    [Plugin] Greeble 2 released! (Updated August 31st, 2009)
    94 Posts 24 Posters 81.0k Views 24 Watching
    • bagateloB Offline
      bagatelo
      Please note the presentation that I have made in the attached file. That's exactly what I need. In some cases, I do not use handles in aluminum bar. I use ordinary handles. So I do not pull over 3cm from top face to bottom. In some cases, I use different spaces for 0.5cm, as requested by the woodworker or architect that I work. Thank you for your attention.
      One day I will no more bore you, because I'm trying to learn Ruby Script. Thanks.
      WHAT I NEED SKT 7.skp
        This plug is always very funny ☀
        • Chris FullmerC Offline
          Pilou, you crack me up! Great stuff as always.
          PS - what is your artistic style called, with all the vibrant colors and nonsensical shapes? I thought I remembered you using a term once that I found very interesting.
            Surely "Flashy" 💚 for the other term I don't remember. 😳
            Speedy Strange surreal geometrical attractor ? 😄
            Because I don't spend more ten minutes by scenes! 😒
            If you have 5 minutes you can see some Zbrush folish 😉
            (section Zibi Art )
            PS You have remarked that I have an immoderated use of your crazy "Random Painter" plug with SU 😉
              Bertier
              can't get no greeble 😞
                Go to SMustard 😉 (it's free)
                  Bertier
                  c'est installé avec tout ce qu'il faut mais ça ne fonctionne pas...
                    Can you upload a simple model that you are trying to use it on that is not working? And also possibly open the Ruby Console (from the Window menu) and then run the plugin and see if it displays any errors there. Please paste those errors here.
                    This script does not always behave well...
                      Bertier
                      set to meters as Pilou suggested
                      trying to greeble a simple 100 x 100 square :
                      #Sketchup::Face:0x24e2b624 did not offset:
                      Error: #<NoMethodError: undefined method normal' for nil:NilClass> C:/Program Files/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:250:in greeble'
                      C:/Program Files/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:223:in each' C:/Program Files/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:223:in greeble'
                      C:/Program Files/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:294
                      C:/Program Files/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:250:in `call'
                        Bertier
                        The error in line #250 is when it tries to get a normal new_vector = cl_newface.normal and the face cl_newface doesn't exist.
                        It is made by offsetting e which is one of clface[s] around lines #236 et al...
                        Not sure what's causing it... Chris?
                          Bertier
                          sound chinese to me...
                            hmm, somehow it is passing a bad vector parameter to the offset script I think.
                            An example model would be helpful. Could you upload a small test model that is not working right? Thanks!
                              Avec comme unité les mètres
                              Essaie avec ces valeur avec une figure qui fait au minimum 100 m par 100 par 100 m !
                              Pour avoir une extrusion continue
                              Il faut répondre oui à la question pour faire un "group" de la boite de dialogue une fois le plug lancé
                              Exploser le groupe résultat et recommencer 😉
                                About the repetition from the last action : now we must make that
                                Select faces
                                begin
                                Grebble with "Yes I want grouping the all topmost faces"
                                • else any faces will be not selected for a next grebbling 😲
                                  Result
                                  Explode group = new topmost faces selected ☀
                                  goto begin
                                it's possible but a little painful 😉
                                Vieria Da Silva inspiration (cool gallery zoom possible) ☀
                                Another thing: using the new plug of Selection aera by Sdmitch on a complex Greeble volume
                                Some faces are selected as wished, but the Greebble makes nothing 😮
                                Have you some tests inside Grebble for exit if some faces are in particular positions (overlapsed) ?
                                (make nothing also with normal selection 😒
                                  Pout
                                  Hey Chris, haven't look at it but i read in the previous version of this plugin that you planned on integrating a cancel button to cancel script execution.
                                  Did you find a solution for this?
                                  Thx
                                    No, this was one of the first scripts I ever wrote and I probably said that before I knew how how hard that can be to do. I really never even tried to do it though.
                                    • E Offline
                                      El_Sexto
                                      Hi guys ! somebody have the solution for the bertier problem plz ?
                                        Bertier never posted his problem SKP or anything further to help us, so it went no further...
                                        If you are experiencing similar problems then please post the full error messages from the Ruby Console etc, and a copy of a SKP that displays this aberrant behavior... 😕
                                        • E Offline
                                          El_Sexto
                                          Ok
                                          Ruby Message : #Sketchup::Face:0xcc62710 did not offset:
                                          Error: #<NoMethodError: undefined method normal' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:250:in greeble'
                                          C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:223:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:223:in greeble'
                                          C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:294
                                          C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:250:in `call'
                                          I used Sketchup 8, meters dimension and i use the Pilou's setting : 10,-10 ... and the Default setting, 1',-1'... and i have the same result : Anything !
                                          Thanx.
                                          model.skp
                                            What did you type to make it offset? I think it is does not work very well with meters, and might not work at all with comma's as decimal place deliminators. Meaning 1,2 should be written as 1.2 if you are from a part of the world that uses a comma as a decimal place.
                                            • 4 / 5
