    [Plugin] follow me rotate
    211 Posts 79 Posters 274.1k Views 79 Watching
    • charly2008C Offline
      charly2008
      So again, the correct workflow.
      • Draw a line and divide the line (If it is a curve than explode and weld)
      • Weld the line
      • Select Face and Line
      • Start FAR
      This should work for all.
      Charly
        SUFractal
        Charly:
        I've had trouble with this plugin along a straight line as many have posted here (on a Mac w/ 10.6). Tried your suggestions of dividing line and welding but no luck. In fact the line doesn't even "weld". Curved lines seem fine and while "fun", a straight line is also needed more often than not for many hoping to use this tool.
        Thoughts/further suggestions?
          charly2008
          Please try it with the attached file. Only select the face and the line.
          Charly
          Untitled.skp
          • dfswyfD Offline
            dfswyf
            @wikii said:
            It is still in developing, here is the current version.
            This is amazing! Thank you so much!
              Marwan
              I still have problems with this ... please can u help me how to fixed t 😢
              ____________________________________________________________________________ "[i:2c0yhog7][b:2c0yhog7]There is no god but He[/b:2c0yhog7][/i:2c0yhog7] : That is the witness of [b:2c0yhog7]God[/b:2c0yhog7], His angels, and those endued with knowledge, standing firm on justice. There is no god but He, the Exalted in Power, the Wise."
                SUFractal
                This Plugin sure appears to be problematic and doesn't seem to work no matter I've tried (based on other posts here).
                I'm appreciative of its creator's efforts, but frustrated that it isn't stable or bug-free.
                  shoeb_cars
                  i love it 😎 thanks
                  • E Offline
                    emanuelson87
                    @solo said:
                    I have tried that without anything happening.
                    Hello I have the same problem I can not run this plugin you could tell me how you solved it? thanks
                      charly2008
                      It works normally only with a face and a curve. If you want to use it with a straight line than have look at page 5 of this topic. ThereEcuadorian shows a tutorial video.
                      Charly
                      • brookefoxB Offline
                        brookefox
                        I have a 3d helix as a curve and a circular face, but the results ain't right. Any tips?
                        ~ Brooke
                          brookefox
                          Results with a 2d spiral:
                          ~ Brooke
                            Better if surface is drawn on the ground (Flat) as a top view as the helix is vertical
                            but not obliged in theory any orientations can be made
                            Seems your examples fail because of the Construction Point is out of the surface!
                            You can add a Construction Point on the surface By the Didier Bur Projection
                            http://www.pushpullbar.com/forums/attachment.php?attachmentid=45446&stc=1&d=1223643779
                            Images following by Takesh
                            http://www.pushpullbar.com/forums/attachment.php?attachmentid=45450&stc=1&d=1223648103
                            http://www.pushpullbar.com/forums/attachment.php?attachmentid=45506&stc=1&d=1223954760
                              brookefox
                              Thank you for your very helpful help. I will try to implement it.
                              ~ Brooke
                                brookefox
                                It's a start!
                                ~ Brooke
                                  Looks like a drogue to drag behind a boat. 😄
                                  • mitcorbM Offline
                                    mitcorb
                                    Do you have to group the polygon first? No?
                                      Your result is normal 😉
                                      Scale 0.2 signify 1/5 at each segment generation!
                                      so
                                      1, 0.2, 0.04, 0.008...so toward very tiny very speedy 😉
                                      Take 0.95 if you want a more smooth reduction 😄
                                      PS Put a Construction Point at the center of the surface make nothing more! 😉
                                      This one must be excentered for make something funny!
                                        brookefox
                                        You pick the face and the path, face and curve, no group.
                                        Getting somewhere, at least.
                                        I'm sparing you the mis-starts, by which means I absolve myself of error.
                                        ~ Brooke
                                          brookefox
                                          I think that degrees of rotation and scaling over the entire path would be useful settings, saving much perhaps tedious calculation for the machine, which does it so much faster.
                                          ~ Brooke
                                            http://farm8.staticflickr.com/7085/6965349742_2e0f0c498b_z.jpg
                                            I had to play a little. 😉
                                            • 11
                                            • 6 / 11
