    [Plugin] Component Spray Tool 1.3.
    92 Posts 44 Posters 97.2k Views 44 Watching
      If you read the PDF help file you'd see that Component Spray Tool is accessed from a pop-out menu in Draw Menu NOT the Plugins Menu !CStool.png
        rangrstudio
        @tig said:
        If you read the PDF help file you'd see that Component Spray Tool is accessed from a pop-out menu in Draw Menu NOT the Plugins Menu ![attachment=0:2qfvuyqu]<!-- ia0 -->CStool.png<!-- ia0 -->[/attachment:2qfvuyqu]
        Thank you! I guess I should read the whole manual...
        This is an amazing tool.
        • FrederikF Offline
          Frederik
          This is a GREAT tool...
          Would it be possible to make an option, where components sprayed don't intersect with each other...??
          It's possible to prevent stacking, but I miss an option, where components don't intersect also...
          Perhaps even an option, where I can define how close components can be to each other...
          Could have both positive and negative entries...
          Any ideas...??
          Cheers
          Kim Frederik
          • soloS Offline
            solo
            Yes please, I have the same issue where I need to mass some proxies but the boxes I'm using are all stacked and intersecting, maybe a collision checkbox?
            http://www.solos-art.com
              csolar
              I've just installed this (SU 7.1, WinXP), and I have a question about the spray pressure parameter. In the user guide it says that the # of components dropped is calculated as:
              [area of surface]/[average area of component(s)]*[spray pressure]
              In my case, the surface is a 10x10 square, and the component is a 1x1 square -- so the surface is 100 times the component area. If I select a spray pressure of 10%, I would expect 10 components to be dropped, but what I get is 100 components. Basically this calculation seems to be off by a factor of 10: if I ask for 100% pressure, then 1000 components get dropped, and so on.
              Am I missing something? I ask because for my model I really need lower densities; i.e. in line with the calculation described in the guide.
              Thanks,
              Chris.
                csolar
                Another observation:
                I select "random rotate", but when I look at the results it's clear that only 6 specific rotation angles are being used...actually more like 3 pairs of angles, 120 degrees apart, with the items in each pair being 8 degrees apart. Is this expected?
                Thanks, Chris.
                • Didier BurD Offline
                  Didier Bur
                  Hi csolar,
                  Do you have set any angle snapping ?
                  DB
                  • FrederikF Offline
                    Frederik
                    Hi Didier,
                    Any chance of adding what Solo and I have requested...??
                    Cheers
                    Kim Frederik
                      csolar
                      I did, but the results are the same after I turned off angle snapping.
                        Didier Bur
                        Yes. The only question is: when ? 😕
                        DB
                        • FrederikF Offline
                          Frederik
                          @didier bur said:
                          Yes.
                          Hopefully soon...
                          Cheers
                          Kim Frederik
                            Didier:
                            If you replace the native model.raytest with this method the rays won't stop on invisible entities:
                              # Raytrace method that does not stop on hidden entities.
                              def self.raytest(ray)
                                model = Sketchup.active_model
                                vector = ray[1]
                                while true
                                  # Shot ray
                                  test = model.raytest(ray)
                                  return nil if test.nil?
                                  # Verify visibility
                                  point, path = test
                                  if path.all? { |e| e.visible? && e.layer.visible? }
                                    return test
                                  else
                                    # raytest stopped on a hidden entity - create a new ray from that point
                                    # and let the loop continue until it hits something visible, or nothing.
                                    ray = [ point, vector ]
                                end # while
                              Didier Bur
                              Hi tt,
                              DB
                              • I Offline
                                inbal
                                thank so much 😄
                                  lapx
                                  Problems with component spray tool...Tool will not pick point after clicking.
                                  Is anyone else have problems with the tool? All the parameters appear correct.
                                  I'm placing byce on a simple plane is not working. Openig a new drawing helped but it always goes back to not working at some point.
                                  I'm using in V6.
                                  • charly2008C Offline
                                    charly2008
                                    I wanted to try compo spray but I get a huge number of components at a small circle. What am I doing wrong?
                                    Charly
                                      Didier Bur
                                      Did you draw a great circle (20m or so) or a small one (2m or so) ?
                                      But don't worry, since FaceMe components don't really have a bounding box, the number of components to be created is wrong, if I remember well...
                                      Regards,
                                      DB
                                        charly2008
                                        Hi Didier,
                                        The circle was about three meters. I tried the whole day. If i use it at a single line or a point then i get very small copies.
                                        Charly
                                        Untitled.skp
                                          charly2008
                                          For the above mentioned problem i found the solution. The values for Low and high scale where to less.
                                          But now although Keep vertical is selected, the tree is horizontal. For this I could not find the reason.
                                          Charly
                                            charly2008
                                            I found the error. This component was the reason. After I exploded the component and made it a new component, the error was gone.
                                            Charly
                                            • 4 / 5
