    Proper_animation.rb ,some questions
    45 Posts 14 Posters 9.7k Views 14 Watching
      morisdov
      @n lindenthal said:
      My Mac has proper animation with proper_animation, if I drag the folder »extensionmanager« out of Tools folder. Then the right mouse click menue on marked objets has the item »Transformation«.
      Now the question would be, whether this same folder »extentionmanager« also disturbs the context menue of SketchUp on Windows PC.
      I can not find a comparable folder on my Windows machine.
      My Plugin itself is properly wrapped in a module and is not using any global variables, so there should be no collision with other plugins.
      Can you zip and email me the contents of that folder ?
      See if its removal has no other negative consequenses.
        tomasz
        Hi Malaise,
        I have rendered your robot. It is a VERY quick an dirty test.
        Will need more time to fix few things in gui 😄
        p.s. I couldn't attach avi directly
        KT render @ low quality - ca. 3 frames per minute
        Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
          miikka1978
          Tomasz and morisdov,
          Looks great! Finally we will be able to render simple Sketchup animations with moving objects in Kerkythea. At least I assume that Tomasz's animation was rendered in Kerkythea.
          • N Offline
            N Lindenthal
            Mac OS X 10.4.10, SketchUp 6 (6.4.120)
            @malaise said:
            N Lindenthal has the same strange behaviour. …
            Now the question would be, whether this same folder »extensionmanager« also disturbs the context menue of SketchUp on Windows PC.
            • MALAISEM Offline
              MALAISE
              Hi Animation's Fellows !
              I'm still using proper_animation, and drawing quite more complex models used for
              technical and education purpose. It's one of the easiest way to give explanation
              about repeating séquences done by machines
              Only one question : Has someone made what I name a "knee" ?
              A component is rotating along its axe , a second one
              may turn around an reference attached to the first component.
              ( think to a leg with its knee )
              I can't reach a stable axe for the 2nd group.
              Thank for any remarks.
              MALAISE
              • MALAISEM Offline
                MALAISE
                Hello Morisdov and Tomasz
                I saw on YouTube the render, great !
                MALAISE 😄
                • N Offline
                  N Lindenthal
                  Please select all and write in your Ruby console:
                  Morisdov.transf_get("transf1")
                  or
                  Morisdov.transf_get("transf2")
                  SU knee
                  • MALAISEM Offline
                    MALAISE
                    Hallo N_Lindenthal
                    I'll study your example and try to use Ruby commands
                    Thanks for this fast answer. 👍 👍
                    Ausgezeichnet 😄
                    MALAISE
                    • MALAISEM Offline
                      MALAISE
                      Hallo everybody
                      Who have an idea to solve the problem shown in the hereby file.
                      Still this crazy "knee" or "elbow" problem.
                      Thanks for helps
                      MALAISE 💭
                      drehende Probenhandler.skp
                      • N Offline
                        N Lindenthal
                        My idea would be to make two groups, two axes, and then make one component.
                        • FletchF Offline
                          Fletch
                          @ Tomasz:
                          http://www.kerkythea.net/phpBB2/images/smiles/kt_dance.gif
                          http://www.kerkythea.net/phpBB2/images/smiles/kt_clap.gif
                          Fletch
                            Julius
                            Hi Malaise,
                            how did you do this?
                              I guess he is playing with a beta version of su2kt
                                tomasz
                                I have modified the SU2KT script. I am distracted by many things at the moment and it is hard for me to focus on programming, but the 'technology' is there. Getting it into your hands is just a matter of time.
                                  kwistenbiebel
                                  @Thomasz, I can't get that animation you posted to play.
                                  I unzipped the .zip file and tried opening the .avi both in windows media player as in VLC player. No success.
                                    works fine for me with the free Mediaplayer Classic 👍
                                    The krosoft Player is null 😒
                                      Julius
                                      take your time. 😉 thx.
                                      • 2 / 3
