.
        Or maybe a hash of just the exceptions.
        Its a shame SU has to be so inconsistent.
        • P Offline
          pecan
          Here's a list of the send_actions and the actual tool name returned by the observer.
          howRubyPanel;
          viewBack;
          viewBottom;
          viewFront;
          viewIso;
          viewLeft;
          viewRight;
          viewTop;
          viewPerspective;
          viewShowAxes;
          viewShowHidden;
          viewZoomExtents;
          viewZoomToSelection;
          viewUndo;
          selectOrbitTool; (CameraOrbitTool)
              ok  selectPositionCameraTool;
          selectDollyTool; (CameraDollyTool
          selectTurnTool;
          selectWalkTool; (CameraWalkTool)
          selectZoomTool; (CameraZoomTool)
          selectFieldOfViewTool; (CameraFOVTool) <=== inconsistency
          selectZoomWindowTool; (CameraZoomWindowTool)
          pageAdd;
          pageDelete;
          pageUpdate;
          pageNext;
          pagePrevious;
          renderWireframe;
          renderHiddenLine;
          renderMonochrome&#058;
          renderShaded;
          renderTextures;
              ok  selectArcTool;
          selectAxisTool; (SketchCSTool)
              ok  selectCircleTool;
              ok selectEraseTool;
              ok  selectFreehandTool;
          selectLineTool; (SketchTool)
              ok  selectMeasureTool;
              ok  selectMoveTool;
              ok  selectOffsetTool;
              ok  selectPaintTool;
          selectPolygonTool; (PolyTool)
              ok  selectProtractorTool;
              ok  selectPushPullTool;
              ok  selectRectangleTool;
              ok  selectRotateTool;
              ok  selectScaleTool;
              ok  selectSectionPlaneTool;
              ok  selectTextTool;
              ok  selectDimensionTool;
              ok  selectExtrudeTool;
              ok  selectSelectionTool;
          editUndo;
          editRedo;
          editHide;
          editUnhide;
          fixNonPlanarFaces;
          axes is returning SketchCSTool
          3d text is returning 3DTextTool
          plugins return RubyTool
          orbit return CameraOrbitTool
          pan returns CameraDollyTool
          zoom returns CameraZoomTool
          field of view returns CameraFDVTool
          zoom window returns CameraFOVTool
          zoom extends return CameraZoomWindowTool
          walk return CamerWalkTool
          look returns CameraPanTool
          line returns selectSketchTool
          Except for "selectFieldOfViewTool: (CameraFOVTool)" you can remove "Camera" from the observer reported name and prefix "select".
          Special cases are PolyTool, Line tool, and axis tool.
          On second thought, a hash like {reportedObserverName, sendSelectName} might be the best bet.
          • P Offline
            pecan
            The following seems to work, and you can add to the exceptions hash when you find 'em.
            Hope this helps some...
            # Supports Organizer.rb
            =begin
            Copyright 2009, Matt
            All Rights Reserved
            THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION,
            THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
            License;   Free
            Author;     	Matthieu NOBLET
            Organization;   Matt
            Name;      		Recall_lst_tool
            Version;   		1.0
            SU Version;   	6 and 7
            Date;      		17/02/2009
            Description;   	Recall last tool used
            Usage;      	If you want to have a shortcut, please try with native Sketchup shortcuts...
            History;
            	1.000   17/02/2009
            			First version
            	1.100	17/02/2009
            			Global variables replaced by Class variables
            =end
            require 'sketchup.rb'
            class Matt_Observer < Sketchup;;ToolsObserver
                def initialize
                    @ToolExceptionsHash = {
                       # observerName    send_actionName
                        "FOVTool",       "FieldOfViewTool",
                        "SketchCSTool",  "AxisTool",
                        "SketchTool",    "LineTool",
                        "PolyTool",      "PolygonTool"
            	@@Matt_Model_Toolid = nil
            	@@Matt_Model_Toolid2 = nil
                    print tools_object, " ", toolname, " ", toolid, "\n"
                    tname = toolname;
            		# remove "Camera" prefix reported by ToolObserver"
            		@@Matt_Model_Toolid2 = (tname[0,6]="" if (tname[0,6] == "Camera"));
            		tname = @ToolExceptionsHash.fetch(tname, tname);
            		@@Matt_Model_Toolid2 = "select#{tname};";
            	def self.recall_last
                    puts "sending action #{@@Matt_Model_Toolid}" if @@Matt_Model_Toolid
            		return Sketchup.send_action(@@Matt_Model_Toolid) if @@Matt_Model_Toolid
            		return Sketchup.send_action("selectSelectionTool;")
            unless file_loaded?(__FILE__)
               file_loaded(__FILE__)
               Sketchup.active_model.tools.add_observer(Matt_Observer.new)
               $submenu ? (organizer = $submenu) ; (organizer = UI.menu("Plugins"))
               organizer.add_item("Recall last tool"){ Matt_Observer.recall_last }
              Matt666
              Hi pecan!
