    Proper_animation.rb ,some questions
    45 Posts 14 Posters 9.7k Views 14 Watching
      Shotster
      I've been trying some paper folding animations using nested components. The animation of a nested component works as expected when in the context of (i.e. editing) the parent component. However, when not in component edit mode, the nested component does not animate properly. It does move - but typically way out of view, off in left field. It appears that when you're editing the parent component, the nested component's motion is relative to its parent, but when not editing the parent component, the motion is relative to something else.
      Any chance this could be "fixed" so that nested components always move relative to their parent?
      -Steve
        Hi Malaise,
        Could you add one more scene "in between" when moving your ship? (Of course it should be added within the transformation script itself - it wouldn't work "from outside").
        @__Steve__- I haven't played around with this but what if you set the origin of both your parent and child component to the original world axis? I can imagine it has something to do with active axes somehow.
        • MALAISEM Offline
          MALAISE
          Hi Gaieus
          Interesting suggestion, let me try.. 👍 ( stepping motorized boat maybe ?)
          MALAISE
            But then also turn off (set to 0) the animation delayin the Model info > Animation settings (there will be a very short delay anyway I'm afraid).
              Shotster
              @gaieus said:
              Steve- I haven't played around with this but what if you set the origin of both your parent and child component to the original world axis?
              Unless I'm misunderstanding something, I don't see how that will help, as I need the components to rotate about different axes. ❓
                roberta
                Hello there,
                I'm using a MAC and downloaded proper-animation.rb but everytime I right klick the component and try to "get position" in order to record it for the animation sketch-up crashes.
                Is there anything I can do about that?
                Could anyone help?
                Thanks Roberta
                • MALAISEM Offline
                  MALAISE
                  Hi Roberta,
                  You 're not the first to encounter such a problem on MAC. It's due to MAC way of
                  managing ruby plugins. Our friend Morisdov is already warned about this. Just have a look in the same folder. N Lindenthal has the same strange behaviour.
                  301 Moved Permanently
                  (www.sketchucation.com)
                  MALAISE 😉
                    morisdov
                    Robert i emailed you PM with the older version of the plugin.
                    See if it does not crush on a MAC.
                      morisdov
                      @n lindenthal said:
                      My Mac has proper animation with proper_animation, if I drag the folder »extensionmanager« out of Tools folder. Then the right mouse click menue on marked objets has the item »Transformation«.
                      Now the question would be, whether this same folder »extentionmanager« also disturbs the context menue of SketchUp on Windows PC.
                      I can not find a comparable folder on my Windows machine.
                      My Plugin itself is properly wrapped in a module and is not using any global variables, so there should be no collision with other plugins.
                      Can you zip and email me the contents of that folder ?
                      See if its removal has no other negative consequenses.
                        tomasz
                        Hi Malaise,
                        I have rendered your robot. It is a VERY quick an dirty test.
                        Will need more time to fix few things in gui 😄
                        p.s. I couldn't attach avi directly
                        KT render @ low quality - ca. 3 frames per minute
                        Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                          miikka1978
                          Tomasz and morisdov,
                          Looks great! Finally we will be able to render simple Sketchup animations with moving objects in Kerkythea. At least I assume that Tomasz's animation was rendered in Kerkythea.
                          • N Offline
                            N Lindenthal
                            Mac OS X 10.4.10, SketchUp 6 (6.4.120)
                            @malaise said:
                            N Lindenthal has the same strange behaviour. …
                            Now the question would be, whether this same folder »extensionmanager« also disturbs the context menue of SketchUp on Windows PC.
                            • MALAISEM Offline
                              MALAISE
                              Hi Animation's Fellows !
                              I'm still using proper_animation, and drawing quite more complex models used for
                              technical and education purpose. It's one of the easiest way to give explanation
                              about repeating séquences done by machines
                              Only one question : Has someone made what I name a "knee" ?
                              A component is rotating along its axe , a second one
                              may turn around an reference attached to the first component.
                              ( think to a leg with its knee )
                              I can't reach a stable axe for the 2nd group.
                              Thank for any remarks.
                              MALAISE
                              • MALAISEM Offline
                                MALAISE
                                Hello Morisdov and Tomasz
                                I saw on YouTube the render, great !
                                MALAISE 😄
                                • N Offline
                                  N Lindenthal
                                  Please select all and write in your Ruby console:
                                  Morisdov.transf_get("transf1")
                                  or
                                  Morisdov.transf_get("transf2")
                                  SU knee
                                  • MALAISEM Offline
                                    MALAISE
                                    Hallo N_Lindenthal
                                    I'll study your example and try to use Ruby commands
                                    Thanks for this fast answer. 👍 👍
                                    Ausgezeichnet 😄
                                    MALAISE
                                    • MALAISEM Offline
                                      MALAISE
                                      Hallo everybody
                                      Who have an idea to solve the problem shown in the hereby file.
                                      Still this crazy "knee" or "elbow" problem.
                                      Thanks for helps
                                      MALAISE 💭
                                      drehende Probenhandler.skp
                                      • N Offline
                                        N Lindenthal
                                        My idea would be to make two groups, two axes, and then make one component.
                                        • FletchF Offline
                                          Fletch
                                          @ Tomasz:
                                          http://www.kerkythea.net/phpBB2/images/smiles/kt_dance.gif
                                          http://www.kerkythea.net/phpBB2/images/smiles/kt_clap.gif
                                          Fletch
                                          3D Modeling addict. Former owner/developer of Twilight Render. sleepinggiantvisual.com
                                            Julius
                                            Hi Malaise,
                                            how did you do this?
                                            • 2 / 3
