    Proper_animation.rb ,some questions
    45 Posts 14 Posters 11.6k Views 14 Watching
    • MALAISEM
      MALAISE
      Hi Roberta,
      You 're not the first to encounter such a problem on MAC. It's due to MAC way of
      managing ruby plugins. Our friend Morisdov is already warned about this. Just have a look in the same folder. N Lindenthal has the same strange behaviour.
      404 Not Found
      (www.sketchucation.com)
      MALAISE 😉
        morisdov
        Robert i emailed you PM with the older version of the plugin.
        See if it does not crush on a MAC.
          morisdov
          @n lindenthal said:
          My Mac has proper animation with proper_animation, if I drag the folder »extensionmanager« out of Tools folder. Then the right mouse click menue on marked objets has the item »Transformation«.
          Now the question would be, whether this same folder »extentionmanager« also disturbs the context menue of SketchUp on Windows PC.
          I can not find a comparable folder on my Windows machine.
          My Plugin itself is properly wrapped in a module and is not using any global variables, so there should be no collision with other plugins.
          Can you zip and email me the contents of that folder ?
          See if its removal has no other negative consequenses.
          • T
            tomasz
            Hi Malaise,
            I have rendered your robot. It is a VERY quick an dirty test.
            Will need more time to fix few things in gui 😄
            p.s. I couldn't attach avi directly
            KT render @ low quality - ca. 3 frames per minute
              miikka1978
              Tomasz and morisdov,
              Looks great! Finally we will be able to render simple Sketchup animations with moving objects in Kerkythea. At least I assume that Tomasz's animation was rendered in Kerkythea.
              • N
                N Lindenthal
                Mac OS X 10.4.10, SketchUp 6 (6.4.120)
                @malaise said:
                N Lindenthal has the same strange behaviour. …
                Now the question would be, whether this same folder »extensionmanager« also disturbs the context menue of SketchUp on Windows PC.
                • MALAISEM
                  MALAISE
                  Hi Animation's Fellows !
                  I'm still using proper_animation, and drawing quite more complex models used for
                  technical and education purpose. It's one of the easiest way to give explanation
                  about repeating séquences done by machines
                  Only one question : Has someone made what I name a "knee" ?
                  A component is rotating along its axe , a second one
                  may turn around an reference attached to the first component.
                  ( think to a leg with its knee )
                  I can't reach a stable axe for the 2nd group.
                  Thank for any remarks.
                  MALAISE
                  • MALAISEM
                    MALAISE
                    Hello Morisdov and Tomasz
                    I saw on YouTube the render, great !
                    MALAISE 😄
                    • N
                      N Lindenthal
                      Please select all and write in your Ruby console:
                      Morisdov.transf_get("transf1")
                      or
                      Morisdov.transf_get("transf2")
                      SU knee
                      • MALAISEM
                        MALAISE
                        Hallo N_Lindenthal
                        I'll study your example and try to use Ruby commands
                        Thanks for this fast answer. 👍 👍
                        Ausgezeichnet 😄
                        MALAISE
                        • MALAISEM
                          MALAISE
                          Hallo everybody
                          Who have an idea to solve the problem shown in the hereby file.
                          Still this crazy "knee" or "elbow" problem.
                          Thanks for helps
                          MALAISE 💭
                          drehende Probenhandler.skp
                          • N
                            N Lindenthal
                            My idea would be to make two groups, two axes, and then make one component.
                            • FletchF
                              Fletch
                              @ Tomasz:
                              http://www.kerkythea.net/phpBB2/images/smiles/kt_dance.gif
                              http://www.kerkythea.net/phpBB2/images/smiles/kt_clap.gif
                              Fletch
                                Julius
                                Hi Malaise,
                                how did you do this?
                                • GaieusG
                                  I guess he is playing with a beta version of su2kt
                                  • T
                                    tomasz
                                    I have modified the SU2KT script. I am distracted by many things at the moment and it is hard for me to focus on programming, but the 'technology' is there. Getting it into your hands is just a matter of time.
                                    • K
                                      kwistenbiebel
                                      @Thomasz, I can't get that animation you posted to play.
                                      I unzipped the .zip file and tried opening the .avi both in windows media player as in VLC player. No success.
                                        works fine for me with the free Mediaplayer Classic 👍
                                        The krosoft Player is null 😒
                                          Julius
                                          take your time. 😉 thx.
                                          • 2 / 3
