    [Plugin] follow me rotate
    211 Posts 79 Posters 280.1k Views 79 Watching
    • T
      tamfore
      is there a link for a text file or description and instructions on what this plugin does and how to use it?
      thanks
      Tamfore
        thanks
        Tamfore
        Select welded edges as path and a face before using this script.
        • K
          kostas_designer
          Cool!...
          Jeff: i think you are talking about the SCF POWERBAR:
          http://forums.sketchucation.com/viewtopic.php?f=180&t=14770&st=0&sk=t&sd=a&hilit=powertoolbar#p112024
            ayieartwork
            guys.how to rotate the shape from bigger to smaller?
            Intel Core i7-3930k with 16gb G.Skill Ripjaws
            • brookefoxB
              brookefox
              I unzip to plugins; get FollowAndRotate_cn.rbs, FollowAndRotate_en.rbs and inputbox.rb, which I must rename as I have a larger file of that name already (I put far.skp elsewhere). No plugins result in my pull down. I rename them *.rb and still nothing. Any tips?
              ~ Brooke
                you must keep names *.rbs!
                • brookefoxB
                  brookefox
                  OK, thanks, though they did not work that way ---> It dawned on me belatedly that I needed to provide for the re-naming or not of inbox.rb: if I rename it then I guess I need to go through the code and replace the old name with the new name wherever it occurs.
                  ~ Brooke
                  • Chris FullmerC
                    What? You already have a inputbox.rb? This plugin appears to have a file called that, as well as another plugin then? Do you know what other plugin supplied the other inputbox.rb? If you PM them both to me, I'll look at them and see if I can help un-entangle this issue. It will probably take more than just changing file names inside the script.
                    • brookefoxB
                      brookefox
                      Thanks, Chris.
                      Yes; yes. The three being: FollowAndRotate_cn.rbs, FollowAndRotate_en.rbs and inputbox.rb.
                      Both inputbox.rb open as below, but are different implementations:
                      Inputbox.rb Copyright 2008 jim.foltz@gmail.com
                      The Inputbox class makes it easy to create user input
                      dialogs by providing a consistent interface to UI.inputbox for
                      text fields and drop-down selection fields.
                      Checking the date stamps and my downloads leads to 2 DLs on 4.4.: inputbox and model_location.rb, which may or may not require input box (it has been snipped from some search result locations).
                      Certainly I can try renaming the existing to something else in order to see if that will enable FAR.
                      ~ Brooke
                      • brookefoxB
                        brookefox
                        The renaming (and re-starting SU, as opposed to just re-loading the scripts) worked, but behavior is erratic. (I didn't want to trouble you further, Chris, if I could make the re-naming work.)
                        First 4 images show a failure with a welded straight path (called a curve by SU) and a rectangular face.
                        Second 4 show success with a truly (apparently) curved path and a round face.
                        The final image shows the SU upload dialog which leads one to believe you can upload more than one attachment at a time but which then ignores the request.
                        ~ Brooke
                          SUFractal
                          This FAR script does not work for me at all ... HELP!
                            Please post some files or image or message error ... 😉
                            • charly2008C
                              charly2008
                              I had forgotten this plugin because it almost never worked properly. This time it has worked once, but only after I had divided the line and rewelded it.
                              Then came back the error message shown in Ruby box .
                              So for me it only works if the line has been previously divided and re-welded.
                              Charly
                              • charly2008C
                                charly2008
                                So again, the correct workflow.
                                • Draw a line and divide the line (If it is a curve than explode and weld)
                                • Weld the line
                                • Select Face and Line
                                • Start FAR
                                This should work for all.
                                Charly
                                  SUFractal
                                  Charly:
                                  I've had trouble with this plugin along a straight line as many have posted here (on a Mac w/ 10.6). Tried your suggestions of dividing line and welding but no luck. In fact the line doesn't even "weld". Curved lines seem fine and while "fun", a straight line is also needed more often than not for many hoping to use this tool.
                                  Thoughts/further suggestions?
                                  • charly2008C
                                    charly2008
                                    Please try it with the attached file. Only select the face and the line.
                                    Charly
                                    Untitled.skp
                                    • dfswyfD
                                      dfswyf
                                      @wikii said:
                                      It is still in developing, here is the current version.
                                      This is amazing! Thank you so much!
                                        Marwan
                                        I still have problems with this ... please can u help me how to fixed t 😢
                                        ____________________________________________________________________________ "[i:2c0yhog7][b:2c0yhog7]There is no god but He[/b:2c0yhog7][/i:2c0yhog7] : That is the witness of [b:2c0yhog7]God[/b:2c0yhog7], His angels, and those endued with knowledge, standing firm on justice. There is no god but He, the Exalted in Power, the Wise."
                                          SUFractal
                                          This Plugin sure appears to be problematic and doesn't seem to work no matter I've tried (based on other posts here).
                                          I'm appreciative of its creator's efforts, but frustrated that it isn't stable or bug-free.
                                            shoeb_cars
                                            i love it 😎 thanks
                                            • 11
                                            • 6 / 11
