    [Plugin] Recall last tool v1.2
    60 Posts 28 Posters 65.3k Views 28 Watching
      pecan
      Result from SU ruby console
      (eval)
      result = Sketchup.send_action "selectSelectionTool:"
      true
      I was in error suggesting it was a num.
        pecan
        Using the tool name should work:
        def onActiveToolChanged (tools_object, toolname, toolid)
                print tools_object, toolname, toolid
        		@@Matt_Model_Toolid = @@Matt_Model_Toolid2 if @@Matt_Model_Toolid2
        		#@@Matt_Model_Toolid2 = toolid if not([21022,10508].index toolid)
        		@@Matt_Model_Toolid2 = "select#{toolname};";
        		puts "1; #{@@Matt_Model_Toolid} 2; #{@@Matt_Model_Toolid2}"
          pecan
          > 	end
          Well... almost.
          "selectCameraOrbitTool:" doesnt work.
          It's action name is simply OrbitTool.
          So maybe a hash of returned tool names and the send_action name.
          sendActionToolName = {"CameraOrbitTool", "OrbitTool", } etc.
          Or maybe a hash of just the exceptions.
          Its a shame SU has to be so inconsistent.
            pecan
            Here's a list of the send_actions and the actual tool name returned by the observer.
            howRubyPanel;
            viewBack;
            viewBottom;
            viewFront;
            viewIso;
            viewLeft;
            viewRight;
            viewTop;
            viewPerspective;
            viewShowAxes;
            viewShowHidden;
            viewZoomExtents;
            viewZoomToSelection;
            viewUndo;
            selectOrbitTool; (CameraOrbitTool)
                ok  selectPositionCameraTool;
            selectDollyTool; (CameraDollyTool
            selectTurnTool;
            selectWalkTool; (CameraWalkTool)
            selectZoomTool; (CameraZoomTool)
            selectFieldOfViewTool; (CameraFOVTool) <=== inconsistency
            selectZoomWindowTool; (CameraZoomWindowTool)
            pageAdd;
            pageDelete;
            pageUpdate;
            pageNext;
            pagePrevious;
            renderWireframe;
            renderHiddenLine;
            renderMonochrome&#058;
            renderShaded;
            renderTextures;
                ok  selectArcTool;
            selectAxisTool; (SketchCSTool)
                ok  selectCircleTool;
                ok selectEraseTool;
                ok  selectFreehandTool;
            selectLineTool; (SketchTool)
                ok  selectMeasureTool;
                ok  selectMoveTool;
                ok  selectOffsetTool;
                ok  selectPaintTool;
            selectPolygonTool; (PolyTool)
                ok  selectProtractorTool;
                ok  selectPushPullTool;
                ok  selectRectangleTool;
                ok  selectRotateTool;
                ok  selectScaleTool;
                ok  selectSectionPlaneTool;
                ok  selectTextTool;
                ok  selectDimensionTool;
                ok  selectExtrudeTool;
                ok  selectSelectionTool;
            editUndo;
            editRedo;
            editHide;
            editUnhide;
            fixNonPlanarFaces;
            axes is returning SketchCSTool
            3d text is returning 3DTextTool
            plugins return RubyTool
            orbit return CameraOrbitTool
            pan returns CameraDollyTool
            zoom returns CameraZoomTool
            field of view returns CameraFDVTool
            zoom window returns CameraFOVTool
            zoom extends return CameraZoomWindowTool
            walk return CamerWalkTool
            look returns CameraPanTool
            line returns selectSketchTool
            Except for "selectFieldOfViewTool: (CameraFOVTool)" you can remove "Camera" from the observer reported name and prefix "select".
            Special cases are PolyTool, Line tool, and axis tool.
            On second thought, a hash like {reportedObserverName, sendSelectName} might be the best bet.
              pecan
              The following seems to work, and you can add to the exceptions hash when you find 'em.
              Hope this helps some...
              # Supports Organizer.rb
              =begin
              Copyright 2009, Matt
              All Rights Reserved
              THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION,
              THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
              License;   Free
              Author;     	Matthieu NOBLET
              Organization;   Matt
              Name;      		Recall_lst_tool
              Version;   		1.0
              SU Version;   	6 and 7
              Date;      		17/02/2009
              Description;   	Recall last tool used
              Usage;      	If you want to have a shortcut, please try with native Sketchup shortcuts...
