    [Plugin] follow me rotate
    211 Posts 79 Posters 280.0k Views 79 Watching
    • charly2008C
      charly2008
      I had forgotten this plugin because it almost never worked properly. This time it has worked once, but only after I had divided the line and rewelded it.
      Then came back the error message shown in Ruby box .
      So for me it only works if the line has been previously divided and re-welded.
      Charly
      • charly2008C
        charly2008
        So again, the correct workflow.
        • Draw a line and divide the line (If it is a curve than explode and weld)
        • Weld the line
        • Select Face and Line
        • Start FAR
        This should work for all.
        Charly
          SUFractal
          Charly:
          I've had trouble with this plugin along a straight line as many have posted here (on a Mac w/ 10.6). Tried your suggestions of dividing line and welding but no luck. In fact the line doesn't even "weld". Curved lines seem fine and while "fun", a straight line is also needed more often than not for many hoping to use this tool.
          Thoughts/further suggestions?
          • charly2008C
            charly2008
            Please try it with the attached file. Only select the face and the line.
            Charly
            Untitled.skp
            • dfswyfD
              dfswyf
              @wikii said:
              It is still in developing, here is the current version.
              This is amazing! Thank you so much!
                Marwan
                I still have problems with this ... please can u help me how to fixed t 😢
                ____________________________________________________________________________ "[i:2c0yhog7][b:2c0yhog7]There is no god but He[/b:2c0yhog7][/i:2c0yhog7] : That is the witness of [b:2c0yhog7]God[/b:2c0yhog7], His angels, and those endued with knowledge, standing firm on justice. There is no god but He, the Exalted in Power, the Wise."
                  SUFractal
                  This Plugin sure appears to be problematic and doesn't seem to work no matter I've tried (based on other posts here).
                  I'm appreciative of its creator's efforts, but frustrated that it isn't stable or bug-free.
                    shoeb_cars
                    i love it 😎 thanks
                    • E
                      emanuelson87
                      @solo said:
                      I have tried that without anything happening.
                      Hello I have the same problem I can not run this plugin you could tell me how you solved it? thanks
                      • charly2008C
                        charly2008
                        It works normally only with a face and a curve. If you want to use it with a straight line than have look at page 5 of this topic. ThereEcuadorian shows a tutorial video.
                        Charly
                        • brookefoxB
                          brookefox
                          I have a 3d helix as a curve and a circular face, but the results ain't right. Any tips?
                          ~ Brooke
                          • brookefoxB
                            brookefox
                            Results with a 2d spiral:
                            ~ Brooke
                              Better if surface is drawn on the ground (Flat) as a top view as the helix is vertical
                              but not obliged in theory any orientations can be made
                              Seems your examples fail because of the Construction Point is out of the surface!
                              You can add a Construction Point on the surface By the Didier Bur Projection
                              http://www.pushpullbar.com/forums/attachment.php?attachmentid=45446&stc=1&d=1223643779
                              Images following by Takesh
                              http://www.pushpullbar.com/forums/attachment.php?attachmentid=45450&stc=1&d=1223648103
                              http://www.pushpullbar.com/forums/attachment.php?attachmentid=45506&stc=1&d=1223954760
                              • brookefoxB
                                brookefox
                                Thank you for your very helpful help. I will try to implement it.
                                ~ Brooke
                                • brookefoxB
                                  brookefox
                                  It's a start!
                                  ~ Brooke
                                    Looks like a drogue to drag behind a boat. 😄
                                    • mitcorbM
                                      mitcorb
                                      Do you have to group the polygon first? No?
                                        Your result is normal 😉
                                        Scale 0.2 signify 1/5 at each segment generation!
                                        so
                                        1, 0.2, 0.04, 0.008...so toward very tiny very speedy 😉
                                        Take 0.95 if you want a more smooth reduction 😄
                                        PS Put a Construction Point at the center of the surface make nothing more! 😉
                                        This one must be excentered for make something funny!
                                        • brookefoxB
                                          brookefox
                                          You pick the face and the path, face and curve, no group.
                                          Getting somewhere, at least.
                                          I'm sparing you the mis-starts, by which means I absolve myself of error.
                                          ~ Brooke
                                          • brookefoxB
                                            brookefox
                                            I think that degrees of rotation and scaling over the entire path would be useful settings, saving much perhaps tedious calculation for the machine, which does it so much faster.
                                            ~ Brooke
                                            • 11
                                            • 6 / 11
