    [Plugin] Component Spray Tool 1.3.
    92 Posts 44 Posters 99.2k Views 44 Watching
    • Didier BurD Offline
      Didier Bur
      Do you shine in ruby field only or there are some lisp routins of yours?
      I was used to code in Autolisp years ago, and now I'm learning Javascript along with Unity3D. πŸ˜›
      Regards
      DB
        arjunmax09
        didier... your compo spray is interfering with the progressbar script.. any improvements you've made to compo spray so that it doesn't do the progressbar thing??
        when you fail at something....you haven't really failed...you've found one way the thing will not work out
          Didier Bur
          I though I had done this several monthes ago, but just in case see page 1 of this thread and download the latest version. The spray uses its own progress bar class named "sprayprogressbar", so there should not be any conflict with other plugin(s).
          If the problem persists, not my fault anymore πŸ˜‰
          Regards,
          DB
            arjunmax09
            um.. didier ... there's no ruby file in the latest update... there's one rbs file and one pdf file... where did the plugin go man...??? πŸ˜’ The rbs file is in the following folder.....
            Utilisateurs\Bur\Exercices\Ruby\Component_airbrush
            checked both the english and french versions.. both the archives contain the same files....please help... 😞
            • Chris FullmerC Offline
              .rbs is a plugin. It is the extension put on encrypted plugins.
              Didier, we are running into problems where it appears that this script is breaking progressbar again. I know you fixed it up perfectly quite a while ago. did it revert back somehow to a version that no longer works? Or do you think that it should still be working correctly and that perhaps it is something else messing up progressbar? Any thoughts?
                maymay
                I get an error when SketchUp starts:
                Error Loading File compo_spray.rb
                C;/Program Files/Google/Google SketchUp 6/Plugins/compo_spray.rb;1; no .<digit> floating literal anymore; put 0 before dot
                RBS1.0
                C;/Program Files/Google/Google SketchUp 6/Plugins/compo_spray.rb;1; syntax error
                RBS1.0
                C;/Program Files/Google/Google SketchUp 6/Plugins/compo_spray.rb;1; Invalid char `\030' in expression
                Any ideas? I'd really like to try this out.
                  Didier Bur
                  Hem, hem, it seems we have some problems with the scrambler now...
                  I've uploaded the latest RB version, in which there's NO progressbar class. I suppose there's a conflict with another plugin than this one.
                  Sorry for the inconvenience with the RBS.
                  Regards,
                  DB
                    rangrstudio
                    Hi I'm trying to install this on Mac with Sketchup 7.
                    The compo_spray.rb is in the Plugins folder, but I'm not seeing it in the plugins menu. Have reinstalled SKP 7 from scratch, then unzipped the zip file in the plug-ins folder per instructions but nothing.
                    Is it not mac compatible?
                    EDIT: I tried it on a windows machine (XP with SKP 7) and I couldn't get it to work there either. The zip contains "compo_spray.rb" and the pdf file. Is there something missing? Thanks for any help.
                      If you read the PDF help file you'd see that Component Spray Tool is accessed from a pop-out menu in Draw Menu NOT the Plugins Menu !CStool.png
                        rangrstudio
                        @tig said:
                        If you read the PDF help file you'd see that Component Spray Tool is accessed from a pop-out menu in Draw Menu NOT the Plugins Menu ![attachment=0:2qfvuyqu]<!-- ia0 -->CStool.png<!-- ia0 -->[/attachment:2qfvuyqu]
                        Thank you! I guess I should read the whole manual...
                        This is an amazing tool.
                        • FrederikF Offline
                          Frederik
                          This is a GREAT tool...
                          Would it be possible to make an option, where components sprayed don't intersect with each other...??
                          It's possible to prevent stacking, but I miss an option, where components don't intersect also...
                          Perhaps even an option, where I can define how close components can be to each other...
                          Could have both positive and negative entries...
                          Any ideas...??
                          Cheers
                          Kim Frederik
                          • soloS Offline
                            Yes please, I have the same issue where I need to mass some proxies but the boxes I'm using are all stacked and intersecting, maybe a collision checkbox?
                              csolar
                              I've just installed this (SU 7.1, WinXP), and I have a question about the spray pressure parameter. In the user guide it says that the # of components dropped is calculated as:
                              [area of surface]/[average area of component(s)]*[spray pressure]
                              In my case, the surface is a 10x10 square, and the component is a 1x1 square -- so the surface is 100 times the component area. If I select a spray pressure of 10%, I would expect 10 components to be dropped, but what I get is 100 components. Basically this calculation seems to be off by a factor of 10: if I ask for 100% pressure, then 1000 components get dropped, and so on.
                              Am I missing something? I ask because for my model I really need lower densities; i.e. in line with the calculation described in the guide.
                              Thanks,
                              Chris.
                                csolar
                                Another observation:
                                I select "random rotate", but when I look at the results it's clear that only 6 specific rotation angles are being used...actually more like 3 pairs of angles, 120 degrees apart, with the items in each pair being 8 degrees apart. Is this expected?
                                Thanks, Chris.
                                  Didier Bur
                                  Hi csolar,
                                  Do you have set any angle snapping ?
                                  DB
                                  • FrederikF Offline
                                    Frederik
                                    Hi Didier,
                                    Any chance of adding what Solo and I have requested...??
                                    Cheers
                                    Kim Frederik
                                      csolar
                                      I did, but the results are the same after I turned off angle snapping.
                                        Didier Bur
                                        Yes. The only question is: when ? πŸ˜•
                                        DB
                                        • FrederikF Offline
                                          Frederik
                                          @didier bur said:
                                          Yes.
                                          πŸ‘Š
                                          Hopefully soon...
                                          Cheers
                                          Kim Frederik
                                            Didier:
                                            If you replace the native model.raytest with this method the rays won't stop on invisible entities:
                                              # Raytrace method that does not stop on hidden entities.
                                              def self.raytest(ray)
                                                model = Sketchup.active_model
                                                vector = ray[1]
                                                while true
                                                  # Shot ray
                                                  test = model.raytest(ray)
                                                  return nil if test.nil?
                                                  # Verify visibility
                                                  point, path = test
                                                  if path.all? { |e| e.visible? && e.layer.visible? }
                                                    return test
                                                  else
                                                    # raytest stopped on a hidden entity - create a new ray from that point
                                                    # and let the loop continue until it hits something visible, or nothing.
                                                    ray = [ point, vector ]
                                                end # while
                                            • 4 / 5
