    [Plugin] follow me rotate
    211 Posts 79 Posters 261.7k Views 79 Watching
      SUFractal
      This FAR script does not work for me at all ... HELP!
        Please post some files or image or message error ... 😉
        • charly2008C Offline
          charly2008
          I had forgotten this plugin because it almost never worked properly. This time it has worked once, but only after I had divided the line and rewelded it.
          Then came back the error message shown in Ruby box .
          So for me it only works if the line has been previously divided and re-welded.
          Charly
            charly2008
            So again, the correct workflow.
            • Draw a line and divide the line (If it is a curve than explode and weld)
            • Weld the line
            • Select Face and Line
            • Start FAR
            This should work for all.
            Charly
              SUFractal
              Charly:
              I've had trouble with this plugin along a straight line as many have posted here (on a Mac w/ 10.6). Tried your suggestions of dividing line and welding but no luck. In fact the line doesn't even "weld". Curved lines seem fine and while "fun", a straight line is also needed more often than not for many hoping to use this tool.
              Thoughts/further suggestions?
                charly2008
                Please try it with the attached file. Only select the face and the line.
                Charly
                Untitled.skp
                • dfswyfD Offline
                  dfswyf
                  @wikii said:
                  It is still in developing, here is the current version.
                  This is amazing! Thank you so much!
                    Marwan
                    I still have problems with this ... please can u help me how to fixed t 😢
                    ____________________________________________________________________________ "[i:2c0yhog7][b:2c0yhog7]There is no god but He[/b:2c0yhog7][/i:2c0yhog7] : That is the witness of [b:2c0yhog7]God[/b:2c0yhog7], His angels, and those endued with knowledge, standing firm on justice. There is no god but He, the Exalted in Power, the Wise."
                      SUFractal
                      This Plugin sure appears to be problematic and doesn't seem to work no matter I've tried (based on other posts here).
                      I'm appreciative of its creator's efforts, but frustrated that it isn't stable or bug-free.
                        shoeb_cars
                        i love it 😎 thanks
                        • E Offline
                          emanuelson87
                          @solo said:
                          I have tried that without anything happening.
                          Hello I have the same problem I can not run this plugin you could tell me how you solved it? thanks
                            charly2008
                            It works normally only with a face and a curve. If you want to use it with a straight line than have look at page 5 of this topic. ThereEcuadorian shows a tutorial video.
                            Charly
                            • brookefoxB Offline
                              brookefox
                              I have a 3d helix as a curve and a circular face, but the results ain't right. Any tips?
                              ~ Brooke
                                brookefox
                                Results with a 2d spiral:
                                ~ Brooke
                                  Better if surface is drawn on the ground (Flat) as a top view as the helix is vertical
                                  but not obliged in theory any orientations can be made
                                  Seems your examples fail because of the Construction Point is out of the surface!
                                  You can add a Construction Point on the surface By the Didier Bur Projection
                                  http://www.pushpullbar.com/forums/attachment.php?attachmentid=45446&stc=1&d=1223643779
                                  Images following by Takesh
                                  http://www.pushpullbar.com/forums/attachment.php?attachmentid=45450&stc=1&d=1223648103
                                  http://www.pushpullbar.com/forums/attachment.php?attachmentid=45506&stc=1&d=1223954760
                                    brookefox
                                    Thank you for your very helpful help. I will try to implement it.
                                    ~ Brooke
                                      brookefox
                                      It's a start!
                                      ~ Brooke
                                        Looks like a drogue to drag behind a boat. 😄
                                        • mitcorbM Offline
                                          mitcorb
                                          Do you have to group the polygon first? No?
                                            Your result is normal 😉
                                            Scale 0.2 signify 1/5 at each segment generation!
                                            so
                                            1, 0.2, 0.04, 0.008...so toward very tiny very speedy 😉
                                            Take 0.95 if you want a more smooth reduction 😄
                                            PS Put a Construction Point at the center of the surface make nothing more! 😉
                                            This one must be excentered for make something funny!
                                            • 11
                                            • 6 / 11
