    [Plugin] Component Spray Tool 1.3.
    92 Posts 44 Posters 103.6k Views 44 Watching
      maymay
      I get an error when SketchUp starts:
      Error Loading File compo_spray.rb
      C;/Program Files/Google/Google SketchUp 6/Plugins/compo_spray.rb;1; no .<digit> floating literal anymore; put 0 before dot
      RBS1.0
      C;/Program Files/Google/Google SketchUp 6/Plugins/compo_spray.rb;1; syntax error
      RBS1.0
      C;/Program Files/Google/Google SketchUp 6/Plugins/compo_spray.rb;1; Invalid char `\030' in expression
      Any ideas? I'd really like to try this out.
      • Didier BurD
        Didier Bur
        Hem, hem, it seems we have some problems with the scrambler now...
        I've uploaded the latest RB version, in which there's NO progressbar class. I suppose there's a conflict with another plugin than this one.
        Sorry for the inconvenience with the RBS.
        Regards,
        DB
          rangrstudio
          Hi I'm trying to install this on Mac with Sketchup 7.
          The compo_spray.rb is in the Plugins folder, but I'm not seeing it in the plugins menu. Have reinstalled SKP 7 from scratch, then unzipped the zip file in the plug-ins folder per instructions but nothing.
          Is it not mac compatible?
          EDIT: I tried it on a windows machine (XP with SKP 7) and I couldn't get it to work there either. The zip contains "compo_spray.rb" and the pdf file. Is there something missing? Thanks for any help.
            If you read the PDF help file you'd see that Component Spray Tool is accessed from a pop-out menu in Draw Menu NOT the Plugins Menu !CStool.png
              rangrstudio
              @tig said:
              If you read the PDF help file you'd see that Component Spray Tool is accessed from a pop-out menu in Draw Menu NOT the Plugins Menu ![attachment=0:2qfvuyqu]<!-- ia0 -->CStool.png<!-- ia0 -->[/attachment:2qfvuyqu]
              Thank you! I guess I should read the whole manual...
              This is an amazing tool.
              • FrederikF
                Frederik
                This is a GREAT tool...
                Would it be possible to make an option, where components sprayed don't intersect with each other...??
                It's possible to prevent stacking, but I miss an option, where components don't intersect also...
                Perhaps even an option, where I can define how close components can be to each other...
                Could have both positive and negative entries...
                Any ideas...??
                Cheers
                Kim Frederik
                • soloS
                  Yes please, I have the same issue where I need to mass some proxies but the boxes I'm using are all stacked and intersecting, maybe a collision checkbox?
                  • C
                    csolar
                    I've just installed this (SU 7.1, WinXP), and I have a question about the spray pressure parameter. In the user guide it says that the # of components dropped is calculated as:
                    [area of surface]/[average area of component(s)]*[spray pressure]
                    In my case, the surface is a 10x10 square, and the component is a 1x1 square -- so the surface is 100 times the component area. If I select a spray pressure of 10%, I would expect 10 components to be dropped, but what I get is 100 components. Basically this calculation seems to be off by a factor of 10: if I ask for 100% pressure, then 1000 components get dropped, and so on.
                    Am I missing something? I ask because for my model I really need lower densities; i.e. in line with the calculation described in the guide.
                    Thanks,
                    Chris.
                    • C
                      csolar
                      Another observation:
                      I select "random rotate", but when I look at the results it's clear that only 6 specific rotation angles are being used...actually more like 3 pairs of angles, 120 degrees apart, with the items in each pair being 8 degrees apart. Is this expected?
                      Thanks, Chris.
                      • Didier BurD
                        Didier Bur
                        Hi csolar,
                        Do you have set any angle snapping ?
                        DB
                        • FrederikF
                          Frederik
                          Hi Didier,
                          Any chance of adding what Solo and I have requested...??
                          Cheers
                          Kim Frederik
                          • C
                            csolar
                            I did, but the results are the same after I turned off angle snapping.
                            • Didier BurD
                              Didier Bur
                              Yes. The only question is: when ? ๐Ÿ˜•
                              DB
                              • FrederikF
                                Frederik
                                @didier bur said:
                                Yes.
                                ๐Ÿ‘Š
                                Hopefully soon...
                                Cheers
                                Kim Frederik
                                  Didier:
                                  If you replace the native model.raytest with this method the rays won't stop on invisible entities:
                                    # Raytrace method that does not stop on hidden entities.
                                    def self.raytest(ray)
                                      model = Sketchup.active_model
                                      vector = ray[1]
                                      while true
                                        # Shot ray
                                        test = model.raytest(ray)
                                        return nil if test.nil?
                                        # Verify visibility
                                        point, path = test
                                        if path.all? { |e| e.visible? && e.layer.visible? }
                                          return test
                                        else
                                          # raytest stopped on a hidden entity - create a new ray from that point
                                          # and let the loop continue until it hits something visible, or nothing.
                                          ray = [ point, vector ]
                                      end # while
                                  • Didier BurD
                                    Didier Bur
                                    Hi tt,
                                    ๐Ÿ’ญ ๐Ÿ’ญ ๐Ÿ’ญ ๐Ÿ’ญ ๐Ÿ’ญ ๐Ÿ’ญ
                                    DB
                                    • I
                                      inbal
                                      thank so much ๐Ÿ˜„
                                      • L
                                        lapx
                                        Problems with component spray tool...Tool will not pick point after clicking.
                                        Is anyone else have problems with the tool? All the parameters appear correct.
                                        I'm placing byce on a simple plane is not working. Openig a new drawing helped but it always goes back to not working at some point.
                                        I'm using in V6.
                                        • charly2008C
                                          charly2008
                                          I wanted to try compo spray but I get a huge number of components at a small circle. What am I doing wrong?
                                          Charly
                                          • Didier BurD
                                            Didier Bur
                                            Did you draw a great circle (20m or so) or a small one (2m or so) ?
                                            But don't worry, since FaceMe components don't really have a bounding box, the number of components to be created is wrong, if I remember well...
                                            Regards,
                                            DB
                                            • 4 / 5
