    [Plugin] Component Spray Tool 1.3.
    92 Posts 44 Posters 102.2k Views 44 Watching
    • soloS Offline
      Yes please, I have the same issue where I need to mass some proxies but the boxes I'm using are all stacked and intersecting, maybe a collision checkbox?
        csolar
        I've just installed this (SU 7.1, WinXP), and I have a question about the spray pressure parameter. In the user guide it says that the # of components dropped is calculated as:
        [area of surface]/[average area of component(s)]*[spray pressure]
        In my case, the surface is a 10x10 square, and the component is a 1x1 square -- so the surface is 100 times the component area. If I select a spray pressure of 10%, I would expect 10 components to be dropped, but what I get is 100 components. Basically this calculation seems to be off by a factor of 10: if I ask for 100% pressure, then 1000 components get dropped, and so on.
        Am I missing something? I ask because for my model I really need lower densities; i.e. in line with the calculation described in the guide.
        Thanks,
        Chris.
          csolar
          Another observation:
          I select "random rotate", but when I look at the results it's clear that only 6 specific rotation angles are being used...actually more like 3 pairs of angles, 120 degrees apart, with the items in each pair being 8 degrees apart. Is this expected?
          Thanks, Chris.
          • Didier BurD Offline
            Didier Bur
            Hi csolar,
            Do you have set any angle snapping ?
            DB
            • FrederikF Offline
              Frederik
              Hi Didier,
              Any chance of adding what Solo and I have requested...??
              Cheers
              Kim Frederik
                csolar
                I did, but the results are the same after I turned off angle snapping.
                  Didier Bur
                  Yes. The only question is: when ? 😕
                  DB
                  • FrederikF Offline
                    Frederik
                    @didier bur said:
                    Yes.
                    Hopefully soon...
                    Cheers
                    Kim Frederik
                      Didier:
                      If you replace the native model.raytest with this method the rays won't stop on invisible entities:
                        # Raytrace method that does not stop on hidden entities.
                        def self.raytest(ray)
                          model = Sketchup.active_model
                          vector = ray[1]
                          while true
                            # Shot ray
                            test = model.raytest(ray)
                            return nil if test.nil?
                            # Verify visibility
                            point, path = test
                            if path.all? { |e| e.visible? && e.layer.visible? }
                              return test
                            else
                              # raytest stopped on a hidden entity - create a new ray from that point
                              # and let the loop continue until it hits something visible, or nothing.
                              ray = [ point, vector ]
                          end # while
                        Didier Bur
                        Hi tt,
                        DB
                        • I Offline
                          inbal
                          thank so much 😄
                            lapx
                            Problems with component spray tool...Tool will not pick point after clicking.
                            Is anyone else have problems with the tool? All the parameters appear correct.
                            I'm placing byce on a simple plane is not working. Openig a new drawing helped but it always goes back to not working at some point.
                            I'm using in V6.
                            • charly2008C Offline
                              charly2008
                              I wanted to try compo spray but I get a huge number of components at a small circle. What am I doing wrong?
                              Charly
                                Didier Bur
                                Did you draw a great circle (20m or so) or a small one (2m or so) ?
                                But don't worry, since FaceMe components don't really have a bounding box, the number of components to be created is wrong, if I remember well...
                                Regards,
                                DB
                                  charly2008
                                  Hi Didier,
                                  The circle was about three meters. I tried the whole day. If i use it at a single line or a point then i get very small copies.
                                  Charly
                                  Untitled.skp
                                    charly2008
                                    For the above mentioned problem i found the solution. The values for Low and high scale where to less.
                                    But now although Keep vertical is selected, the tree is horizontal. For this I could not find the reason.
                                    Charly
                                      charly2008
                                      I found the error. This component was the reason. After I exploded the component and made it a new component, the error was gone.
                                      Charly
                                      • mariochaM Offline
                                        mariocha
                                        I'm having difficulty to make it work in SU 8.
                                        Confirmation ?
                                        But it is my first try, I must say.
                                        %(#008000)[Mario C.
                                          Confirmation ?
                                          Exactly what isn't working?
                                          • mariochaM Offline
                                            mariocha
                                            Well, like I said it was my first try. I finally got it after a few more tries.
                                            My mistake was to try to "spray" on a face in a group being outside of it.
                                            Somehow I assumed that's what it did. 😳
                                            Maybe cause I cannot get the "selection" option to work. It just stops and asks to select objects, even when a face is selected before, and it stays suck there, clicking or enter do nothing.
                                            I read the manual, again (very well done btw). Maybe a warning line could be added about groups. 😄
                                            Although it is so obvious now.
                                            %(#008000)[Mario C.
                                            • 4 / 5