              Sorry, I didn"t test your plugin, but I think it doesn't work with plugins. So Non native tools...
              I will test it! Thank you for that Pecan!
              Frenglish at its best !
              My scripts
                Matt666
                Hi Pecan! Your method does not work with ruby tools, as expected...
                A new version has been posted in the first post. It fixes a bug found by Simon Le Bon. Thank you Simon!
                My scripts
                • simon le bonS Offline
                  simon le bon
                  Hi Matt,
                  Hip Hip! I've just installed your plug v 1.2 and it seems working very well (all tools are seemingly supported)! So cool!!
                  It's too young to see if it remain operative on duration, but i believe this is now fixed.
                  Many thanks for that tool dear Matt 👍 😄
                  I take it!
                  http://i274.photobucket.com/albums/jj245/Spendauballet/Tampon/gull.gif
                  simon.
                  • EdsonE Offline
                    Edson
                    @matt666 said:
                    Sorry Edson, and all mac users. But I can't do anything with this bug. 😞 Function 'send_action' doesn't accept integers (so tool IDs) on Mac.
                    would the last update make it usable in macs?
                    http://www.mahfuz.arq.br
                      Matt666
                      I take it!
                      ... Dear Edson... I'm so sorry! 😞 You (and all Mac users!)have some problems with many of my scripts... Included this one...
                      I can't be usable in mac. Mac has a bug with main function used in this script: Sketchup.send_action(ToolID). And I can't do anything.
                      Sorry again Edson... 😳
                      My scripts
                      • EdsonE Offline
                        Edson
                        matt,
                        no problem. several other plugins you created work without problems. let's hope this bug gets solved in the future.
                        • plot-parisP Offline
                          plot-paris
                          great plugin, Matthieu. 👍
                          just a thought: does it make sense to have a similar tool go through several previously used tools when pressing the shortcut key repeatedly?
                            Matt666
                            Hi plot_paris!
                            That's a good idea... I will give a try! I think we may go through 10 previously used tools, and may undo history (retrun to the last tool used) by activating selection tool.
                            My scripts
                            • Chris FullmerC Offline
                              Hey, I was just thinking about a plugin that would cycle through tools on repeated pressing of a button.
                              So assign it to the spacebar. Hit the spacebar once and its select. Twice it move, 3 is rotate. But I quickly decided against the silly plugin when I started thinking about having to hit the spacebar 26 times to get to "place camera" or something 😆
                              But in this context, I think it is quite a good idea,
                              Chris
                              All my Plugins I've written
                                plot-paris
                                another idea, although probably not managable with ruby, is a much more graphical approach:
                                when you hold down the space bar, a ring with tool buttons appears around your cursor in a circular fashion. you can now left click any button to get the tool. or you can simply turn the scroll wheel to file through them, either clockwise or counterclockwise. by default the selection tool is highlighted - so if you just press the space bar once, you get the select tool.
                                you can easily customise this tool-circle by holding down the space bar and then dragging unwanted tools out of the circle and vice versa.
                                well, maybe Google comes up with soemthing similar in the next release 😄
                                • juan974J Offline
                                  juan974
                                  Merci MATT ...
                                  juan974 (Réunion island)
                                  website : http://sketchucation.com/click.php?url=http://www.tarn.us
                                    bitsnbites
                                    Thank you very much, Matt666.
                                    That´s the Plugin i was lookin for.
                                    thx a lot
                                      Matt666
                                      I will try to find a solution.
                                      My scripts
                                        Matt666
                                        Sorry, I don't know how to create a personal observer for controlling mouse events...
                                        My scripts
                                        • P Offline
                                          Pherim
                                          Neat, I didn't know this yet. Great timesaver when switching to select tool to return to the previously used tool.
                                            mirale999
                                            Merci Matt! Great plugin~
                                            By the way, I come up with an idea, I think maybe it's useful!
                                            I use the shortcut“shift+Y” to recall the last tool. When I use this plugin, a situation like this will happen:
                                            first I use the "Edge follow me" tool to build a face,
                                            then I move it to another place, and use move and scale to modify the curves,
                                            then I want to do "Edge follow me" again
                                            so the idea comes:------this tool have a function: ignore the move, scale, rotate, line, arc, rectangle, circle...(because they are so useful and they have shortcuts), but recall edge follow me, blend, extrapolate colors...(you must find it in a submenu).
                                            On my bad English... hope you get my meaning... ☀
                                            paranoia is a higher form of awareness...
                                            • 2 / 3
