    ⚠️ Important | Libfredo 15.6a introduces important bugfixes for Fredo's Extensions Update
    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.6m Views 202 Watching
    • fredo6F Offline
      fredo6
      The information on ToolsOnSurface is maintained on the Plugin Home Page of ToolsOnSurface. This is also where you can download the RBZ file.
      • LibFredo6: v14.3b or above
      • Sketchucation ExtensionStore: v4.4.0 or above (for licensing)
      • Usage: Licensed under Sketchucation SCFLicense
      • Free Trial period (full features): 30 days from first usage
      • Perpetual license (3 seats): $15
      • Part of Fredo6Bundle2022 license (8 plugins): $50
      To purchase the license of ToolsOnSurface or the Bundle of 8 plugins, go to this page and sign in.
      Tools on Surface is a Suite of Tools drawing on curved surfaces, with lines, various shapes, offset and Freehand / Polyline. It provides an inference mechanism, a Contour Editor and a dedicated Eraser.
      Shapes includes:
      • Circleand Polygon
      • Rectangle, defined by its length and width
      • Parallelogram, defined by its length, width and angle
      • Ellipses, defined by axes
      • Circle defined by 3 points
      • Arcs(circular)
      • Sectors, defined by origin, direction and angle
        All shapes have in addition the option to draw Rings, that is, the same contour offset by a negative or positive distance. And of course, all generated contours can be later edited by the Contour Edition tool.
      The inference mechanismtries to simulate some stickiness when lines are drawn along some remarkable directions. There is also a Lock inference mechanism to force drawing in a particular direction. A Protractor can help to pick particular angles.
      ToolsOnSurface also works to draw lines and shapes 'without' a surface.
      See videos in the tutorial
      Quickcard ToolsOnSurface - English - v2.0 - 12 Nov 13.pdf
      Quickcard ToolsOnSurface - French - v2.0 - 12 Nov 13.pdf
      There is a very good video by Justin (TheSketchupEssentials) giving an overview of the plugin.
      • fredo6F Offline
        fredo6
        Additional doc on Offset on Surface(which I could not attach to previous message, as It exceeded the limit of 2 Mb). Just drop it in the TOS_Dir_13 subfolder.
        to drop in subfolder TOS_Dir_13
          chango70
          OMG! you work tirelessly to make Sketchup the tool that it is today! Hail! 😍
            stanmarsh
            Thanks Fredo6! very useful plugin! 😍
              Now, Fredo, I totally get rid of my native "Draw" toolbar and replace it with yours!
              Thanks a bunch! πŸ‘ πŸ‘ πŸ‘
              • fredo6F Offline
                fredo6
                On Matt666's suggestion (right before I released), it could be possible to configure ToolsOnSurface as an extension of Sketchup (like Sandbox), which you can turn on and off from the Menu Preferences--> Extensions.
                This way, you can decide whether you want to load it, or can turn it off when you troubleshoot your plugins.
                As I don't know what would be the best for users, I would simply ask all of you about what you think is more appropriate.
                For the version configured as Extension, you just need to replace the file ZLoader__OnSurface.rbwith the one attached in the Sketchup plugins directory.
                Also, I indicate the time of loading the ToolsOnSurface scriptsin the About menu item of the ToolsOnSurface menu. Can you check if you see abnormal load times in your environment(on mine it is below 100 ms)
                Thanks for your feedback
                Fredo
                To replace the existing file in the Sketchup PLugins folder
                  remus
                  whyd i have to see this jsut before i went to work! ill be thinking about this all day now!
                  cheers πŸ‘
                  • I Offline
                    ilay7k
                    Fredo, thank you! πŸ‘
                      Hi Fredo,
                      Although I have removed all older files and folders, every time I click on any of the tools the first time I start SU it gives this popup:
                      Not a very big deal however, since it only pops up once in a session - just telling...
                      • FrederikF Offline
                        Frederik
                        I have same issue as Csaba... 😐
                        Strange thing is, that I haven't any of the sub-folders mentioned (TOS and/or OFS), since I haven't installed previous versions of this plug-in...
                        It's no big deal, but I assume that it's something that will be fixed soon..?!? πŸ˜‰
                        Any way... THANKS for another GREAT plug-in..!! πŸ‘ πŸ˜„
                        Cheers
                        Kim Frederik
                        • BurkhardB Offline
                          Burkhard
                          Mistake!
                          [http://www.ia-plus.de(http://www.ia-plus.de)]
                          • fredo6F Offline
                            fredo6
                            The Warning message is simply a bug. Thanks to signal it and sorry for that.
                            I have updated the Zip file in the main message of this thread. I also integrate the code to make the script a proper Sketchup Extension, based on a suggestion from Matt666. You'll need to activate the script after first installation in the Preferences-Extension dialog box.
                            Hope this is fine now
                            Fredo
                              OK, thanks Fredo! - and again, for this great tool! πŸ‘
                              • fredo6F Offline
                                fredo6
                                I did too fast. The bug was still present.
                                The correct version is now online in the main message (after 12h45 today)
                                  Never mind - I have not downloaded it yet anyway because I had other stuff to finish first πŸ˜‰
                                    Stu
                                    Wow Fredo, more fantastic stuff!!
                                    Thanks a million!!
                                    http://www.landesign.com.au
                                    • EdsonE Offline
                                      Edson
                                      hi fredo,
                                      thanks again for one more great script.
                                      1. i am also getting the message about looking for older versions of the script.
                                      2. why do i have the line drawing tool twice on my menu? see picture.
                                      regards.
                                      http://www.mahfuz.arq.br
                                        @edson said:
                                        1. why do i have the line drawing tool twice on my menu? see picture...
                                        That's a bonus for Mac users, Edson!
                                        πŸ˜„
                                        • fredo6F Offline
                                          fredo6
                                          @edson said:
                                          hi fredo,
                                          regards.
                                          Edson,
                                          It looks like you have something rescued from version 1.1. Did you delete the older files?
                                            Daniel S
                                            Fantastic!! Thank you Fredo!!! Love the new tools and the inference mechanism (these visual cues makes all much easier and faster) 😍 😍 😍
                                            Thank you again,
                                            Daniel S
                                            PS. Hope that the next update goes for your Round Edge (by Bezier) tool.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 31
                                            • 32
                                            • 19 / 32
