    [Plugin] follow me rotate
    211 Posts 79 Posters 260.3k Views 79 Watching
    • brookefoxB Offline
      brookefox
      The renaming (and re-starting SU, as opposed to just re-loading the scripts) worked, but behavior is erratic. (I didn't want to trouble you further, Chris, if I could make the re-naming work.)
      First 4 images show a failure with a welded straight path (called a curve by SU) and a rectangular face.
      Second 4 show success with a truly (apparently) curved path and a round face.
      The final image shows the SU upload dialog which leads one to believe you can upload more than one attachment at a time but which then ignores the request.
      ~ Brooke
        SUFractal
        This FAR script does not work for me at all ... HELP!
          Please post some files or image or message error ... 😉
          • charly2008C Offline
            charly2008
            I had forgotten this plugin because it almost never worked properly. This time it has worked once, but only after I had divided the line and rewelded it.
            Then came back the error message shown in Ruby box .
            So for me it only works if the line has been previously divided and re-welded.
            Charly
              charly2008
              So again, the correct workflow.
              • Draw a line and divide the line (If it is a curve than explode and weld)
              • Weld the line
              • Select Face and Line
              • Start FAR
              This should work for all.
              Charly
                SUFractal
                Charly:
                I've had trouble with this plugin along a straight line as many have posted here (on a Mac w/ 10.6). Tried your suggestions of dividing line and welding but no luck. In fact the line doesn't even "weld". Curved lines seem fine and while "fun", a straight line is also needed more often than not for many hoping to use this tool.
                Thoughts/further suggestions?
                  charly2008
                  Please try it with the attached file. Only select the face and the line.
                  Charly
                  Untitled.skp
                  • dfswyfD Offline
                    dfswyf
                    @wikii said:
                    It is still in developing, here is the current version.
                    This is amazing! Thank you so much!
                      Marwan
                      I still have problems with this ... please can u help me how to fixed t 😢
                      ____________________________________________________________________________ "[i:2c0yhog7][b:2c0yhog7]There is no god but He[/b:2c0yhog7][/i:2c0yhog7] : That is the witness of [b:2c0yhog7]God[/b:2c0yhog7], His angels, and those endued with knowledge, standing firm on justice. There is no god but He, the Exalted in Power, the Wise."
                        SUFractal
                        This Plugin sure appears to be problematic and doesn't seem to work no matter I've tried (based on other posts here).
                        I'm appreciative of its creator's efforts, but frustrated that it isn't stable or bug-free.
                          shoeb_cars
                          i love it 😎 thanks
                          • E Offline
                            emanuelson87
                            @solo said:
                            I have tried that without anything happening.
                            Hello I have the same problem I can not run this plugin you could tell me how you solved it? thanks
                              charly2008
                              It works normally only with a face and a curve. If you want to use it with a straight line than have look at page 5 of this topic. ThereEcuadorian shows a tutorial video.
                              Charly
                                brookefox
                                I have a 3d helix as a curve and a circular face, but the results ain't right. Any tips?
                                ~ Brooke
                                  brookefox
                                  Results with a 2d spiral:
                                  ~ Brooke
                                    Better if surface is drawn on the ground (Flat) as a top view as the helix is vertical
                                    but not obliged in theory any orientations can be made
                                    Seems your examples fail because of the Construction Point is out of the surface!
                                    You can add a Construction Point on the surface By the Didier Bur Projection
                                    http://www.pushpullbar.com/forums/attachment.php?attachmentid=45446&stc=1&d=1223643779
                                    Images following by Takesh
                                    http://www.pushpullbar.com/forums/attachment.php?attachmentid=45450&stc=1&d=1223648103
                                    http://www.pushpullbar.com/forums/attachment.php?attachmentid=45506&stc=1&d=1223954760
                                      brookefox
                                      Thank you for your very helpful help. I will try to implement it.
                                      ~ Brooke
                                        brookefox
                                        It's a start!
                                        ~ Brooke
                                          Looks like a drogue to drag behind a boat. 😄
                                          • mitcorbM Offline
                                            mitcorb
                                            Do you have to group the polygon first? No?
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 6 / 11
