    [Plugin] Greeble 2 released! (Updated August 31st, 2009)
    94 Posts 24 Posters 81.0k Views 24 Watching
      Pout
      Hey Chris, haven't look at it but i read in the previous version of this plugin that you planned on integrating a cancel button to cancel script execution.
      Did you find a solution for this?
      Thx
      • Chris FullmerC Offline
        No, this was one of the first scripts I ever wrote and I probably said that before I knew how how hard that can be to do. I really never even tried to do it though.
        • E Offline
          El_Sexto
          Hi guys ! somebody have the solution for the bertier problem plz ?
            Bertier never posted his problem SKP or anything further to help us, so it went no further...
            If you are experiencing similar problems then please post the full error messages from the Ruby Console etc, and a copy of a SKP that displays this aberrant behavior... πŸ˜•
            • E Offline
              El_Sexto
              Ok
              Ruby Message : #Sketchup::Face:0xcc62710 did not offset:
              Error: #<NoMethodError: undefined method normal' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:250:in greeble'
              C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:223:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:223:in greeble'
              C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:294
              C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_greeble_2.rb:250:in `call'
              I used Sketchup 8, meters dimension and i use the Pilou's setting : 10,-10 ... and the Default setting, 1',-1'... and i have the same result : Anything !
              Thanx.
              model.skp
                What did you type to make it offset? I think it is does not work very well with meters, and might not work at all with comma's as decimal place deliminators. Meaning 1,2 should be written as 1.2 if you are from a part of the world that uses a comma as a decimal place.
                  No problem with your model Model.SKP! (in V8) Works like a charm! 😎 (I am on PC)
                  Greeble buildings are just in the other side πŸ˜‰
                  Are you sure you have also in the plugins folder
                  Progress bar and Offset?
                  • E Offline
                    El_Sexto
                    Thanx guys for your answer !
                    Pilou : u can see the folder, offset and progressbar are here.
                    Chris :in this model i have not deliminators; see the attachment, 10,10,-2,-2,0,100 and i have also use the default and Pilou valuesplugin folder
                    first step
                    second step
                    third step
                    4th step
                      masterplan
                      it doesnt work for me. ❓
                        Masterplan (welcome, BTW) please, be more specific. What are you doing exactly and what do you expect? Is there any error message? Maybe attach a file that "does not work for you" or something.
                        For a sentence "it does not work for me" one can only answer "well that sucks". Give as much info as possible otherwise you will be left hanging...
                          @ El-sexto
                          That is very mysterious 😲
                          What can I say? That works for me with your model with your version of SU πŸ€“
                          Does this version the last one ?
                          Have you try with a previous version of SU ?
                          • E Offline
                            El_Sexto
                            Yes I tried with sketchup 7 - Maybe i should try with the version 1 ... πŸ€“
                              Do you get any better results if you lift the geometry off the groundplane?
                              Just to verify (again), but you do have the most recent greeble and offset scripts from http://www.smustard.com?
                              What language is your Operating System set to?
                              I'll see if I can test this later tonight, sorry its not working!
                                Make just a test from a cube!
                                Select the top face and launch the plug...
                                here i call it twice with thes same entries
                                SU 6, last version of greeble
                                Not sure of the units used "inside" the Plugin (maybe royal units )
                                My unit "outside" the plug is meter with 2 decimals
                                I input in the box dialog number without unit
                                  corgano
                                  I am getting the same error that was posted by El_Sexto on Thu Oct 06, 2011 6:59 am. I have downloaded and re-downloaded the files from smustard with no effect. It doesn't matter what I try to do it on, it never works. I'm running on win 7 64 bit, and the only important thing i have installed is vray for sketchup. Everything else is normal.
                                    So use Protrude by Jim Foltz waiting Chris Fullmer debuging (if bug exists that is not proved) πŸ˜‰
                                    http://forums.sketchucation.com/download/file.php?id=70532&t=1
                                    http://forums.polyloop.net/picture.php?albumid=23&pictureid=545
                                    http://forums.sketchucation.com/download/file.php?id=70534
                                      Hmm, I'll re-download the files and install from scratch when I get some time. Currently that is not looking like any time soon though. Its been about 2 weeks of near all-nighters πŸ‘Š I've not got much capacity to look into it at the moment.
                                        corgano
                                        Right, so I got the protrude plugin as you recommended. It works ecpt for the offset function. for some reason offset.rb is not offsetting the faces, so it isn't so much a problem with either Greeble or protrude, but with offset.rb. I will do more debugging on offset.rb to see if I can narrow it down...
                                        ~Corgano
                                          corgano
                                          Found the problem!
                                          Removing the begin....rescue -> end statement in offset.rb and trying again led me to line 61,
                                          61: vecs << vec
                                          It said that vec did not exist, and I noticed the cde before it was checking if vec3 was valid. I changed it to
                                          61: vecs << vec3
                                          and it worked!
                                          Note: This is for the Failed to create offset error. Other errors may not be related to this
                                            Jim
                                            Thanks corgano. I thought that this offset.rb bug had been fixed months ago, but maybe not. I've pinged Rick about it.
                                            • 4 / 5
