    [Plugin] Recall last tool v1.2
    60 Posts 28 Posters 62.9k Views 28 Watching
      pecan
      @matt666 said:
      Hi Edson... I hope you do not know!! I'm cursed...
      Sketchup.send_action(21022)
      This code calls selection tool.
      Thank you Edson. And sorry for the inconvenience.
      On differenct OS's, even the same OS with different menus, that magic number will have changed.
      What's wrong with Sketchup.send_action(selectSelectionTool:);
      When the menu structure is updated, then the call will still work even tho the menu id has changed.
      • simon le bonS Offline
        simon le bon
        Bravo Matt !!
        at the very beginning of my learning SketchUp, I was surprised not to have this feature at disposal. And then I was accustomed to always recall my tools. And Here comes your ruby. It is as if suddenly we had won a great lightness. (F2 is great)
        it already belongs to my toolbox. πŸ‘ πŸ‘ πŸ˜„simon
          Matt666
          Merci Simon ! πŸ˜‰
          @pecan said:
          On different OS's, even the same OS with different menus, that magic number will have changed.
          Hi pecan! Are you sure of that? I use only two different numbers in my code. The rest is a recall of the last number used.
          But there's a biiig problem with Mac... On Mac, function "send_action" does not accept integers. Only strings! 😞
          @edson said:
          It did not work. i had done it that way before. below is the ruby console reading.
          Thank you Edson!
          Ouch. I will try to find a solution. Can you test this code below, please?
          Sketchup.send_action("21022")
          Frenglish at its best !
          My scripts
          • EdsonE Offline
            Edson
            it looks good!
            http://www.mahfuz.arq.br
              Matt666
              Ok. But if you have rectangle tool called, when you copy and validate the code, is the selection tool activated?
              My scripts
              • EdsonE Offline
                Edson
                i drew a rectangle, then pressed the space bar, then used the script from the menu. the result is in the picture.
                  Matt666
                  Sorry Edson, and all mac users. But I can't do anything with this bug. 😞 Function 'send_action' doesn't accept integers (so tool IDs) on Mac.
                  My scripts
                    pecan
                    Result from SU ruby console
                    (eval)
                    result = Sketchup.send_action "selectSelectionTool:"
                    true
                    I was in error suggesting it was a num.
                      pecan
                      Using the tool name should work:
                      def onActiveToolChanged (tools_object, toolname, toolid)
                              print tools_object, toolname, toolid
                      		@@Matt_Model_Toolid = @@Matt_Model_Toolid2 if @@Matt_Model_Toolid2
                      		#@@Matt_Model_Toolid2 = toolid if not([21022,10508].index toolid)
                      		@@Matt_Model_Toolid2 = "select#{toolname};";
                      		puts "1; #{@@Matt_Model_Toolid} 2; #{@@Matt_Model_Toolid2}"
                        pecan
                        > 	end
                        Well... almost.
                        "selectCameraOrbitTool:" doesnt work.
                        It's action name is simply OrbitTool.
                        So maybe a hash of returned tool names and the send_action name.
                        sendActionToolName = {"CameraOrbitTool", "OrbitTool", } etc.
                        Or maybe a hash of just the exceptions.
                        Its a shame SU has to be so inconsistent.
                          pecan
                          Here's a list of the send_actions and the actual tool name returned by the observer.
                          howRubyPanel;
                          viewBack;
                          viewBottom;
                          viewFront;
                          viewIso;
                          viewLeft;
                          viewRight;
                          viewTop;
                          viewPerspective;
                          viewShowAxes;
                          viewShowHidden;
                          viewZoomExtents;
                          viewZoomToSelection;
                          viewUndo;
                          selectOrbitTool; (CameraOrbitTool)
                              ok  selectPositionCameraTool;
                          selectDollyTool; (CameraDollyTool
                          selectTurnTool;
                          selectWalkTool; (CameraWalkTool)
                          selectZoomTool; (CameraZoomTool)
                          selectFieldOfViewTool; (CameraFOVTool) <=== inconsistency
                          selectZoomWindowTool; (CameraZoomWindowTool)
                          pageAdd;
                          pageDelete;
                          pageUpdate;
                          pageNext;
                          pagePrevious;
                          renderWireframe;
                          renderHiddenLine;
                          renderMonochrome&#058;
                          renderShaded;
                          renderTextures;
                              ok  selectArcTool;
                          selectAxisTool; (SketchCSTool)
                              ok  selectCircleTool;
                              ok selectEraseTool;
                              ok  selectFreehandTool;
                          selectLineTool; (SketchTool)
                              ok  selectMeasureTool;
                              ok  selectMoveTool;
                              ok  selectOffsetTool;
                              ok  selectPaintTool;
                          selectPolygonTool; (PolyTool)
                              ok  selectProtractorTool;
                              ok  selectPushPullTool;
                              ok  selectRectangleTool;
                              ok  selectRotateTool;
                              ok  selectScaleTool;
                              ok  selectSectionPlaneTool;
                              ok  selectTextTool;
                              ok  selectDimensionTool;
                              ok  selectExtrudeTool;
                              ok  selectSelectionTool;
                          editUndo;
                          editRedo;
                          editHide;
                          editUnhide;
                          fixNonPlanarFaces;
                          axes is returning SketchCSTool
                          3d text is returning 3DTextTool
                          plugins return RubyTool
                          orbit return CameraOrbitTool
                          pan returns CameraDollyTool
                          zoom returns CameraZoomTool
                          field of view returns CameraFDVTool
                          zoom window returns CameraFOVTool
                          zoom extends return CameraZoomWindowTool
                          walk return CamerWalkTool
                          look returns CameraPanTool
                          line returns selectSketchTool
                          Except for "selectFieldOfViewTool: (CameraFOVTool)" you can remove "Camera" from the observer reported name and prefix "select".
