    [Plugin] Greeble 2 released! (Updated August 31st, 2009)
    94 Posts 24 Posters 84.3k Views 24 Watching
    • Chris FullmerC Offline
      hmm, somehow it is passing a bad vector parameter to the offset script I think.
      An example model would be helpful. Could you upload a small test model that is not working right? Thanks!
        Avec comme unité les mètres
        Essaie avec ces valeur avec une figure qui fait au minimum 100 m par 100 par 100 m !
        Pour avoir une extrusion continue
        Il faut répondre oui à la question pour faire un "group" de la boite de dialogue une fois le plug lancé
        Exploser le groupe résultat et recommencer 😉
          About the repetition from the last action : now we must make that
          Select faces
          begin
          Grebble with "Yes I want grouping the all topmost faces"
          • else any faces will be not selected for a next grebbling 😲
            Result
            Explode group = new topmost faces selected ☀
            goto begin
          it's possible but a little painful 😉
          Vieria Da Silva inspiration (cool gallery zoom possible) ☀
          Another thing: using the new plug of Selection aera by Sdmitch on a complex Greeble volume
          Some faces are selected as wished, but the Greebble makes nothing 😮
          Have you some tests inside Grebble for exit if some faces are in particular positions (overlapsed) ?
          (make nothing also with normal selection 😒
            Pout
            Hey Chris, haven't look at it but i read in the previous version of this plugin that you planned on integrating a cancel button to cancel script execution.
            Did you find a solution for this?
            Thx
              No, this was one of the first scripts I ever wrote and I probably said that before I knew how how hard that can be to do. I really never even tried to do it though.
              • E Offline
                El_Sexto
                Hi guys ! somebody have the solution for the bertier problem plz ?
                  Bertier never posted his problem SKP or anything further to help us, so it went no further...
                  If you are experiencing similar problems then please post the full error messages from the Ruby Console etc, and a copy of a SKP that displays this aberrant behavior... 😕
                  • E Offline
                    El_Sexto
                    Ok
                    Ruby Message : #Sketchup::Face:0xcc62710 did not offset:
                    Error: #<NoMethodError: undefined method normal' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:250:in greeble'
                    C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:223:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:223:in greeble'
                    C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:294
                    C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:250:in `call'
                    I used Sketchup 8, meters dimension and i use the Pilou's setting : 10,-10 ... and the Default setting, 1',-1'... and i have the same result : Anything !
                    Thanx.
                    model.skp
                      What did you type to make it offset? I think it is does not work very well with meters, and might not work at all with comma's as decimal place deliminators. Meaning 1,2 should be written as 1.2 if you are from a part of the world that uses a comma as a decimal place.
                        No problem with your model Model.SKP! (in V8) Works like a charm! 😎 (I am on PC)
                        Greeble buildings are just in the other side 😉
                        Are you sure you have also in the plugins folder
                        Progress bar and Offset?
                        • E Offline
                          El_Sexto
                          Thanx guys for your answer !
                          Pilou : u can see the folder, offset and progressbar are here.
                          Chris :in this model i have not deliminators; see the attachment, 10,10,-2,-2,0,100 and i have also use the default and Pilou valuesplugin folder
                          first step
                          second step
                          third step
                          4th step
                            masterplan
                            it doesnt work for me. ❓
                              Masterplan (welcome, BTW) please, be more specific. What are you doing exactly and what do you expect? Is there any error message? Maybe attach a file that "does not work for you" or something.
                              For a sentence "it does not work for me" one can only answer "well that sucks". Give as much info as possible otherwise you will be left hanging...
                                @ El-sexto
                                That is very mysterious 😲
                                What can I say? That works for me with your model with your version of SU 🤓
                                Does this version the last one ?
                                Have you try with a previous version of SU ?
                                • E Offline
                                  El_Sexto
                                  Yes I tried with sketchup 7 - Maybe i should try with the version 1 ... 🤓
                                    Do you get any better results if you lift the geometry off the groundplane?
                                    Just to verify (again), but you do have the most recent greeble and offset scripts from http://www.smustard.com?
                                    What language is your Operating System set to?
                                    I'll see if I can test this later tonight, sorry its not working!
                                      Make just a test from a cube!
                                      Select the top face and launch the plug...
                                      here i call it twice with thes same entries
                                      SU 6, last version of greeble
                                      Not sure of the units used "inside" the Plugin (maybe royal units )
                                      My unit "outside" the plug is meter with 2 decimals
                                      I input in the box dialog number without unit
                                        corgano
                                        I am getting the same error that was posted by El_Sexto on Thu Oct 06, 2011 6:59 am. I have downloaded and re-downloaded the files from smustard with no effect. It doesn't matter what I try to do it on, it never works. I'm running on win 7 64 bit, and the only important thing i have installed is vray for sketchup. Everything else is normal.
                                          So use Protrude by Jim Foltz waiting Chris Fullmer debuging (if bug exists that is not proved) 😉
                                          http://forums.sketchucation.com/download/file.php?id=70532&t=1
                                          http://forums.polyloop.net/picture.php?albumid=23&pictureid=545
                                          http://forums.sketchucation.com/download/file.php?id=70534
                                            Hmm, I'll re-download the files and install from scratch when I get some time. Currently that is not looking like any time soon though. Its been about 2 weeks of near all-nighters 👊 I've not got much capacity to look into it at the moment.
                                            • 4 / 5
