    [Plugin] Greeble 2 released! (Updated August 31st, 2009)
    94 Posts 24 Posters 78.8k Views 24 Watching
    • Chris FullmerC Offline
      Can you upload a simple model that you are trying to use it on that is not working? And also possibly open the Ruby Console (from the Window menu) and then run the plugin and see if it displays any errors there. Please paste those errors here.
      This script does not always behave well...
      All my Plugins I've written
        Bertier
        set to meters as Pilou suggested
        trying to greeble a simple 100 x 100 square :
        #Sketchup::Face:0x24e2b624 did not offset:
        Error: #<NoMethodError: undefined method normal' for nil:NilClass> C:/Program Files/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:250:in greeble'
        C:/Program Files/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:223:in each' C:/Program Files/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:223:in greeble'
        C:/Program Files/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:294
        C:/Program Files/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:250:in `call'
          Bertier
          The error in line #250 is when it tries to get a normal new_vector = cl_newface.normal and the face cl_newface doesn't exist.
          It is made by offsetting e which is one of clface[s] around lines #236 et al...
          Not sure what's causing it... Chris?
            Bertier
            sound chinese to me...
              hmm, somehow it is passing a bad vector parameter to the offset script I think.
              An example model would be helpful. Could you upload a small test model that is not working right? Thanks!
              Chris
                Avec comme unité les mètres
                Essaie avec ces valeur avec une figure qui fait au minimum 100 m par 100 par 100 m !
                Pour avoir une extrusion continue
                Il faut répondre oui à la question pour faire un "group" de la boite de dialogue une fois le plug lancé
                Exploser le groupe résultat et recommencer 😉
                  About the repetition from the last action : now we must make that
                  Select faces
                  begin
                  Grebble with "Yes I want grouping the all topmost faces"
                  • else any faces will be not selected for a next grebbling 😲
                    Result
                    Explode group = new topmost faces selected ☀
                    goto begin
                  it's possible but a little painful 😉
                  Vieria Da Silva inspiration (cool gallery zoom possible) ☀
                  Another thing: using the new plug of Selection aera by Sdmitch on a complex Greeble volume
                  Some faces are selected as wished, but the Greebble makes nothing 😮
                  Have you some tests inside Grebble for exit if some faces are in particular positions (overlapsed) ?
                  (make nothing also with normal selection 😒
                  • P Offline
                    Pout
                    Hey Chris, haven't look at it but i read in the previous version of this plugin that you planned on integrating a cancel button to cancel script execution.
                    Did you find a solution for this?
                    Thx
                      No, this was one of the first scripts I ever wrote and I probably said that before I knew how how hard that can be to do. I really never even tried to do it though.
                      • E Offline
                        El_Sexto
                        Hi guys ! somebody have the solution for the bertier problem plz ?
                          Bertier never posted his problem SKP or anything further to help us, so it went no further...
                          If you are experiencing similar problems then please post the full error messages from the Ruby Console etc, and a copy of a SKP that displays this aberrant behavior... 😕
                          • E Offline
                            El_Sexto
                            Ok
                            Ruby Message : #Sketchup::Face:0xcc62710 did not offset:
                            Error: #<NoMethodError: undefined method normal' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:250:in greeble'
                            C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:223:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:223:in greeble'
                            C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:294
                            C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:250:in `call'
                            I used Sketchup 8, meters dimension and i use the Pilou's setting : 10,-10 ... and the Default setting, 1',-1'... and i have the same result : Anything !
                            Thanx.
                            model.skp
                              What did you type to make it offset? I think it is does not work very well with meters, and might not work at all with comma's as decimal place deliminators. Meaning 1,2 should be written as 1.2 if you are from a part of the world that uses a comma as a decimal place.
                                No problem with your model Model.SKP! (in V8) Works like a charm! 😎 (I am on PC)
                                Greeble buildings are just in the other side 😉
                                Are you sure you have also in the plugins folder
                                Progress bar and Offset?
                                • E Offline
                                  El_Sexto
                                  Thanx guys for your answer !
                                  Pilou : u can see the folder, offset and progressbar are here.
                                  Chris :in this model i have not deliminators; see the attachment, 10,10,-2,-2,0,100 and i have also use the default and Pilou valuesplugin folder
                                  first step
                                  second step
                                  third step
                                  4th step
                                    masterplan
                                    it doesnt work for me. ❓
                                      Masterplan (welcome, BTW) please, be more specific. What are you doing exactly and what do you expect? Is there any error message? Maybe attach a file that "does not work for you" or something.
                                      For a sentence "it does not work for me" one can only answer "well that sucks". Give as much info as possible otherwise you will be left hanging...
                                        @ El-sexto
                                        That is very mysterious 😲
                                        What can I say? That works for me with your model with your version of SU 🤓
                                        Does this version the last one ?
                                        Have you try with a previous version of SU ?
                                        • E Offline
                                          El_Sexto
                                          Yes I tried with sketchup 7 - Maybe i should try with the version 1 ... 🤓
                                            Do you get any better results if you lift the geometry off the groundplane?
                                            Just to verify (again), but you do have the most recent greeble and offset scripts from http://www.smustard.com?
                                            What language is your Operating System set to?
                                            I'll see if I can test this later tonight, sorry its not working!
                                            Chris
                                            • 4 / 5