                          Special cases are PolyTool, Line tool, and axis tool.
                          On second thought, a hash like {reportedObserverName, sendSelectName} might be the best bet.
                            pecan
                            The following seems to work, and you can add to the exceptions hash when you find 'em.
                            Hope this helps some...
                            # Supports Organizer.rb
                            =begin
                            Copyright 2009, Matt
                            All Rights Reserved
                            THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION,
                            THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
                            License;   Free
                            Author;     	Matthieu NOBLET
                            Organization;   Matt
                            Name;      		Recall_lst_tool
                            Version;   		1.0
                            SU Version;   	6 and 7
                            Date;      		17/02/2009
                            Description;   	Recall last tool used
                            Usage;      	If you want to have a shortcut, please try with native Sketchup shortcuts...
                            History;
                            	1.000   17/02/2009
                            			First version
                            	1.100	17/02/2009
                            			Global variables replaced by Class variables
                            =end
                            require 'sketchup.rb'
                            class Matt_Observer < Sketchup;;ToolsObserver
                                def initialize
                                    @ToolExceptionsHash = {
                                       # observerName    send_actionName
                                        "FOVTool",       "FieldOfViewTool",
                                        "SketchCSTool",  "AxisTool",
                                        "SketchTool",    "LineTool",
                                        "PolyTool",      "PolygonTool"
                            	@@Matt_Model_Toolid = nil
                            	@@Matt_Model_Toolid2 = nil
                                    print tools_object, " ", toolname, " ", toolid, "\n"
                                    tname = toolname;
                            		# remove "Camera" prefix reported by ToolObserver"
                            		@@Matt_Model_Toolid2 = (tname[0,6]="" if (tname[0,6] == "Camera"));
                            		tname = @ToolExceptionsHash.fetch(tname, tname);
                            		@@Matt_Model_Toolid2 = "select#{tname};";
                            	def self.recall_last
                                    puts "sending action #{@@Matt_Model_Toolid}" if @@Matt_Model_Toolid
                            		return Sketchup.send_action(@@Matt_Model_Toolid) if @@Matt_Model_Toolid
                            		return Sketchup.send_action("selectSelectionTool;")
                            unless file_loaded?(__FILE__)
                               file_loaded(__FILE__)
                               Sketchup.active_model.tools.add_observer(Matt_Observer.new)
                               $submenu ? (organizer = $submenu) ; (organizer = UI.menu("Plugins"))
                               organizer.add_item("Recall last tool"){ Matt_Observer.recall_last }
                              Matt666
                              Hi pecan!
                              Sorry, I didn"t test your plugin, but I think it doesn't work with plugins. So Non native tools...
                              I will test it! Thank you for that Pecan!
                              My scripts
                                Matt666
                                Hi Pecan! Your method does not work with ruby tools, as expected...
                                A new version has been posted in the first post. It fixes a bug found by Simon Le Bon. Thank you Simon!
                                My scripts
                                  simon le bon
                                  Hi Matt,
                                  Hip Hip! I've just installed your plug v 1.2 and it seems working very well (all tools are seemingly supported)! So cool!!
                                  It's too young to see if it remain operative on duration, but i believe this is now fixed.
                                  Many thanks for that tool dear Matt πŸ‘ πŸ˜„
                                  I take it!
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/Tampon/gull.gif
                                  simon.
                                  • EdsonE Offline
                                    Edson
                                    would the last update make it usable in macs?
                                      Matt666
                                      I take it!
                                      πŸ‘
                                      ... Dear Edson... I'm so sorry! 😞 You (and all Mac users!)have some problems with many of my scripts... Included this one...
                                      I can't be usable in mac. Mac has a bug with main function used in this script: Sketchup.send_action(ToolID). And I can't do anything.
                                      Sorry again Edson... 😳
                                      My scripts
                                      • EdsonE Offline
                                        Edson
                                        matt,
                                        no problem. several other plugins you created work without problems. let's hope this bug gets solved in the future.
                                        • plot-parisP Offline
                                          plot-paris
                                          great plugin, Matthieu. πŸ‘
                                          just a thought: does it make sense to have a similar tool go through several previously used tools when pressing the shortcut key repeatedly?
                                            Matt666
                                            Hi plot_paris!
                                            That's a good idea... I will give a try! I think we may go through 10 previously used tools, and may undo history (retrun to the last tool used) by activating selection tool.
                                            My scripts
                                            • 2 / 3
