    [Plugin] Component Spray Tool 1.3.
    92 Posts 44 Posters 99.2k Views 44 Watching
    • majidM Offline
      majid
      tanx tanx tanx and a word : tanx Didier
        jiegou
        thanks.
          sbthomas
          I am trying to use the component spray tool to place trees on terrain from google earth. The trees intersect the ground fine on the hills but in the valley they are hovering above the surface. What am I doing wrong??
          Thank you guys
          • plot-parisP Offline
            plot-paris
            do you have any geometry on a hidden layer in that valley (buildings for example). because the Component Spray Tool does regard hidden layers as well.
            @Didier,
            is it possible to change that, so that only active layers are taken into consideration? that would be awesome.
            • Didier BurD Offline
              Didier Bur
              No, because the raycast ruby method does not support hidden entities or inactive layer 😞
              DB
                sbthomas
                I have not added anything to the su file but the image/terrain from GE and the bilboard style tree that I'm trying to multiply. When you import the tree it will fall on the surface on the hilltops or in the valley, but when you try to spray the tree (even with the point style) the tree doesn't want to drop to the ground in the valleys. Is the Z placement limited to the zero elevation(I see negative and positive elevation limits in the spray dialog box)?
                Thanks for trying to help.
                STAN
                • Chris FullmerC Offline
                  Hi Didier, I have some requests that I wouldn't mind seeing in a script like this. I'll list them below and if any are interesting to your or easy to incorporate, I'd be thrilled! Ok, so I mostly like to use 2d faceme components, so I think my ideas might be more useful for 2d faceme plants/trees and people.
                  1. The ability to create pre made lists of components. So currently you have 6 slots to set the components. But editable lists would be cool. So I could make a large list of all my 2d faceme people, then a different list of all my 2d faceme sillhouette people. Both of these lists are much larger than 6 components, so it would be cool if there was something of a component group editor. So instead of selecting the components one by one, I could choose from my lists I had previously put together. This is probably my #1 request if you want to add it πŸ˜„
                  2. Skip this one, it was random size. I got it work - excellent!
                  3. The point and click method should be random (I think). So it doesn't just go in the order of the list. Or maybe a radio tickbox allowing for random order, or following the list order.
                  4. Perhaps being able to save different default profiles. So I can set up a default spray for people, then a default for large forrest trees, one for small bushes, etc. This might not be the most important thing to implement, but could be interesting?
                  I think that is it for now. I had put a lot of thought into a similar script a while ago, but I can't rememebr everything. So if I think of anything more, I'll be sure to add it to this thread πŸ˜„
                  Again, awesome work Didier. I plan on using this regularly.
                  All my Plugins I've written
                    Stan,
                    Can it be the case that your terrain valleys are under the ground level in SU (I mean they have negative values on the z axis)?
                    Because if so, the GE Snapshot (which is a horizontal face on 0 z axis) would stop the trees falling under it.
                      Didier Bur
                      Spray tool doesn't mind if there are negative coordinates. This must be something else that prevents the trees to land on the terrain...
                      DB
                        sbthomas
                        Gaieus; I think you are right. The GE snapshot seems to be limiting the z placement of trees even if I toggle terrain on. I'll break the GE snapshots up to smaller sections to see if I can get around the problem for now. If there is a way to adjust the axis of the snapshot to make this work better let me know.
                        STAN
                          Didier Bur
                          Yes. The ruby "raycast" method don't care of hidden layers or entities (no way to get rid of this). You should make a component of your GE snapshot, save it outside your model, delete it in the model, spray your trees, and bring the GE snapshot component back afterwards.
                          Regards,
                          DB
                            If you unlock it and cut it,you can insert it into another model with the Edit > Paste in place command. At the end you can bring it back in the same way to make it sure it is really at the same place.
                              Any thoughts on my requests Didier? Look back a few posts. Especially the first one. It's really important to my workflow. Would it be possible to include? Thanks for looking,
                              Chris
                                Didier Bur
                                Yes, it is possible to include your requests, but you'll have to be patient πŸŽ‰
                                I'm on a huge project now and I'm afraid I must leave my freebies as they are for a couple of weeks...
                                DB
                                  Oh I can be patient πŸ˜„ I just wanted to make sure you saw my thoughts and would see if they were good ideas or useless. Thanks for looking at it Didier, you're the best!
                                  Chris
                                    sbthomas
                                    Gaieus & Didier;
                                    Using your suggestions I have been able to overcome the issue of spraying in the valleys of GE snapshots. The process is as follows:
                                    Get GE snapshot
                                    toggle terrain
                                    save-as "snapshotname"
                                    unlock terrain
                                    explode terrain
                                    edit>copy terrain
                                    file>new sketchup project
                                    edit>paste-in-place
                                    insert component
                                    spray component
                                    delete terrain
                                    import saved snapshot
                                    place model back to GE
                                    thanks again for your help.
                                    STAN
                                      Hi Stan,
                                      In order to make sure your original terrain remains intact,after the step where you copy it,you can just undo the steps in the original model (the copied version will remain on the clipboard and you can use the paste in place command in the new model to spray the components).
                                        This is one of my absolute favourite rubies. I just detailed a large terrain model with 4000 trees in no time. I would never have gotten such a rich detail to it manually.
                                          Hi Didier, I have found that this script is conflicting with progressbar.rb, and therefore crashing all scripts that are using progressbar (makefaces in particular!, but I found the problem while developing my own script). There is a pb.update() method in the progressbar that seems to not work so I'm guessing that is where the conflict is - but I could be WAAAAY off. Thanks Didier!
                                          I was wondering if anyone else could confirm this?
                                          Chris
                                            Does it make use of the disable UI argument for .start_operation ?
                                            • 2 / 5
