    [Plugin] Recall last tool v1.2
    60 Posts 28 Posters 62.9k Views 28 Watching
      Matt666
      Sorry Edson, and all mac users. But I can't do anything with this bug. 😞 Function 'send_action' doesn't accept integers (so tool IDs) on Mac.
      Frenglish at its best !
      My scripts
        pecan
        Result from SU ruby console
        (eval)
        result = Sketchup.send_action "selectSelectionTool:"
        true
        I was in error suggesting it was a num.
          pecan
          Using the tool name should work:
          def onActiveToolChanged (tools_object, toolname, toolid)
                  print tools_object, toolname, toolid
          		@@Matt_Model_Toolid = @@Matt_Model_Toolid2 if @@Matt_Model_Toolid2
          		#@@Matt_Model_Toolid2 = toolid if not([21022,10508].index toolid)
          		@@Matt_Model_Toolid2 = "select#{toolname};";
          		puts "1; #{@@Matt_Model_Toolid} 2; #{@@Matt_Model_Toolid2}"
            pecan
            > 	end
            Well... almost.
            "selectCameraOrbitTool:" doesnt work.
            It's action name is simply OrbitTool.
            So maybe a hash of returned tool names and the send_action name.
            sendActionToolName = {"CameraOrbitTool", "OrbitTool", } etc.
            Or maybe a hash of just the exceptions.
            Its a shame SU has to be so inconsistent.
              pecan
              Here's a list of the send_actions and the actual tool name returned by the observer.
              howRubyPanel;
              viewBack;
              viewBottom;
              viewFront;
              viewIso;
              viewLeft;
              viewRight;
              viewTop;
              viewPerspective;
              viewShowAxes;
              viewShowHidden;
              viewZoomExtents;
              viewZoomToSelection;
              viewUndo;
              selectOrbitTool; (CameraOrbitTool)
                  ok  selectPositionCameraTool;
              selectDollyTool; (CameraDollyTool
              selectTurnTool;
              selectWalkTool; (CameraWalkTool)
              selectZoomTool; (CameraZoomTool)
              selectFieldOfViewTool; (CameraFOVTool) <=== inconsistency
              selectZoomWindowTool; (CameraZoomWindowTool)
              pageAdd;
              pageDelete;
              pageUpdate;
              pageNext;
              pagePrevious;
              renderWireframe;
              renderHiddenLine;
              renderMonochrome&#058;
              renderShaded;
              renderTextures;
                  ok  selectArcTool;
              selectAxisTool; (SketchCSTool)
                  ok  selectCircleTool;
                  ok selectEraseTool;
                  ok  selectFreehandTool;
              selectLineTool; (SketchTool)
                  ok  selectMeasureTool;
                  ok  selectMoveTool;
                  ok  selectOffsetTool;
                  ok  selectPaintTool;
              selectPolygonTool; (PolyTool)
                  ok  selectProtractorTool;
                  ok  selectPushPullTool;
                  ok  selectRectangleTool;
                  ok  selectRotateTool;
                  ok  selectScaleTool;
                  ok  selectSectionPlaneTool;
                  ok  selectTextTool;
                  ok  selectDimensionTool;
                  ok  selectExtrudeTool;
                  ok  selectSelectionTool;
              editUndo;
              editRedo;
              editHide;
              editUnhide;
              fixNonPlanarFaces;
              axes is returning SketchCSTool
              3d text is returning 3DTextTool
              plugins return RubyTool
              orbit return CameraOrbitTool
              pan returns CameraDollyTool
              zoom returns CameraZoomTool
              field of view returns CameraFDVTool
              zoom window returns CameraFOVTool
              zoom extends return CameraZoomWindowTool
              walk return CamerWalkTool
              look returns CameraPanTool
              line returns selectSketchTool
              Except for "selectFieldOfViewTool: (CameraFOVTool)" you can remove "Camera" from the observer reported name and prefix "select".
              Special cases are PolyTool, Line tool, and axis tool.
              On second thought, a hash like {reportedObserverName, sendSelectName} might be the best bet.
                pecan
                The following seems to work, and you can add to the exceptions hash when you find 'em.
                Hope this helps some...
                # Supports Organizer.rb
                =begin
                Copyright 2009, Matt
                All Rights Reserved
                THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION,
                THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
                License;   Free
                Author;     	Matthieu NOBLET
                Organization;   Matt
                Name;      		Recall_lst_tool
                Version;   		1.0
                SU Version;   	6 and 7
                Date;      		17/02/2009
                Description;   	Recall last tool used
                Usage;      	If you want to have a shortcut, please try with native Sketchup shortcuts...