              History;
              	1.000   17/02/2009
              			First version
              	1.100	17/02/2009
              			Global variables replaced by Class variables
              =end
              require 'sketchup.rb'
              class Matt_Observer < Sketchup;;ToolsObserver
                  def initialize
                      @ToolExceptionsHash = {
                         # observerName    send_actionName
                          "FOVTool",       "FieldOfViewTool",
                          "SketchCSTool",  "AxisTool",
                          "SketchTool",    "LineTool",
                          "PolyTool",      "PolygonTool"
              	@@Matt_Model_Toolid = nil
              	@@Matt_Model_Toolid2 = nil
                      print tools_object, " ", toolname, " ", toolid, "\n"
                      tname = toolname;
              		# remove "Camera" prefix reported by ToolObserver"
              		@@Matt_Model_Toolid2 = (tname[0,6]="" if (tname[0,6] == "Camera"));
              		tname = @ToolExceptionsHash.fetch(tname, tname);
              		@@Matt_Model_Toolid2 = "select#{tname};";
              	def self.recall_last
                      puts "sending action #{@@Matt_Model_Toolid}" if @@Matt_Model_Toolid
              		return Sketchup.send_action(@@Matt_Model_Toolid) if @@Matt_Model_Toolid
              		return Sketchup.send_action("selectSelectionTool;")
              unless file_loaded?(__FILE__)
                 file_loaded(__FILE__)
                 Sketchup.active_model.tools.add_observer(Matt_Observer.new)
                 $submenu ? (organizer = $submenu) ; (organizer = UI.menu("Plugins"))
                 organizer.add_item("Recall last tool"){ Matt_Observer.recall_last }
                Matt666
                Hi pecan!
                Sorry, I didn"t test your plugin, but I think it doesn't work with plugins. So Non native tools...
                I will test it! Thank you for that Pecan!
                Frenglish at its best !
                My scripts
                  Matt666
                  Hi Pecan! Your method does not work with ruby tools, as expected...
                  A new version has been posted in the first post. It fixes a bug found by Simon Le Bon. Thank you Simon!
                  My scripts
                  • simon le bonS Offline
                    simon le bon
                    Hi Matt,
                    Hip Hip! I've just installed your plug v 1.2 and it seems working very well (all tools are seemingly supported)! So cool!!
                    It's too young to see if it remain operative on duration, but i believe this is now fixed.
                    Many thanks for that tool dear Matt 👍 😄
                    I take it!
                    http://i274.photobucket.com/albums/jj245/Spendauballet/Tampon/gull.gif
                    simon.
                    • EdsonE Offline
                      Edson
                      @matt666 said:
                      Sorry Edson, and all mac users. But I can't do anything with this bug. 😞 Function 'send_action' doesn't accept integers (so tool IDs) on Mac.
                      would the last update make it usable in macs?
                      http://www.mahfuz.arq.br
                        Matt666
                        I take it!
                        ... Dear Edson... I'm so sorry! 😞 You (and all Mac users!)have some problems with many of my scripts... Included this one...
                        I can't be usable in mac. Mac has a bug with main function used in this script: Sketchup.send_action(ToolID). And I can't do anything.
                        Sorry again Edson... 😳
                        My scripts
                        • EdsonE Offline
                          Edson
                          matt,
                          no problem. several other plugins you created work without problems. let's hope this bug gets solved in the future.
                          • plot-parisP Offline
                            plot-paris
                            great plugin, Matthieu. 👍
                            just a thought: does it make sense to have a similar tool go through several previously used tools when pressing the shortcut key repeatedly?
                              Matt666
                              Hi plot_paris!
                              That's a good idea... I will give a try! I think we may go through 10 previously used tools, and may undo history (retrun to the last tool used) by activating selection tool.
                              My scripts
                              • Chris FullmerC Offline
                                Hey, I was just thinking about a plugin that would cycle through tools on repeated pressing of a button.
                                So assign it to the spacebar. Hit the spacebar once and its select. Twice it move, 3 is rotate. But I quickly decided against the silly plugin when I started thinking about having to hit the spacebar 26 times to get to "place camera" or something 😆
                                But in this context, I think it is quite a good idea,
                                  plot-paris
                                  another idea, although probably not managable with ruby, is a much more graphical approach:
                                  when you hold down the space bar, a ring with tool buttons appears around your cursor in a circular fashion. you can now left click any button to get the tool. or you can simply turn the scroll wheel to file through them, either clockwise or counterclockwise. by default the selection tool is highlighted - so if you just press the space bar once, you get the select tool.
                                  you can easily customise this tool-circle by holding down the space bar and then dragging unwanted tools out of the circle and vice versa.
                                  well, maybe Google comes up with soemthing similar in the next release 😄
                                  • juan974J Offline
                                    juan974
                                    Merci MATT ...
                                    juan974 (Réunion island)
                                    website : http://sketchucation.com/click.php?url=http://www.tarn.us
                                      bitsnbites
                                      Thank you very much, Matt666.
                                      That´s the Plugin i was lookin for.
                                      thx a lot
                                        Matt666
                                        I will try to find a solution.
                                        My scripts
                                          Matt666
                                          Sorry, I don't know how to create a personal observer for controlling mouse events...
                                          My scripts
                                            Pherim
                                            Neat, I didn't know this yet. Great timesaver when switching to select tool to return to the previously used tool.
                                            • 2 / 3
