    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.8m Views 202 Watching
    • J
      j_forrester
      Had a look and cant see anyone with similar problem. On startup I get the below dialogue box. Any ideas? Installed Fredo 3.4c and run Mac Pro.
      Many thanks.
      • D
        dylan
        Thanks, really nice improvement 👍
        Can't get Daniels icons to show. If I choose them from Default Parameters and ok it, nothing happens. If I open again, the tick in the box is gone.
        http://dmdarchitecture.co.uk/
        • fredo6F
          fredo6
          @thomthom said:
          Can the TOS_Dir_13 folder be removed?
          YES, I forgot to say it.
          Anyway, the folder is passive, as no loader is pointing at it.
          Fredo
          • FrederikF
            Frederik
            Thanks for this, Fredo...! 😄
            Cheers
            Kim Frederik
            • D
              Dan
              I replaced the icons in "IMAGES_Standard" subfolder with the icons set of choice and all went ok.
              • D
                Dan
                I don't remember if I gave thanks to you, Fredo, but if I did, I repeat them: THANK YOU VERY MUCH for your life saving, incredible tools! 😍
                A wish, though: can you make the additional TOS palette to remember its position on screen from a SU session to another?
                • takesh hT
                  takesh h
                  Yes the trick did the job, thanks Dan. 👍
                  • D
                    dylan
                    Thanks Dan, perfect!
                    I was trying to replace them in images DanielS.
                    • olisheaO
                      olishea
                      I love this tool, I use it all the time.
                      Endless thanks 😍 😍 😍
                      oli
                      • fredo6F
                        fredo6
                        You can specify the default position in the SeTtings dialog box of LibFredo6 (so in the Windows > LibFredo6 Settings menu).
                        Fredo
                        • fredo6F
                          fredo6
                          It seems there is a problem with that, but only on Mac.
                          I am checking this issue.
                          Fredo
                          • MALAISEM
                            MALAISE
                            Merci Fredo, I watched the video, that gives us new horizons.... 👍
                            MALAISE
                            • D
                              Dan
                              Thanks a lot, Fredo!
                              I completely forgot I can use it to change the default parameters... 😳
                              This is one of the most complete plugins I see.
                              Thanks again!
                              • L
                                lorca
                                That did the trick:)------> Thanks.
                                • fredo6F
                                  fredo6
                                  Dan and Dylan (and any others having the problem of non-persistence of the choice of Icons)
                                  I have a few questions:
                                  1. does it happen on Mac only?
                                  2. Are all other parameters shown in the Button palettes saved across Sketchup sessions (i.e. nb of segments, options, etc...) ?
                                  3. Could someone send me by PM the file ToolsOnSurface.def in the subfolder DEFPARAM_Dir.
                                  Fredo
                                  • G
                                    gaonirico
                                    Hi Fredo. Grandiose plugins that have created. But I have a problem, after that installed the new version of ToolsOnSurface 1.5. In SketchUp the option to translate the tools with LibFredo6 appears blank, as also the option to translate ToolsOnSurface. The remainder of the tools to translate function very well, as those of GhostComponent or RoundCorner. In spite of the inconvinient of can translate all tools function perfect they...Oh, I am sorry if not very clear for my poor speak english. 😳
                                    • fredo6F
                                      fredo6
                                      @gaonirico said:
                                      :sketchstatic: Hi Fredo. Grandiose plugins that have created. But I have a problem, after that installed the new version of ToolsOnSurface 1.5. In SketchUp the option to translate the tools with LibFredo6 appears blank, as also the option to translate ToolsOnSurface.
                                      I noticed the problem which seems to be only in SU6 and only the very first time you open the translation dialog box. I am going to investigate.
                                      In between, if you slightly resize the dialog box or close and re-open it, you'll get the content. This is not specific to ToolsOnSurface.
                                      Are you going to translate into Spanish? Any language...., thank you in advance
                                      Fredo
                                      • G
                                        gaonirico
                                        Fredo
                                        Thanks for your answer. The problem proved to be that I must erase the ToolsOnSurface 1.2 TOS_Dir_13 folder. Now it works well. When I am finishes make the corresponding translation to the Spanish will give you the corresponding LANG file.
                                        • C
                                          cyan.archnet
                                          will definitely give this a try!, A BIG THANK YOU!! for this awesome plugin!!
                                          • boofredlayB
                                            boofredlay
                                            Fredo
                                            I just installed the update and I don't even have the option to choose an icon set in the Default Parameters. I am on a PC with XP.
                                            DP.jpgAlso, I noticed that when I deleted the old LIBFREDO6_Dir_32 and TOS_Dir_13 folders my TOS toolbar disappeared. It reappeared after restoring those folders.
                                            Any ideas?
                                            Thanks.
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 31
                                            • 32
                                            • 11 / 32