                History;
                	1.000   17/02/2009
                			First version
                	1.100	17/02/2009
                			Global variables replaced by Class variables
                =end
                require 'sketchup.rb'
                class Matt_Observer < Sketchup;;ToolsObserver
                    def initialize
                        @ToolExceptionsHash = {
                           # observerName    send_actionName
                            "FOVTool",       "FieldOfViewTool",
                            "SketchCSTool",  "AxisTool",
                            "SketchTool",    "LineTool",
                            "PolyTool",      "PolygonTool"
                	@@Matt_Model_Toolid = nil
                	@@Matt_Model_Toolid2 = nil
                        print tools_object, " ", toolname, " ", toolid, "\n"
                        tname = toolname;
                		# remove "Camera" prefix reported by ToolObserver"
                		@@Matt_Model_Toolid2 = (tname[0,6]="" if (tname[0,6] == "Camera"));
                		tname = @ToolExceptionsHash.fetch(tname, tname);
                		@@Matt_Model_Toolid2 = "select#{tname};";
                	def self.recall_last
                        puts "sending action #{@@Matt_Model_Toolid}" if @@Matt_Model_Toolid
                		return Sketchup.send_action(@@Matt_Model_Toolid) if @@Matt_Model_Toolid
                		return Sketchup.send_action("selectSelectionTool;")
                unless file_loaded?(__FILE__)
                   file_loaded(__FILE__)
                   Sketchup.active_model.tools.add_observer(Matt_Observer.new)
                   $submenu ? (organizer = $submenu) ; (organizer = UI.menu("Plugins"))
                   organizer.add_item("Recall last tool"){ Matt_Observer.recall_last }
                  Matt666
                  Hi pecan!
                  Sorry, I didn"t test your plugin, but I think it doesn't work with plugins. So Non native tools...
                  I will test it! Thank you for that Pecan!
                  My scripts
                    Matt666
                    Hi Pecan! Your method does not work with ruby tools, as expected...
                    A new version has been posted in the first post. It fixes a bug found by Simon Le Bon. Thank you Simon!
                    My scripts
                    • simon le bonS Offline
                      simon le bon
                      Hi Matt,
                      Hip Hip! I've just installed your plug v 1.2 and it seems working very well (all tools are seemingly supported)! So cool!!
                      It's too young to see if it remain operative on duration, but i believe this is now fixed.
                      Many thanks for that tool dear Matt 👍 😄
                      I take it!
                      http://i274.photobucket.com/albums/jj245/Spendauballet/Tampon/gull.gif
                      simon.
                      • EdsonE Offline
                        Edson
                        would the last update make it usable in macs?
                        http://www.mahfuz.arq.br
                          Matt666
                          I take it!
                          ... Dear Edson... I'm so sorry! 😞 You (and all Mac users!)have some problems with many of my scripts... Included this one...
                          I can't be usable in mac. Mac has a bug with main function used in this script: Sketchup.send_action(ToolID). And I can't do anything.
                          Sorry again Edson... 😳
                          My scripts
                          • EdsonE Offline
                            Edson
                            matt,
                            no problem. several other plugins you created work without problems. let's hope this bug gets solved in the future.
                            • plot-parisP Offline
                              plot-paris
                              great plugin, Matthieu. 👍
                              just a thought: does it make sense to have a similar tool go through several previously used tools when pressing the shortcut key repeatedly?
                                Matt666
                                Hi plot_paris!
                                That's a good idea... I will give a try! I think we may go through 10 previously used tools, and may undo history (retrun to the last tool used) by activating selection tool.
                                My scripts
                                • Chris FullmerC Offline
                                  Hey, I was just thinking about a plugin that would cycle through tools on repeated pressing of a button.
                                  So assign it to the spacebar. Hit the spacebar once and its select. Twice it move, 3 is rotate. But I quickly decided against the silly plugin when I started thinking about having to hit the spacebar 26 times to get to "place camera" or something 😆
                                  But in this context, I think it is quite a good idea,
                                    plot-paris
                                    another idea, although probably not managable with ruby, is a much more graphical approach:
                                    when you hold down the space bar, a ring with tool buttons appears around your cursor in a circular fashion. you can now left click any button to get the tool. or you can simply turn the scroll wheel to file through them, either clockwise or counterclockwise. by default the selection tool is highlighted - so if you just press the space bar once, you get the select tool.
                                    you can easily customise this tool-circle by holding down the space bar and then dragging unwanted tools out of the circle and vice versa.
                                    well, maybe Google comes up with soemthing similar in the next release 😄
                                    • juan974J Offline
                                      juan974
                                      Merci MATT ...
                                      juan974 (Réunion island)
                                      website : http://sketchucation.com/click.php?url=http://www.tarn.us
                                        bitsnbites
                                        Thank you very much, Matt666.
                                        That´s the Plugin i was lookin for.
                                        thx a lot
                                          Matt666
                                          I will try to find a solution.
                                          My scripts
                                            Matt666
                                            Sorry, I don't know how to create a personal observer for controlling mouse events...
                                            My scripts
                                            • 2 / 3
