    [Plugin] Greeble 2 released! (Updated August 31st, 2009)
    94 Posts 24 Posters 84.3k Views 24 Watching
    • Chris FullmerC Offline
      Pilou, you crack me up! Great stuff as always.
      PS - what is your artistic style called, with all the vibrant colors and nonsensical shapes? I thought I remembered you using a term once that I found very interesting.
        Surely "Flashy" 💚 for the other term I don't remember. 😳
        Speedy Strange surreal geometrical attractor ? 😄
        Because I don't spend more ten minutes by scenes! 😒
        If you have 5 minutes you can see some Zbrush folish 😉
        (section Zibi Art )
        PS You have remarked that I have an immoderated use of your crazy "Random Painter" plug with SU 😉
          Bertier
          can't get no greeble 😞
            Go to SMustard 😉 (it's free)
              Bertier
              c'est installé avec tout ce qu'il faut mais ça ne fonctionne pas...
                Can you upload a simple model that you are trying to use it on that is not working? And also possibly open the Ruby Console (from the Window menu) and then run the plugin and see if it displays any errors there. Please paste those errors here.
                This script does not always behave well...
                  Bertier
                  set to meters as Pilou suggested
                  trying to greeble a simple 100 x 100 square :
                  #Sketchup::Face:0x24e2b624 did not offset:
                  Error: #<NoMethodError: undefined method normal' for nil:NilClass> C:/Program Files/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:250:in greeble'
                  C:/Program Files/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:223:in each' C:/Program Files/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:223:in greeble'
                  C:/Program Files/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:294
                  C:/Program Files/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:250:in `call'
                    Bertier
                    The error in line #250 is when it tries to get a normal new_vector = cl_newface.normal and the face cl_newface doesn't exist.
                    It is made by offsetting e which is one of clface[s] around lines #236 et al...
                    Not sure what's causing it... Chris?
                      Bertier
                      sound chinese to me...
                        hmm, somehow it is passing a bad vector parameter to the offset script I think.
                        An example model would be helpful. Could you upload a small test model that is not working right? Thanks!
                          Avec comme unité les mètres
                          Essaie avec ces valeur avec une figure qui fait au minimum 100 m par 100 par 100 m !
                          Pour avoir une extrusion continue
                          Il faut répondre oui à la question pour faire un "group" de la boite de dialogue une fois le plug lancé
                          Exploser le groupe résultat et recommencer 😉
                            About the repetition from the last action : now we must make that
                            Select faces
                            begin
                            Grebble with "Yes I want grouping the all topmost faces"
                            • else any faces will be not selected for a next grebbling 😲
                              Result
                              Explode group = new topmost faces selected ☀
                              goto begin
                            it's possible but a little painful 😉
                            Vieria Da Silva inspiration (cool gallery zoom possible) ☀
                            Another thing: using the new plug of Selection aera by Sdmitch on a complex Greeble volume
                            Some faces are selected as wished, but the Greebble makes nothing 😮
                            Have you some tests inside Grebble for exit if some faces are in particular positions (overlapsed) ?
                            (make nothing also with normal selection 😒
                              Pout
                              Hey Chris, haven't look at it but i read in the previous version of this plugin that you planned on integrating a cancel button to cancel script execution.
                              Did you find a solution for this?
                              Thx
                                No, this was one of the first scripts I ever wrote and I probably said that before I knew how how hard that can be to do. I really never even tried to do it though.
                                • E Offline
                                  El_Sexto
                                  Hi guys ! somebody have the solution for the bertier problem plz ?
                                    Bertier never posted his problem SKP or anything further to help us, so it went no further...
                                    If you are experiencing similar problems then please post the full error messages from the Ruby Console etc, and a copy of a SKP that displays this aberrant behavior... 😕
                                    • E Offline
                                      El_Sexto
                                      Ok
                                      Ruby Message : #Sketchup::Face:0xcc62710 did not offset:
                                      Error: #<NoMethodError: undefined method normal' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:250:in greeble'
                                      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:223:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:223:in greeble'
                                      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:294
                                      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:250:in `call'
                                      I used Sketchup 8, meters dimension and i use the Pilou's setting : 10,-10 ... and the Default setting, 1',-1'... and i have the same result : Anything !
                                      Thanx.
                                      model.skp
                                        What did you type to make it offset? I think it is does not work very well with meters, and might not work at all with comma's as decimal place deliminators. Meaning 1,2 should be written as 1.2 if you are from a part of the world that uses a comma as a decimal place.
                                          No problem with your model Model.SKP! (in V8) Works like a charm! 😎 (I am on PC)
                                          Greeble buildings are just in the other side 😉
                                          Are you sure you have also in the plugins folder
                                          Progress bar and Offset?
                                          • E Offline
                                            El_Sexto
                                            Thanx guys for your answer !
                                            Pilou : u can see the folder, offset and progressbar are here.
                                            Chris :in this model i have not deliminators; see the attachment, 10,10,-2,-2,0,100 and i have also use the default and Pilou valuesplugin folder
                                            first step
                                            second step
                                            third step
                                            4th step
                                            • 4 / 5
