    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
    • R
      RobbieDingemanse
      Hello Fredo6, is the bezier spline plugin not ready for SU19? Because I can install it, but when I try to use Polyline Arc corners, it doesn't show the pop-up window for the input.
      • fredo6F
        fredo6
        Can you open the Ruby console before you launch Polyline Arc Corner and check if there are errors.
        Fredo
        • C
          Cenosha
          Fredo
          Fredo,
          I am working together with Robbie, this is the error code we get in the Ruby Console
          Error: #<NameError: uninitialized constant BZ__Arc::Traductor>
          /Users/cgs/Library/Application Support/SketchUp 2019/SketchUp/Plugins/bezierspline/BZ__Arc.rb:67:in bz_ask_extras' /Users/cgs/Library/Application Support/SketchUp 2019/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2058:in call'
          /Users/cgs/Library/Application Support/SketchUp 2019/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2058:in call_ask_extras' /Users/cgs/Library/Application Support/SketchUp 2019/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2109:in conversion_curve'
          /Users/cgs/Library/Application Support/SketchUp 2019/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2411:in `block (2 levels) in compute_contextual_menu'
          Richard
          • C
            Cenosha
            Fredo
            Fredo,
            Richard
            Fredo,
            any idea how we can fix this ?
            • TIGT
              Fredo has yet to reply, but the error message clearly points to line #67 in one of the loading files [ ../Plugins/bezierspline/BZ__Arc.rb], where it can't find the defined code for ' Traductor'.
              When it's trying to run:
              Traductor::DialogBox.new TTH_Title
              This is a shared 'translation' module - it is an Extension created by LibFredo - which is an Extension set up by a separate installation.
              So ensure that you also have its RBZ downloaded, installed and its Extension enabled in the Extensions Manager...
              It's available from the PluginStore...
              https://sketchucation.com/pluginstore?pln=LibFredo6
              Restart SketchUp after it is installed/enabled to ensure that everything gets properly synced...
              • fredo6F
                fredo6
                @Cenosha
                Normally, this should not happen with the latest version BezierSpline 2.1a.
                Otherwise, just install LibFredo6, latest version, and this should work fine.
                Fredo
                • C
                  Cenosha
                  Guys,
                  With the LibFredo6 installed the problem is gone!
                  Thanks!
                  • N
                    nocoloDean
                    1st and only post.
                    What an absolute ABORTION trying to get Bezierspline loaded into Sketchup 2014.
                    Still haven't managed. It says it's loaded in Sketchucation's plugin manager, but it's not showing up in Prefs/Extensions, nor is it showing up in the program.
                    What a mess. How hard can it be? Install > use.
                    • TIGT
                      SketchUp version 2014 is old.
                      Support from SketchUp only extends back to v2017.
                      Some Extensions' authors allow backward compatible to v8, and reading this tool's guide it should be OK...
                      An oddity in your error message suggests that it's been NOT installed properly.
                      Usually the installation path is...
                      C:\Users\YOUR_USER_NAME\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
                      So how did you install this toolset exactly ?
                      How is it that SketchUp is trying to load it from here ?
                      C:\Documents and Settings\user\Application Data\SketchUp\SketchUp 2014\SketchUp\Plugins
                      What is your current Windows OS ?
                      Please fill in your Profile properly...
                      It might well be incompatible ?
                      Many users have this tool installed successfully in many SketchUp versions.
                      Starting off "on an aggressive preemptive attack" might work in wing chung, but when your are asking for advice or help, then a more conciliatory tone often attracts a more sympathetic and helpful response... 😲
                      • fredo6F
                        fredo6
                        This is related with the non-ascii deficiencies of old Sketchup versions in some Windows configurations, and there is nothing that can be done (except to migrate to newer versions).
                        Fredo
                        • L
                          LisaG
                          Just downloaded LibFredo6 plugin for SketchUp Make V2017. The installation is not yet complete as under Preferences there is no "Extensions" listed. Not sure where else to find it!
                          Thanks.
                            Thanks.
                            LibFredo6 appears in the Window menu and Bezier Spline Curves appears in the Draw menu. Did you look there?
                            • A
                              Ahmed0007
                              Polyline segmentor is not working in sketchup 2020?
                                It worked for me just now in 2020.
                                • A
                                  Ahmed0007
                                  [attachment=1:37qeug7g]<!-- ia1 -->Screenshot - 2_2_2020 , 3_59_21 PM.png<!-- ia1 -->[/attachment:37qeug7g]
                                  Thanks for quick response.
                                  but not working for me 😞
                                  .Gif
                                  • BoxB
                                    Do you have the most up to date Libfredo?
                                    • fredo6F
                                      fredo6
                                      @Ahmed0007
                                      Normally, when you convert to Segmentor, you should have a dialog box popping up (asking for number of segments).
                                      Could you open the Ruby console while you invoke the convert.
                                      Fredo
                                      • A
                                        Ahmed0007
                                        yes.
                                        • A
                                          Ahmed0007
                                          @fredo6 said:
                                          @Ahmed0007
                                          Fredo
                                          Error: #<NameError: uninitialized constant BZ__Segmentor::Traductor>
                                          C:/Users/Ahmed/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/bezierspline/BZ__Segmentor.rb:72:in bz_ask_extras' C:/Users/Ahmed/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2058:in call'
                                          C:/Users/Ahmed/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2058:in call_ask_extras' C:/Users/Ahmed/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2109:in conversion_curve'
                                          C:/Users/Ahmed/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/bezierspline/bezierspline_main.rb:2411:in `block (2 levels) in compute_contextual_menu'
                                          Thanks for Respond
                                          • fredo6F
                                            fredo6
                                            Can you check if in your plugin directory, subfolder bezierspline, you have a file called LibTraductor.rb.
                                            If not, can you download beizerspline v2.1a.
                                            Also, you should delete any file LibTraductor.rb which would be in the main Plugin directory.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 22 / 23
