    Seamless pattern repeats wrongly on curved surface :(
    8 Posts 5 Posters 1.4k Views 5 Watching
    • N Offline
      Norke
      Heya,
      I've push-pulled a pillar out of a half circle. I created a seamless marble pattern, but when I paint that over the pillar, some parts aren't positioned correctly. (see the red arrows on the picture) Does anybody knows how to fix this?
      http://img255.imageshack.us/img255/5389/councilhallpillarsk5.th.jpg
      Thx ahead fella's. πŸ˜„
      • FrederikF Offline
        Frederik
        You should check out the [Plugin] UVTools v0.1... πŸ˜‰
        Cheers
        Kim Frederik
        • N Offline
          Norke
          Thx a lot Frederik! I tested it out and it works. It renders it a little bit different, but it's seamless now.
          Thanks again
          • plot-parisP Offline
            plot-paris
            to be able to export it to render engies correctly (at least with indigo) you need to triangulate all faces. if you have the subdivide & smooth plugin, simply subdivide it and every face will be triangulated...
              Doesn't skindigo automatically triangulates the faces/facets?
              SU2KT does (and preserves UV maps).
                plot-paris
                I don't think so, because when the UV Tool plugin came out, triangulating faces was the only way to make it work in indigo.
                but I have to admit, that I have now idea 😳 Whaat? can you help us? πŸ˜‰
                  Well, and I have no idea about indigo (yet) 😳
                    remus
                    Another way to sort the textures out natively is to turn on hidden geometry (view->hidden geometry) then sample the texture on the main face and paint it on to every other face. Probably a lot easier to use the UV plugin for anything with lots of faces though, as painting every face can get a bit boring.
